Question about ZT Group CISNET A7050 PC Desktop
Had to f10 system. now im missing a file and cannot re-boot. what can i do
    Problem Solver:
  • 7 Answers
You might need to reinstall your operating system. Since it wont boot there isn't much you can do.
The first thing I would do is put your pc diagnostics disc that came with your coputer into the drive and run a system diagnostic. It will most likely find the lost file and replace it.
If that wont work then you have to put your windows operating system disc into the conputer and go to your boot menu by hitting f8, f12, or f2 (depending on your pc) then you select boot from disc. This will wipe all the files on your computer which means you will have to reinstall everything. This sucks but its a guranteed fix as long as the reason your system wont boot is broken hardware.
Posted on Jun 19, 2009
NTLDR missing problem
NTLDR is one of the essential files for booting up your system. If this file is corrupt or missing the computer wont simply boot. The solution here is to Get the CD for your operating system. For example Windows XP or Windows 7 etc. If you are using Windows XP, put the CD in the CD ROM and press Del or F2 to get into the BIOS of the computer. Go to the Boot Order or Boot Sequence and select the CD drive to be the first boot device and press F10 to save and exit. This will allow the XP CD to boot. On the first page after loading all the files, press enter, then you will have to press F8 to accept the Microsoft license, then you can select "R" to repair the system (This will only overwrite the contents in the C:\Windows and this will fix up your start up problem. If you are using Windows 7, boot from the CD like in XP then choose to repair your system.
Feb 22, 2012 | Dell Computers & Internet
When pc is booting , fom begining , I have 3 options. F9 =boot device menu F10 =Rom base setup or F12=NTWORK service boot! Nether 3 work. Only erreor loading operating system! Wht can i do about it.
I think you need to re-install your os for some files that the Operating System need to boot properly is missing. First, run your xp or any operating system that your using and select repair. after doing this , booting problem will no longer be a problem to you my friend. Have a nice day and i was hoping this would solve your boot problem.
Aug 17, 2011 | Computers & Internet
My bootmgr is missing on Acer Aspire 7736z. It is not allowing me to boot in safe mode(f8) or alt f10. How can this be fixed?
Unfortunately you have to reinstall the operating system. It's the best solution.
If I could be of further assistance, let meknow.
Mar 26, 2011 | Computers & Internet
Hello, i have a acer aspire 6920g and it doesn't start up it does come up with stuff but it says, Windows could not start because the following file is missing or corrupt...
You could use the repair feature on the recovery partition, when booting up press F11 and that should take you into it, just choose "repair" and this should replace the missing file/s.
If F11 does not work try ALT + F10 when booting up.
Hope this helps
Mar 19, 2011 | Computers & Internet
My computer can not start. Message: \WINDOWS\SYSTEM32\CONFING\SYSTEM file is missing or corrupted. Kindly assist. Thanks.
You need windows CD for this problem to go away
as it clearly states that your windows system file is missing or corrupt
so borrow a windows CD from some one and put it in your CD ROM
then press F10 to get into bios and under advanced boot priority change your first option to CD and restart ,it will ask to boot from CD,press enter and follow on screen instructions
it will ask to reinstall windows or repair,choose repair option and it will repair all the windows files and your system will be fine again
Aug 02, 2010 | Computers & Internet
Hal error how do i fix without a backup?
Your Hal or boot.ini files are missing/moved/corrupted. Perform a repair installation of Windows XP. If unsucessful, do a fresh install. Try pressing ALT+F10 during boot to access the recovery partition. This will return your system to the day it was new - yes, all files you have will be lost.
Jun 26, 2010 | Acer Aspire One PC Notebook
My pc will not startup when i turn on it appears it crashed i have boot cd that i created. i tried to repair and it will not. im not sure if im doing it right.. i have windows xp.. the original error it...
Hello, Trace.
Here's some help regarding fixing this error. From HP Support:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&dlc=&product=89876&docname=c00188632
If you are still experiencing a problem, your created boot CD is probably faulty.
If it still is not working, depending on your hardware manufacturer, you may be able to access/run Factory Restore. Boot your system and press F10, F11, Alt+F10, or Ctrl+F11 to access Factory Restore. Please note that Factory Restore restores to the original settings and will wipe out anything that you have installed or saved on your PC.
Hope this helps.
Jan 23, 2010 | Computers & Internet
My system won't boot because the windows\system32\config\system
If i am from Singnet technical Helpdesk, we are advised to direct you to Acer Service centre if you owned an Acer computer with a serial number and if it is still under the warranty period on Operating system missing, Another option is to contact Microsoft service centre for CD replacement or oprating system advise since they are the suppliers and vendors for fathering the operating system, To troubleshoot your missing files,you need to know pecifically which files are missing and are they registered in your O/S and are they active and running or are they deactivated, takes longer time to solve missing files problems because you did not list what files are missing and you need to tell microsoft what files are missing in our operating system as there are thousand of files in the WIndows operating system
Jul 23, 2009 | Acer Aspire One AOA150-1983 Notebook PC
MY laptop will not boot-up. I turn it on and all I get is a blank screen
try it in safe mode, (press F8 while its booting up) and select last known good configuration, if it doesnt start, turn it off then the F8 again but use safe mode; if it boots into windows you have a corupt driver, so run a system restore to the last saved point
If nothing works your boot.ini system file is missing and you will either have to use the recovery programme either F11 on boot up or Alt & F10 depending on model, but all your files will be lost and the system will be as new.
Sep 07, 2008 | Computers & Internet
ZT Group CISNET A7050 PC Desktop Logo
135 people viewed this question
Top ZT Group Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
Jose Pino
mukhtar21 shaikh
mukhtar21 shaikh
Are you a ZT Group Computer and Internet Expert? Answer questions, earn points and help others
