Question about Kenmore Side by Side Refrigerator
Refrigerator Rattles New Kenmore frig rattles/knocks when closing doors. It is level, pulled away from wall, and contents readjusted.
    Sergeant:
  • 268 Answers
Perhaps some of the shipping blocks are still on the compressor or other parts.
Posted on Apr 20, 2014
  • Lyngal
    Lyngal Apr 27, 2014
    Service tech came, said the coolent in the frig wall is loose and I should call for a replacement.This will be the second replacemet! Sure hope nothing is wrong with the third one, I probably won't buy from Sears again after going through all the problems I've had with them.
Sea Breeze
  • 4654 Answers
SOURCE: Kenmore Frig-bottom freezer/freezer door pops open
Replace a door gasket on a refrigerator....
Replace a door gasket on a refrigerator: The first thing to do when changing a door gasket is to check and see if you have the proper part before taking the old gasket off. Hold the new gasket up to the fridge door to make sure the gasket is the same size as the old one. Next step is to remove the wrinkles in the gasket caused by folding for shipping. Instructions with the gaskets say to soak the gasket in hot water. Another way is to use a hair dryer to heat the gasket and remove the wrinkles. Be careful not to burn the gasket with the hair dryer. Almost all gaskets in use today are magnetic. I am placing instructions here for the most common one. They have strips of magnetized material inside the gasket material to adhere to the cabinet when the door is closed. Therefore there is sometimes no up or down on the gasket. Some fridge's have magnets on only 3 sides and the side without a magnet is the hinge side gasket. But to be safe, check this before installing. You will certainly want to check for this on older refrigerators that have magnetic door latches. Some of these have no magnets on the latch side of the gasket. There are about three different ways of attaching gaskets. All will be addressed on this page. Remove the food from the shelves on the door. Loosen the screws that hold the metal strips that keep gasket in place on the top half of the door. Back the screws out about 1/4 inch. The gasket has a lip on it that seats in a groove under the top part of the metal strip. Pull the old gasket off. Work the groove on back side of the new gasket under the cutout in the metal strips that holds it on the door liner. Straighten and get good install before tightening screws. Run screws back up against the metal holding strip snugly, not fully tight. Go to the bottom and do the bottom half. By doing the top half first and tightening, then doing the bottom half, you will minimize any warping of the door. If there is warping of the door, we have not yet fully tightened the screws. so you can realign the door easily and then tighten the screws. Check the alignment of the door and be sure the gasket is sealing properly before fully tightening the screws. If the door is warped, (see picture) simply warp it back to a sealing position, then tighten the screws. There are instances where the gasket is too tight on the hinge side, and you may have to shim the door hinges out from the cabinet to keep the gasket from scrubbing when closing. .also use a little petroleum jelly on the gasket on the hinge side will allow the gasket to "settle" better. The hinge side must slide along the cabinet edge while the other 3 sides just close up against the cabinet. The jelly will allow the gasket to rub smoothly and also prevent squeaking noises. Maintenance of the gasket is important also. It should be cleaned on a regular basis. Clean the gasket and the mating cabinet surface with warm soapy water, rinse clean and dry it good. Putting a little baby powder on the sides (except the hinge side because we put the jelly there) will prevent the gasket from sticking and tearing. The heaters in the refrigerator used to keep moisture from forming on the cabinet attracts airborne materials and make the gasket sealing surfaces sticky. The powder will help stop this. Probably 75% of the fridge's made a few years ago use this edge under the metal track....some American made fridge's use the U shaped metal strip and the gasket pushes into the metal strip, (see a picture) the screws that hold this metal strip do not have to be removed or loosened. A lot of fridge's also use the metal strips with out the edge. Some Maytag's and Woods come to mind. The screws go through the metal strip and the gasket as well. The screws have to be removed completely to replace the gasket.
Gasket sheet to assist you in replacing a common door gasket.
Freezer door pops open when I shut the fresh food door:
This happens because the refrigerators of today are air tight, the fresh food door pushes the air into the cabinet as it closes and the air has no place to go but up the air vent into the freezer and "pops" open the freezer door. First thing is make sure the freezer door is capable of closing properly and is not rubbing or catching anywhere. I sometimes add a washer or 2 to the center hinge under the freezer door so it doesn't rub anything. Put a little Vaseline ( or food grade silicone lubricant ) on the hinge side of the seal. I then raise the front of the refrigerator so that the front of the refrigerator is a little higher than the back of the refrigerator. Never level a fridge with a level. Once you have the door closing properly and front slightly higher than the back...let the fresh food door close from 90 degrees on it's own and the freezer door may "pop" open a little but will close again on it's own...and stay closed once all is set up properly. We see this more often now and have no trouble with the door staying open again after setting up the refrigerator properly.
I hope this helps, and if you need more information On solutions just let me know, Thanks Sea Breeze
Posted on Feb 06, 2009
SOURCE: Kenmor frig not getting cold
same problem then suddenly would not shut off, kept running. found out it was the thermo couple as well as the timer.
Posted on Aug 12, 2008
  • 12 Answers
SOURCE: Kenmore - over under
Adjust the feet to raise the front of the frige, which should be higher than the back. Therefore the weight of the door will keep it shut or at least cause it to shut itself if it pops open.
Posted on Oct 05, 2008
SOURCE: Kenmore refrigerator door will not close completely
Both top and bottom doors will not close on mine
Posted on Feb 19, 2009
SOURCE: Kenmore side by side refrigerator Ice maker not working
Found out we still had a warranty/service contract on it. Contacted SEARs and I explained problem to technician. Scheduled house call is Friday.
Posted on Apr 16, 2009
When we open the doors the refrigerator moves
According to how it's moving "away from the wall"; the most likely culprit is balance issues. Does the unit move easily? Is the unit level?
Jul 25, 2014 | Kenmore Refrigerators
New Kenmore Frig Rattles/Knocks
If it is new i would call the dealer and have him set an appointment to have a servicer check it out. If it is under warranty.
Apr 20, 2014 | Kenmore Side by Side Refrigerator
The washing Machine knocks during spinning
Easy fix: Readjust the riser supports and level the washer. Some washers have adjustable feet that screw up and down. Put a level across the top of the washer and when it is level front and back, the legs are in the correct position. Some units have auto-level adjustment meaning you have to pull your washer forward and bounce it gently back toward the wall and lift the Front in the same fashion. In some cases side to side adjustment by lifting one side up and then the other can do the same thing in adjusting the levels. Either way you must LEVEL the washer in order to STOP the rattle or bounce.
Dec 14, 2013 | Whirlpool Washing Machines
I get a constant rattling noise out of the back of the regrigerator, UNLESS the freezer drawer is open, then it stops instantly
From your description it must be the drawer that is rattling against a wall or shelf. You may have bent something or lost a damper. Openclose it to see at what level it rattles, then see if you can tape a piece of sponge where it hits against something.
Mar 18, 2011 | Kenmore 73502 / 73504 / 73509 Bottom...
We purchased a new KitchenAid Side by Side Refrigerator Model # KSRG25FVBL01 that makes a loud knocking noise accompanied by rattling from the date we purchsed. We are getting runaround in getting it fixed...
The knocking noises heard from the Freon moving through the sealed system are perfectly normal and usually do not last long. Since the evaporator coil is mounted in the freezer section, the noise is usually louder there. Some people say it sounds like marbles knocking together.
Refrigerant (Freon) moving through the system can cause a vibration/rattling, especially as the compressor first starts up.
  1. Vibrating from top of cabinet Remove, rearrange or pad any stored items atop the refrigerator such as houseplants, coins, pens, etc.
  2. Vibrating from back or sides of refrigerator Move refrigerator away from water line in the rear or away from walls / cabinets along the side of the cabinet. Refrigerators with a static condenser on the back require a rear clearance of 3 inches across the top of the condenser.
  3. Vibrating from the bottom of refrigerator Level refrigerator so all 4 rollers / feet rest solidly on the floor.
    Hope this works.....
May 01, 2010 | KitchenAid (KSRD22FKST) Side by Side...
Knocking noise
Sometimes when it's to close to the wall it will make noises try pulling it out a bit.
Apr 25, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Duet Washer rattles and knocks when spinning
you either have a broken shock or the spider gear is gone,take off the bottom panel and check out the shocks,if it's the spider gear it's time for new washer,it's around 500 bucks for new gear,to much detergent used over the years eats at the metal
Jan 23, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Refrigerator not cold
first check your damper door from the freezer to the refrigerator compartment make sure its in the proper position. Then turn off the refrigerator for a few hours until the heavy frost melts away. turn on the refrigerator check the refrigeration cycle, is it working properly, is it going into defrost are the defrost heaters working.
Feb 21, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore doors getting air vaccum and will not open right away
  • that is just a sign of a very cold freezer and a good sealed refrigerator.
  • if you don't like it then turn your freezer down so it wont get so cold.
Jun 29, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore Side by Side Refrigerator Logo
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
