Question about Microwave Ovens
We have a samsung microwave ms143sce, that stops completly and screen goes dead after about 8 min, the after cooling about 20 min it resets again and then can I use it again.
SOURCE: Dead microwave
check mains fuse and check control circuit and magnetron. and diodes capacitor  high voltage related circuit. small part also gone microwaveoven doesnot works, first check oven and conform which part was spoiled, after that this is worth or not old ovens good compaare to new ones...
Posted on Oct 28, 2007
SOURCE: microwave won't start after 8 mins. starts again after about 10 mins.
check control unit or magnetron over heat becasue of fan not working properly check all the sensors and wiring ..
Posted on Nov 25, 2007
heatman101
  • 43501 Answers
SOURCE: We used the time cook versus timer and ran the
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Posted on Oct 11, 2010
  • 6771 Answers
SOURCE: We installed a GE Spacemaker Microwave. I put some
The main fuse may be intermittent, causing complete power failure, the other possibility is a defective door switch not operating properly, or loose plug in the power feed, I suggest a technician to take closer look at the system because this could prove tricky to find the culprit.
Posted on Jan 26, 2011
  • 186 Answers
SOURCE: My samsung model ms143sce microwave
a lot of times its the magnetron in microwaves that causes most errors and malfunctions. you will need a technician to repair this if this is the problem.
Posted on Jan 29, 2011
Need a user manual for Samsung TDS Microwave model no MS143SCE
Hello, Ismail -
This is the link to the web page where you can download the manual:
http://www.samsung.com/za/support/model/MS143SCE/XFA
Scroll down that page until you see MANUAL DOWNLOAD in large print.
Look on the right side on that section of the page and find the DOWNLOAD link.
Click or tap on the download arrow.
You will see all the pages of the manual, which you can download and save to the Documents folder of your computer (look for the icon in the upper right corner of the page; the icon looking like a piece of paper with a downward pointing arrow in the middle.)
Make sure you save the downloaded file using a file name you can find again easily - Samsung Microwave MS143SCE Manual, for example.
Note: You will need Adobe Acrobat Reader software, free.
Best wishes.
Feb 27, 2018 | Samsung Microwave Ovens
RE: Samsung microwave SMH7187STG mfg'd 5/08. I heated cup of tea 2 min.Then I closed micro's door & micro emitted a continuous electrical buzzing sound.I opened door & buzzing stopped.
The cook relay on your control board is shorted, and the unit is cooking whenever you close the door.
When the magnetron overheats, its thermostat opens, shutting power down until the unit cools to a safe level, then power is restored.
I regularly repair these with my $54.95 service, which includes insured return shipping.
Details are here, or for full information and instructions, please e-mail me here at pupista@gmail.com and remind me of your full model number and symptoms.
Dec 20, 2016 | Samsung Microwave Ovens
Microwave continues running whilst the door is shut - samsung ms143sce
Sounds like the timer control is faulty, it will need a technician to advise you on options
Aug 09, 2015 | Samsung Microwave Ovens
My samsung model ms143sce microwave is displaying error 5E or SE what could the problem be switching on and off does not solve the problem
Jan 29, 2011 | Microwave Ovens
During cooking, the microwave will work for about 3 minutes then completely shut down.There appears to be a complete power failure.After the units sits for about 5 minutes,it resets itself and you can cook...
sounds like the cooling fan has came adrift or stopped working , this will cause the magnatron ( the microwave generator ) to overheat tripping the over temperature stat ,so fix the cooling , but be sooooooooooooo carefull in there , microwaves + really high voltages , not really a job for a non electrician/microwave tech
Oct 20, 2009 | Samsung SMH7178STD Microwave Oven
Works up to about 5 min. then waits about 20 min. to cook again. HELP
When you say shuts off, do you mean it goes dead as if someone unplugged it, or does it stop as if someone hit the Stop pad?
If it is going dead, it sounds like the magnetron is overheating and opening the thermostat.
This can be caused when the internal cooling fan is not running or by a magnetron that is failing.
When I say internal cooling fan, I do not mean the hood vent exhaust fan which you can turn on and off manually.
I'm instead talking about the internal fan which comes on automatically whenever you microwave.
It is vital that the cooling fan runs, or the magnetron will be destroyed.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Sep 28, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
