Question about Sony STR-DE945 Receiver
Sony str-de945 s.1 rear speakers not working
All speakers work, except the rear spaeakers. Disconnected, reconnected, no luck
    New Friend:
  • 21 Answers
Rear speakers may only work once you have a 5.1 or DTS signal source connected
Posted on May 15, 2014
  • 231 Answers
SOURCE: rear speakers not working
  • Try this on your rceiver to see if it corrects your problem .If not make sure rear speakers are activated and properly connected
  • Sound Field Clear Mode
    The preset sound field is cleared when this mode is activated. Use
    this mode before returning the product to clients upon completion
    of repair.
    Procedure:
    1. While depressing the [MODE +] button, press the power `/1
    button to turn on the main power. The message S.F Initialize
    appears and initialization is performed.
Posted on Dec 05, 2007
SOURCE: rear speakers not working on STR-K740P
The only way your surround sound will work is if you have either the coaxial or fiber optic digital hookups attached to a PS3/Blueray/DVD/Cable box/Satellite box that have digital sound outputs. If you are just using the 1970's version of the red/white audio cables that is stero only.
Posted on Apr 11, 2008
marsrover
  • 682 Answers
SOURCE: STR--DG910: no rear speaker sound, no center speaker sound
if you confirmed all connection repeat your speaker setup.
Posted on Aug 02, 2008
SOURCE: No sound from rear speakers during test tone usng Sony STR-DE475
I had this problem last night.
To solve it, you can reset the amp by:
1) Put the receiver on stand-by
2) Hold down "MODE" button and press on button
3) "S.F. CLR" appears in the display and surround is back on.
Good luck
Dr Gardner
Posted on Feb 10, 2009
SOURCE: Speakers pop and rear speakers cut out of surround sound
your problem is a bad solder connection of the relay linked to the lautspeaker sockets. I had the same problem and googled for the solution. Since I resoldered the pins everything is fine. That problem is well known and happens to a lot of Sony receivers.
I can send you a link with a detailed how-to-do solution with pictures, however it's written in german language. But you can use some online translators.
Here is the link: http://www.bmw-syndikat.de/bmwsyndikatforum/topic.asp?TOPIC_ID=28280&FORUM_ID=20&CAT_ID=9&Forum_Title=Geplaudere&Topic_Title=Problem+Sony+STR-DE445
Ralf (from Germany)
Posted on Feb 15, 2009
I have a Sony STR-DE845 receiver. The rear
Something is heating up to a point that it fails in the rear amplifier section. take it to a tech.
Jan 01, 2010 | Sony STR-DE845 Receiver
Sony STR DE845: rear speakers not working, three fronts are OK.
The rear amp is malfunctioning (duh). Take it to a tech for a real diagnosis.
Sep 05, 2009 | Sony STR-DE845 Receiver
My sony str de605 am/fm reciever flashes "Protector", is there something I need to replace internally?
Hiya, not sure if i remember correctly but try reset it. First disconnect the speakers (make sure error isnt there)
When it is ON, press and hold the power button for about 4 seconds. It should then ask reset, clear or something and press enter. When its finished, try it again. If ok, reconnect speakers. If it happens with speakers, there is a problem. If it doesnt work and goes straight back to protect, then there is an internal fault (if i have the reset procedure correct)
Best of luck
Jul 16, 2009 | Sony STR-D700SS Shelf System
Sony STR-DE635, Sound from left surround speaker but not right
first turn the actual volume up on that channel on the reciver then make sure your speaker wires in the rear are using the same lenght each
May 18, 2009 | Sony STR-DE635 Receiver
Good luck
Dr Gardner
Jan 21, 2009 | Sony STR-DE475 Receiver
Rear speakers not working on STR-K740P
Mar 02, 2008 | Sony STR-DE625
    of repair.
    Procedure:
Dec 05, 2007 | Sony STR-DB940 Receiver
Surrond Sound Rear spaeakers
yeh i get the same problem.. i have 5 speakers hooked up to my str- de475 and cannot get sound from my sl/sr speakers its a nightmare aint it? why is there no soloutions on the net for?
Jan 16, 2007 | Sony STR-DE475 Receiver
No output on main speakers
I have experienced a similar problem with my Sony STR-GX57ES and took it to a certified tech only to find it needed the power supply replaced. I opted to hunt down a compatible power supply but have been unsucessful thus far. That being said I picked up an STR-D665 for next to nothing and found the power supplies to be quite different (you would hope so any, with the ES meaning Elivated Standard and all) but with the D665 working flawlessly I'd rather have something working than nothing. Good luck!
Dec 06, 2006 | Sony STR-D665 Receiver
Sony STR-DE945 Receiver Logo
119 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
