Question about Maytag Bravos MTW6600T Top Load Washer
Maytag Bravos MVWB300WQ1. While sitting idle I heard a click and now the machine will not turn on plus it popped the circuit main circuit breaker.
  • 101 Answers
The clicking sound may have been insulation / plastic in one of the electrical components cooling down after failure. The problem is more than likely the motor or lid switch. If you are capable, remove motor wires / plug, insulated same, plug into the power, turn on & see if it trips the circuit breaker. if it does not it is the motor, if it still trips check other electrical components.
Posted on Apr 21, 2014
3 Suggested Answers
  • 58 Answers
SOURCE: I have loaded my Maytag Bravos and all the lights blink
Check door switch wiring or door switch or control board
Posted on Mar 09, 2010
kdrake84
  • 262 Answers
SOURCE: how do I lift the
The link listed below will show you a diagram of your units Motor basket and lid parts.
Click on the link http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Washer-Parts/Model-MVWB300WQ1/3048/0153200/W1003175/00003?blt=06&prst=0&shdMod=MVWB300WQ1
As you can see (click on view full size) part number 6 (impellar or agitator) is held down by only a bolt,part number 2 and a washer part number 3.
Simply remove the bolt and remove the impellar (agitatior)
If you have any other questions or concerns please post.
If this information helped you please consider giving us a 4 thumbs up for our rating.
Thanks in advance and Thank You for using FixYa!
Keith
Posted on Feb 20, 2011
What would cause my Bravos washer not to power up when breaker is not tripped.
How to get codes from a Maytag Bravo X washer - YouTube
? 2:41
https://www.youtube.com/watch?v=C_MfPBM8Dy4
May 10, 2013 - Uploaded by 52SCHUELKE
I had some problem with my Maytag washer and couldn't find any info on how to fix it. ... Up Next. Maytag ...
maytag washer bravos will not turn on ' ShopYourW
Nov 20, 2015 | Washing Machines
Maytag bravos mvwx500xw0 has no power after closing lid
You should hear a click just before the lid closes and a click just after it opens. If no click, check lid switch and it's actuator.
Jan 12, 2013 | Maytag MVWX500XL High-Efficiency Bravos X...
Loud pop while fixing a light and now the light wont go back on
More than likely tripped the circuit breaker for that circuit in the main breaker panel. I would check they should be labled for which one controls the lights for that room. Just turn it off and back on to reset the breaker switch.
Dec 16, 2012 | Televison & Video
Maytag bravos will turn on; totally dead, its plugged in properly and breaker is connected
Bravos dryer picture
Bravos service manual
A lot of these are malfunctioning due to the small belt and pulley that drives the blower falls off. It is recommend lock tite on the nut will fix the problem.
Sep 22, 2012 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Does this Maytag Bravos electric dryer require more power? I.e., new dryer blows circuit breaker multiple times during a load. Have used electric dryers on this circuit for many years and have not had this...
Assuming that your house is wired correctly, if the plug will physically fit into the outlet, then the outlet is capable of driving the appliance properly. A breaker for a dryer should be rated at 30 amperes. The breaker itself could be going bad (they tend to fail to the off position).
Your best bet is to actually use an amp meter to measure the current it draws.
If you discover that someone wired your dryer with a 2 pole 20 amp breaker, then make sure the wire itself is 10 AWG before replacing it with a 2 pole 30.
:o)
Jun 03, 2011 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
My bravo steam dryer is showing an F1 code, and I can't get it to start
this is a control board issue, you may be able to clear the fault using these steps:
1) Unplug or turn the circuit breaker off for 30 seconds.
2) Plug the dryer back in or turn the breaker back on.
3) Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
4) Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
If it will not clear then you will need to replace the control board, Good Luck Tim
Mar 05, 2011 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
My maytag glass lid shattered and I need to find A replacement and how to install
Unplug the machine. Pop the top using a putty knife to release spring clips between the top and front panel. Remove the hinge screws with phillips head screwdriver, pull the hinge straight out as seen on page 49 of this Maytag Bravos Service Manual
Jun 27, 2010 | Maytag Bravos MTW6600T Top Load Washer
My Maytag Bravo Steam Dryer runs for about 5 minutes and gets hot and then kicks the breaker in the breaker box. HELP!!
Hello there:
It blows fuses or trips the circuit breaker Electric dryers use 220 volts or two power lines of 110 volts each. Some components in the dryer need only 110 volts; the heating element requires 220 volts. So it's possible for one part of the dryer to be fine and another part to have a short circuit. Short circuits can be caused by the heating element, the main power cord, or any other part of the internal wiring. To decide where the problem lies, unplug the dryer, then:It could be also wired backwardes so make sure to have this checked'
If the circuit breakers or fuses remain on and/or intact when the dryer is unplugged, it's likely the problem is with the dryer. Contact a qualified appliance repair technician. If the circuit breaker trips or the fuse blows when the dryer is unplugged, it's likely the problem is with the house wiring, fuse box, or circuit box.
May 21, 2010 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Mar 09, 2010 | Maytag Bravos MTW6600T Top Load Washer
No electrical power
You must find the reason the main breaker is popping ...
I'd start by unplugging everything and remove all breakers. Turn the main on ... does it pop? If it pops here look between the breaker panel and the end of your cord. Turn the power off - reinstall the first breaker - turn power back on. What happens ... keep doing this until the main or individual breaker pops - investigate that circuit to find your short.
If you get all breakers back in with out popping anything ... start plugging stuff back in. Something is shorting somewhere.
Let me know what you find please.
thanks
a
Oct 06, 2009 | Hilltop Rv 60 AMP CIRCUIT BREAKER CARDED
Maytag Bravos MTW6600T Top Load Washer Logo
82 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
