My samsung ps-42d5sd switches itself off and on repeatedly
    Top Expert:
  • Televison & ... Master
  • 74,251 Answers
Shorted component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Posted on Apr 20, 2014
I have a Samsung Plasma PN63A650 that has worked 4 8 years, until today. I turned it on, stays on for 14 seconds, then turns off for 8 seconds. Would not respond to remote commands either
Easy fix for new Samsung TV switching on and off power ...
? 4:41
https://www.youtube.com/watch?v=H0cG3lzjuw8
Sep 15, 2012 - Uploaded by alwaysafix
My tv turns on and off by itself the minute I plug in the cable. ....Samsung E6030 led tv hv blinkin red light issue ... capacitors are looking good ...
Help PLEASE! Samsung Plasma Turning On/Off Repeatedly.
michiganstate.247sports.com > Topics
247Sports.comMy Samsung Plasma HDTV (approx 3.5years old) has some issues as of late. When Iturn the tv on, invariably, it starts to turn off and back on repeatedly.
Samsung Smart TV turning off - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - I have a Samsung plasma 60 inch model number PN60E6500EFXZA TV. It began to turn itself off every 5 minutes, for the past few days. I was able to factory ... Samsung TV Keeps turning off and on.
Jun 11, 2015
Samsung TV Keeps Shutting Down
Jun 11, 2015
Samsung Plasma TV turns off by itself
Jun 22, 2011
My Samsung 50 in PN50B650 turns off by itself then on again ...
Apr 30, 2010
More results from www.cnet.com
Jan 13, 2016 | Samsung Televison & Video
Samsung PS-42D5SD rotating through channels and will not allow me to choose Ext1, Ext2, HDMI, Etc.
make sure that you have something connected to those inputs that you are trying to use
Feb 25, 2014 | Televison & Video
My samsung b2100 repeatedly switches itself off and immediately back on but ONLY when i am using it
your battery has most likely gone wrong you should tttry buying a new one . That should do the trick ;)
Jul 09, 2011 | Samsung Cell Phones
Hi, after aprx 1.5hrs of playing a dvd the home theatre system switches off, i then turn it back on and then aprx 1hr later after playing a dvd it switches back off, i repeat the steps above and the time...
Sounds like you have a cold solder connection somewhere on the main board or power supply. It opens when the junction begins to heat up after prolong use. It probably corrects itself when the unit is cold and the junction re-connects. Your best remedy is to inspect the boards and try to locate the bad solder connection. You can do this, but please be careful when working on live circuits, by using a non-conductive pointed tool and poke at suspected joints on the circuit board - if the unit begins to work again, Bingo, you found the problem. Good-luck!
Dec 16, 2010 | Samsung HT-X250T Theater System
Tv keeps shutting off and going back on by itself
Cold solder joint in the power-supply board, once it heats up it expands and shuts off. Open it up and start scanning the board for defects and hit them with a hot soldering iron and a dab of solder.
Cheers
May 05, 2010 | Samsung LN-S4051D 40 in. LCD Television
Tv switches itself on and off it just clicks on
If you haven't tried already, replace the lamp. This is the first suspect in issues like this.
Nov 03, 2009 | Samsung DLP HL-P5663W 56" TV
No picture
Common faults that give you no picture and sound on Plasma are often related to Sustain board, buffer and cables problem.
In this case the cost will be affordable, ans surely worth.
In the unlikely eventuality that instead you have a faulty plasma screen , or a faulty digital control board (main board), the cost of repair may be high.
The only way to find out is by having the TV inspected by a technician.
The most common fault that gives you no picture and sound on plasma is Sustain board , lower buffer, or connector, that is repairable.
Jan 05, 2009 | Televison & Video
SAMSUNG 50" Switches off with beep-beep
the problems capacitors try to look the 315v/10uf
Sep 19, 2007 | Samsung HLR5067WX 50" Rear Projection HDTV
Samsung DLP HL-P5063W. . .no lamp!
You will need to have it diagnosed if you do not have the service manual, or the knowledge of how these circuits work. I can tell you to replace this or that but it would be a guess! You need to start measuring the voltages on the ballast circuit, as I have seen door switches, fan sensors, heat sensors cause all of your symptoms as well. Good Luck
Jul 24, 2007 | Samsung DLP HL-P4663W 46" Rear Projection...
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
Electro Med Services...
