My jacuzzi platinum series control panel is in lock mode (economy) I dont know how to reset it
  • 10865 Answers
SOURCE: cannot unlock oven frigidaire electrolux gallery series
hello. this is a common problem. here is a link to provide you with an owner manual which explains how to use the self-clean function
http://www.frigidaire.com/manuals.aspx
and here is a link to speak directly to the folks at frigidaire who will talk you through the solution to your problem
http://www.frigidaire.com/contactus.aspx
let me know how u make out with this as I can offer additional help if needed.
Posted on May 28, 2009
  • 3 Answers
SOURCE: US ROBOTICS 9106- Reset not working. Bridge mode
My USR8054 has a default ip of 192.168.123.254, not 192.168.1.1. Also, the login default is admin with no password.
Try that.
Posted on Dec 16, 2009
bigguy810
  • 448 Answers
SOURCE: Kitchenaid Electric Range Architect Series
first go down and check your curcuit breakers this is a 220 volt oven when you use the self cleaning
it gets so hot that it Burns every thing that was inside if the circuit breakers are not rated for
this unit it will kick them out the breaker is going to be a double breaker.
if all is ok with the breakers than check the plug if all is ok there then i would lean towards the
control panel
hope this helps you
good luck
bob
Posted on May 12, 2011
  • 2330 Answers
SOURCE: self cleaning mode door will
what is the model number off of the machine,open the bottom draw,look around the frame not the draw and you'll see a tag with the model and serial numbers,just need the model number,there's a door lock motor that could be bad,i can look it up for you,i don't understand what you wrote,what did the tech tell you?
Posted on May 15, 2011
  • 963 Answers
SOURCE: how to reset a 7000 series lock
Go to this web page:
http://www.kaba-ilco.com/kaba-access-control/Literature-Support/292720/simplex-mechanical-pushbutton-locks.html
To download the instructions, go to to 7000 on the chart, and under the TIPS column, click on PDF
This will download a PDF file of the instructions for you to open.
A note about PDF files: If you cannot view a given file, you need to first install Adobe Reader. You can get the free download here:
http://get.adobe.com/reader/
Posted on Apr 12, 2012
Why is hot tub over-heating past max temperature?
Sounds like a problem with the thermostat.
Aug 05, 2014 | Jacuzzi Home
How do you get it off economy mode
there is a MODE/PROG button on the panel. this buttom switches the unit between the modes.
Press it and it will cycle thru from Standard to economy.
It's on page 5 of the manual... and you can download it from http://www.qcaspas.com/content/pdf/Majestic-10Btn.pdf if this is your unit
Jun 29, 2014 | Qca Spas Dream Series Dream Master Hot Tub...
Hot tub in EC with light flashing
Ecn or Ec Message
Ecn or Ec Message
If the Ecn or Ec Message is Alternating with the Water Temperature on the Display, the Spa is Operating in the Economy Heating Mode.
If the Ecn or Ec Message is ON Solid (Not Flashing) on the Display, the Spa is Operating in the Economy Heating Mode, but there is No current water temperature because the Spa is between Filter Cycles.
Ecn or Ec is Alternating with Temp:
The Spa is Operating in the "Economy" (Ecn or Ec) Heating Mode.
The Water Temperature is Sampled Only during Programmed Filter Cycles. The Heater will Only operate and Heat up to Set Temperature during the Filter Cycles. The Water Temperature will probably drop Below Set Temperature between Filter Cycles. Other Heating Modes are Standard, Standard in Economy, and Sleep Modes.
Ecn or Ec is ON Solid (Not Flashing):
The Current Water Temperature is "Unknown" (- - - or - -) while in Economy or Sleep Mode.
Between Filter Cycles, while in the Economy or Sleep Heating Modes, the Pump has not turned ON and the Last Water Temperature is not Current. To read the Current Water Temperature, either Change to Standard Heating Mode or turn On the Heating Related Pump, and wait at least 2 Minutes.
Dec 23, 2012 | Jacuzzi Balboa R574 System for 1 2 Speed...
Can't unlock jacuzzi hot tub control panel
control panel not working, cannot control or work control buttons, stays in econ mode all the time. Nothing else works.
Nov 27, 2010 | Jacuzzi Pool & Spa
Hot tub stuck in 'SL' mode
Need to know what buttons your topside control has... depending on the model, some have a mode button which you press and release and then immediately press the temp up or down, to select SL for sleep (no heat), ST for standard (heat as needed) or EC for Economy (only heat during filtration). If the mode button is not present, and you have a single temp button and light button, try pressing and releasing temp and then immediately pressing light button, repeat until choice appears, then wait, it will hold last displayed mode.
Jul 09, 2010 | Jacuzzi Balboa R574 System for 1 2 Speed...
We have a 1997 or 1998 beachcomber hot tub, digital 3000 and the control panel seems to be locked on economy and we just can't get it unlocked. We've tried following the steps the instructions give us but...
I have a 1997 beachcomber tub w/ digital 3000 which was locked in economy and temp said 80*. i check solded joints and they were ok, i replaced the main board and it work fine now.
Jun 01, 2010 | Jacuzzi Pool & Spa
WHAT IS THE MODE BUTTON FOR?
EC stands for Economy. Change the mode until you reach ST and then it will stop flashing and function as normal.
Economy mode only allows the heater to function when the hot tub is on its filtration cycle.
Regards,
Ian.
http://hottub.synthasite.com
Jan 04, 2009 | Jacuzzi Balboa R574 System for 1 2 Speed...
Washing Machines Logo
18 people viewed this question
Top Washing Machines Experts
