Question about Samsung HTE6500/ZA
Cannot turn on
Hello I cannot turn on the bluray. I mean i have to unplug it,then i can turn on but no button responds. when i turn it off,the tube stays on and the display says off.i have to unplg it to reset,but cannot open tray.
Nothing when turned on, unplugged overnight, got light blue screen and voice ?
Search Results
    If Samsung Bluray keeps turning off and on, I have a fix - Forums ...
    www.cnet.com > Forums > Samsung
    CNETJun 11, 2015 - If your Samsung Bluray keeps turning off and on by itself and will not stay on, I have ... (DVD plays fine on the POS Vizio 3D BD player I have (that came in a ... After leaving it unplugged overnight, when first plugged in, it immediately turnsitself on, ... Saw your fix, but i assumed you're an internet troll with nothing better to do ... Samsung Blu-Ray cannot stream Netflix
    Jun 11, 2015
    HDMI Input Issue - Only One Port Working
    Jun 11, 2015
    Smart hub not connecting to the internet
    Aug 22, 2011
    More results from www.cnet.com
Dec 28, 2015 | Televison & Video
Dvd stuck in Samsung bluray
Have you tried pulling the plug for a minute? Also try the eject button directly from standby.
Nov 26, 2013 | Samsung BD-F5100 - Blu-ray disc player
Stays in stand by
Meaning it won't turn on? does it respond to the remote yet fail to turn on? will it turn on if you press the channel button on the tv itself?
There could be a problem with the power board. These are usual pretty cheap to fix.
Jan 04, 2013 | Emerson LC320EM2 32" LCD HD Television
Player turns on ok,display shows menu that disc is playing but tv says there is no signal, not seeing home screen with net flixs or the other apps.player has been working great we used it 2 day earlier...
The "handshake" between the television and the blu ray player has been lost. This happens a lot when connecting with hdmi. Sometimes a hot swap will work to remedy this. That is turning off and unplugging both your television and bluray player while removing the hdmi cable from both for 30 seconds to one minute. Reconnect the bluray player to the hdmi cable and then to the television. Plug them both back in and turn the television on first then the bluray player. Your television may need a factory reset going into the service menu or the board the hdmi ports are located on might need to be replaced if all of the hdmi ports are not responding. You can connect with component if possible in the meantime.
Apr 14, 2011 | LG BD390 Blu-Ray Player
My TV model 21QF2-A is locked please send me unlock code. thankyou
my sharp tv model 21qf2-A asks for a code or password of 4 numbers that I forget. What should I do?
Nov 24, 2010 | Sharp 32C-240 32" TV
Need code for rca tv
Hello
You just try one amoung the folloing four digit codes
{ 0031 0004 0048 0054 0094 0100 0102 0107 0129 0191 0005 0009 0000 0162 0163 0342 0003 0015 0022 0096 0113 0125 0179 0187 0188 }
Proceedings
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Oct 23, 2010 | RCA F31317 31" TV
I need to set-up my one for all remote for a sanyo tv. i need the tv code
Hello
You just try one amoung the following four digit numbers
{ 0049 0097 0110 0004 0268 0012 0108 0180 }
Proceedings
Oct 23, 2010 | Sanyo Televison & Video
Lost code list and need a code for my t.v.
Hello
You just try any one amoung these codes. Thease are only availabe remote codes for Sanyo at this time.
0049 _0097 _0110 _0004 _0268 _0012_ 0108 _0180
Proceedings
Samsung BD-P1200 (Bluray) Remote Control stop responding
Try resetting it.
Remove the batteries and hold down the POWER button on it for 30 secs. Then replace the batteries with fresh ones.
Dec 19, 2008 | Samsung (1012861) Remote Control
Broken Kroy 4350?
You may have the tube threaded over the green sensor board, instead of below it..
What size tube is it. 1/8 and sometimes 3/16 lets infrared light past one side or the other and trips the sensor, making the machine think there is no tube in there, also.
We're Hanover Technical Sales, Inc. We do Technical Support for Kroy machines. If we're wrong, we don't have enough info.
Jun 10, 2008 | Kroy K 4350 Printer
Samsung HTE6500/ZA Logo
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
