Question about BenQ Office Equipment & Supplies
Connect the DSTV to Benq
We have the cables and set up everything. Every time we change the channel on the DSTV the picture came up and then disappears. Can you help
  • 53 Answers
SOURCE: am setting up a bose GSX 3-2-1 home theater
simplist solution, if the TV has an audio output just run that to the Bose system.
what type of TV are you connecting to?
Is the cable box an HD or digital box?
Posted on Jun 24, 2008
SOURCE: dstv to dvd recorder connection
  1. Grab your A/V composite wires and insert them into the Audio/Video OUTPUTS on the back of the satellite receiver. These are color-coded connections--red to red, white to white and yellow to yellow. The red and white connections are your audio feeds and the yellow is for your video.
  2. Look on the backside of your DVD/VCR dual recorder. You will see similar connections. Connect the other end of the composite wires to the Audio/Video INPUTS on the DVD/VCR dual recorder.
  3. With a second set of A/V composite wires, connect one end to the DVD/VCR dual recorder's A/V OUTPUT and the other end to the television's A/V INPUT. Again, be sure to follow the color code. Also, if your television has more than one available input, be sure to know to which one you made the connections (A/V 1, A/V 2, etc.).
Posted on May 02, 2009
  • 10 Answers
SOURCE: picture on all channels is dark
seems like its the inverter thats either not working or the tubes are faulty
Posted on Mar 27, 2010
  • 12 Answers
SOURCE: Need to connect my DSTV decoder through my sony
well this is easier than you think, get yourself a set of RCA's (the red and white and yellow cables that DVD players come with) look behind your decoder and place them colour to colour, then behind your Amp you will read (TV IN) do the same, then with just one yellow RCA plug it into (monitor) that one will then go to the (AV input) behind your TV.. And presto!!! now set your amp input on the remote to TV and your off!! good luck
Posted on May 03, 2010
  • 4961 Answers
SOURCE: How to unlock Dstv Channels on Strong Decoders?
You might want to post this question in a different section. This is the computer section.
Posted on Jul 15, 2012
I need to wirelessly connect my DSTV explorer to the internet using the Netgear n600 router
Dstv's directions are here at this link: ( the first step is connecting the Explora;s USB cable to the DStv receiver's WiFi port
How to connect the DStv Explora to theInternet using WiFi or Ethernet
Sep 17, 2017 | NetGear Computers & Internet
Hi I cannot get a picture just a green screen
If you are using a flat screen, there might be no signal source. connect the cable from dstv dish or any SP channel
Feb 22, 2015 | utube.com
My rca p52936 will not change channels. everything else seems to work.
First would be what kind of signal are you using? Direct cable to the set or what?
If only one channel does the number on screen change when you change channel but set stays on the last channel?
Also look to see if set on the front has the "Guide Plus" logo.
Jun 15, 2012 | Televison & Video
In just bought new Toshiba regza 40" Lcd tv and auto tuned it, but the picture is terible , snowy and colours are not good, what to do...
Hello
First of all reset the TV. for that
press and hold the POWER button
on the TV control panel for 5 or more seconds to reset the TV.
Then connect the TV tt any source like outdoor areiel or cable box etc, select the appropriate input, and retune the TV. First of all, connect it to an external antenna, and set it to autotune.
You must configure the ANT/CABLE input source before
programming channels (-left-hand column).
If the ANT/CABLE input signal type is set to Cable, the
automatic channel programming process erases channels
that were previously programmed into the TV's memory.
If the ANT/CABLE input signal type is set to Antenna, the
automatic channel programming process adds newly found
channels to the existing set of programmed channels (and
does NOT erase channels that were previously
programmed into the TV's memory.) To remove an Antenna
source channel from the memory, you must manually delete
it.
To tune the TV to a channel not programmed in the channel
memory, you must use the Channel Number buttons on the
remote control.
Programming channels when the ANT/CABLE input is
configured for Cable will take substantially longer than when
the antenna input is configured for Antenna. This is normal;
however, once channel programming is finished, you should
not have to repeat the programming process again unless
your Cable TV service lineup changes significantly.
Find out the received channels are clear or not. If they are clear, your TV is perfect, and the input device you connects ot the TV is faulty. OK.
Feb 16, 2011 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
I just bought the BenQ pq4242 LCD TV. I got it out of the box and WOW,,no cable connector in the back of the TV. How can I connect it? I will not buy an extra cable/coverter box to add to my brand new...
Hi, Actually Your OK. Not to Worry. BenQ is known for making good equipment. The configuration I give you will be an upgrade to the single cable coming from the box.
How do you solve the problem? There may have been other cables supplied with your set that
will connect to your box. If there is an RCA cable with 3 sections. Yellow Red and White. They go from the cable box straight into the set. Yellow is composite Video Signal without sound. Connect it to the Yellow output on the Box to the Yellow Input on the BenQ. The Red goes to the Right Channel Audio Output of the Cable box to the Right Channel Audio Input (also Red) on the Back of the BenQ. Finally the White Connector goes to the Left Channel Audio Output of the Box to the White Left Channel Audio Input on the BenQ. You will probably have a choice of "Video One or Video Two. I think Two should work with your configuration. When turning on the set set the input to whichever section 1 or 2 or 3 sometimes. And Everything should come up fine.
THIS IS BETTER QUALITY THAN YOU HAD BEFORE.
The set you now have is full High Definition. So if your box is unable to receive High Definition, you are missing out on HDTV. If you get a BluRay Disk Play, such as a Samsung or Sony (I recommend Samsung for reliability), You will be Thrilled with the Video Image. Your BenQ also has decent speaker outputs to connect bigger speakers.
I hope this has been a help.
Have a Happy New Year,
Best, Mark
Jan 01, 2011 | BenQ Televison & Video
I want to couple my DSTV Decoder through my new THT-3017HDMI Home Theatre System to the TV. How do I do that? I am very much technology disatvantaged.
THT-3017HDMI to hook with TV.
Get RCA Cables, red and white from your DSTV straight to your DVD.
The Yellow (Video) Straight from your DSTV to your TV yellow input.
Set your TV to Input 1 or 2 depending on the port you used. PLease but your volume will be only controlled via DVD, if you switch your TV off it will still sound the TV channels via DVD speakers,
Sep 03, 2010 | Televison & Video
Benq DC C500 : How do I get rid of the time/date on my pics?
There is an option in teh menu of the camera date imprint.Take it off.And thes is it!
Jan 26, 2008 | BenQ DC C500 Digital Camera
Everything is red.
Hi guys
The colour change can only be one of two things :
1. Faulty Cable
2. Faulty Mainboard
Must warn you that a Mainboard is quite expensive to have replaced.
Dec 27, 2007 | BenQ PB6100 Multimedia Projector
Repost: some channels missing.
try going as high as the channel will go taking time to see if there is a picture on each change
Dec 08, 2007 | Mitsubishi CS-27205 TV
HDTV Cable box conflict
This set does not support 480I in the DTV mode, only 480P and 1080I is supported. Try setting the analog setting in the cable box to 480p and that should take care of watching the set in DTV. Most cable boxes have a setting for format changes in the customer menu, depending on the type of box. If you are able to change the format, then the other inputs will not work since they need a 480I signal, as well as VCRs. Another setup could be to use the S-Video cable or Video input jacks to get a better picture in 480I instead of using the cable input. However, when changing from HD to Analog, you will have to change to the correct input on the set as well. Hope this helps.
Dec 24, 2006 | Samsung HCJ655W TV
23 people viewed this question
Top BenQ Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
