Question about AEG U3100-4 Electric Double Oven
Oven trips RCD
I've changed the bottom oven element but it lasted for around 15mins and trips the house RCD, this has been deteriorating over the past few years I've replaced the element a number of times but never straight away. Could this be anything else loose element clips when it heats up?
  • Dan Hobson
    Dan Hobson Apr 20, 2014
    Apologies the oven model is U7101-4-M
2 Suggested Answers
  • 1462 Answers
SOURCE: Main oven problem
I suspect not the oven element at fault. you only way forward is to actually test the resistance of the element to earth with a megga if you can beg the use of one. be cautious about the result as on occasion, elements are only faulty to earth when hot. another way to test if you are cdarefull, is to connect the element to mains independently of the oven and see if the rcd trips
Posted on Sep 22, 2008
Neff U1422 bottom element faulty, is it needed?
the only problem might be hat the oven will not come up to proper temp with out that element .
Oct 16, 2015 | Neff Ovens
I have a eurolec double built under oven. When I turn the bottom oven on the rcd at the house consumer unit pops. The top oven works fine...
The elements in ovens consist of an outer earthed metal tube and an inner resistive element that is insulated from the outer tube by what is effectively a compressed ceramic insulating powder. If the element is not used for a while, enough atmospheric moisture, (or from spills, etc), can penetrate the insulation to cause enough earth leakage to trip the RCD. If the RCD is tripping at the correct level, (They can get too sensitive - see this article here:
Diagnosing RCD earth leakage breaker nuisance trips), then the only long term solution is to replace the element, although they can sometimes be dried out by heating them.
Aug 11, 2014 | Ovens
Kenmore duel fuel oven wont heat
I take it this will be an electric oven. If so the likely hood is that the oven element has blown and will need replacing. Normally when elements short they will trip the houses RCD (once only normally)
Apr 10, 2014 | Ovens
Lower oven loss of power
I'd check the control switch first, and the wireing and connections.
Sep 05, 2012 | Ovens
I recently bought a new house with fitted kitchen containing a fitted Diplomat double oven. When the power is on but both ovens off the Amber light above the top oven mode selector glows dimly. When I...
I'm not sure its been connected properly, needs checking out by someone who know's what they're doing. Be careful, the fuse doesn't trip for nothing.
Jul 09, 2010 | Ovens
Keeps tripping out rcd 63 amps when warming up after about 10 minutes
If your oven is rated above 14kw then change the RCD to 80A. But if its rated less than this then please check shorted element and change them
Jun 18, 2010 | Neff U1721 Double circotherm Electric Oven
Siemens oven tripping RCD
We need wiring diagram for HB905 Siemens double oven, to start with it kept tripping, element ok. Now we have no heat coming from the main oven.
May 02, 2009 | Siemens Ovens
Not heating up
Hi.
I suspect you may have a faulty oven element, which is breaking down as it gets hotter, disconnect element and try if ,if it does not trip, then element is faulty
Nov 20, 2008 | AEG U7101-4 Electric Double Oven
Main oven problem
Sep 22, 2008 | AEG U3100-4 Electric Double Oven
AEG U3100-4 Electric Double Oven Logo
209 people viewed this question
Top AEG Ovens Experts
ashburton
Sal De
Steve
Are you an AEG Oven Expert? Answer questions, earn points and help others
