Question about Sewing Machines
I want to return to one finger screen touch - Sewing Machines
  • Sewing Machines Master
  • 1,388 Answers
Perhaps a little more detail would be helpful...
Posted on Apr 22, 2014
385 19000 touch screen is blank
There is probably an electronic problem with the circuit behind the knob.
Do you have a manual?
Kenmore 385 19000 Owner Manual
Feb 15, 2015 | Sewing Machines
Visual touch screen is blank for 1900 series embroidery machine
'm not technical so please bare with my terminology. There is an area soldered from the knob to the LCD Screen. Don't make the same mistake I did and turn it so much it breaks completely loose and connection is totally lost == my the knob fell down inside the machine. Sears said it would cost me $400 to fix because they would have to replace the whole LCD Screen. Turn your knob to where you get the best light and try taping it to the top or side of the sewing machine-- then don't touch it. Otherwise it will be costly to get fixed. Good luck
Feb 15, 2015 | Kenmore 19001
Bernina 165e: touchscreen is very hard to push (touch) sometimes takes 5 or 6 times to work
it would be a good idea to have the machine checked to see if
the circut board needs to be replaced.
Apr 25, 2013 | Sewing Machines
My touch screen on my Designer 1 is off-kilter. You touch to the right to get the left box to work. For example, if I use the first stitch I touch the second stitch. The touch also does not work well...
You need to access the SET menu. Try pushing to the right of this in various spots and hopefully you will be able to get in to this menu. Then you need to keep hitting More until you get to "Colour touch screen adjust" . Select this (by trial and error - keep touching to the right of the square until it is selected). Now get your stylus and carefully press it directly in the centre of the crosshatches - first the one marked "1" - it should turn green - then the one marked "2" - it too will turn green. Your screen is now re-calibrated and you should be able to push the buttons and get the correct selection. If not, I think the machine should be seen by a technician. There may be problems either with the screen or the motherboard.
Oct 13, 2010 | Husqvarna Designer I
How do you recalibrate the touch screen on the Quantum XL-1000?
Enter service mode....
Press the start/stop switch and hold it while you power the machine on.
THEN, press the reverse switch, hold it and press the lcd. Release the reverse switch AFTER you touch the LCD.
Nov 15, 2009 | Singer Quantum XL-1000 Computerized Sewing...
Husqvarna designer 1 won't turn on..stitching had messed up and cleared out bundled thread and now screen won't light up.
If there is no noise, like the machine is calibrating or setting up, then more than likely the fuse on the transformer has blown. If the needle motor and feed motor make their usual noise and the lights come on but the screen won't come on, chances are a connection inside the machine is your problem. If the cable from the display screen becomes unplugged, the machine will "start up" but nothing will be displayed on the panel. If when you turn on the machine, you touch the screen and hear the "click" sound the screen makes then its a problem with the display screen only. (there are 2 screens, the one you touch your finger with is the touch screen and the one behind it displaying the picture is the display screen.)
Oct 19, 2009 | Husqvarna Designer I
Am trying to change from light weight knit fabric on machine to light weight woven.push screen and it won't change . designer viking 1
It sounds like the screen has lost calibration. If you can get into "set" touch more until you see color touch screen adjust, then click on it. Click in the middle crosshairs next to the one, it should make a "click" and change colors, after that, do it to the crosshair next to the 2. touch "save". If you can't get the crosshairs to respond to your touchtry cleaning the entire machine and the screen with a static remover spray (NEVER SPRAY SCREEN DIRECTLY) spray your clean cotton cloth( eyeglass rag is awesome here) and wipe the machine down, then try again until successful. The company reccommends using a touch stylus in place of your finger to eliminate the transfer of static electricity to your machine
Hope this helps.
Kent
Mar 21, 2009 | Husqvarna Viking 1
Viking Designer 1 won't embroider
I have seen some of the older style machines that are very susceptible to static charge. Usually this doesn't happen with newer ones. If you get static shocks on door knobs in your house, do not touch the screen of your machine with your finger. Use a stylus instead. You may also try touching the metal presser bar just above the foot and ankle when sitting down at the machine prior to using the screen. This should not be happening with a new machine. Check with your dealer.
Nov 24, 2008 | Husqvarna Designer I
Touch Screen bad on a XL1000
I have posted the answer to this problem if the sceen is misaligned just turn off the machine and hold down the frist to buttons turn the machine back on the singer sceen shows up touch ithe sceen it should freeze and then a small black box should show up touch the box and it should move to a differant spot touch it four times and then rub you finger accross the stright stiche white button at the bottum of the sceen this saves the changes.
Nov 08, 2008 | Singer Quantum XL-1000 Computerized Sewing...
Sewing Machines Logo
12 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
