Question about Konica Minolta Magicolor 2530 DL Laser Printer
Toner level How can you tell how much toner is left?
  • 210 Answers
To check the toner level, there is a little clear window on each cartridge you can use for this purpose. Hold the cartridge vertically. If you see toner in the window, it is more than half full (or less than half empty, ha!). If not, slowly tilt the cartridge toward the side with the window. Essentially, how far you tilt it before you see toner determines how far below half full it is. If you pass a 45 degree angle before the toner appears in the window, it is nearing empty and must be replaced or refilled (yes, refilling is an option).
If you do have to replace or refill, don't forget to empty the waste toner bottle (responsibly, of course). By the time you run low on toner in one of your cartridges, the waste toner bottle will likely be nearing capacity.
Posted on Aug 31, 2009
  • 32 Answers
Print off a menu map
Posted on Jun 26, 2009
Ricoh Irregular Toner error message Toner levels appear OK, reseated the cartridges, but same error.
Take the toner cartridge out and shake it vigorously. The toner level inside may be getting low so shaking it distributes what's left.
Sep 14, 2017 | Ricoh Office Equipment & Supplies
0F54H Fatal Error
Witam,
An error occurs on the toner level sensor for each color:
0F52H Toner level sensor /Y malfunction
0F53H Toner level sensor /M malfunction
0F54H Toner level sensor /C malfunction
0F55H Toner level sensor /K malfunction
Relevant electrical parts:
Toner level sensor/Y (PS13)
Toner level sensor/M (PS14)
Toner level sensor/C (PS15)
Toner level sensor/K (PS16)
Printer control board (PRCB)
Step Action:
1 Check the connector between each sensor- PRCB PJ21 for proper connection and correct as necessary.
2 Replace the toner level sensor of the corresponding color.
3 Change PRCB.
Feb 11, 2014 | Konica Minolta Magicolor 3730 Dn Color...
TONER EMPTY MESSAGE
SAMSUNG SCX 4321 TONER EMPTY RESET
MENU
UPPER LEVEL
LEFT
RIGHT
UPPER LEVEL
ENTER IT WILL SHOW TECH MODE
HIRA THAKUR (hira_22@yahoo.com)
Aug 24, 2012 | Samsung SCX-4321 All-In-One Laser Printer
I was unable to loace the Toner Cartridge. Could you please tell me where to open up and how to replace the tomer cartridge? Thank you. Regards, Lisa Li
Make sure that the printer is turned on. Open the front cover. Slowly but firmly pull the drum unit and toner cartridge assembly out of the machine. Push down the green lock lever and take the toner cartridge out of the drum unit. Unpack the new toner cartridge. Hold the cartridge level with both hands and gently rock it from side to side five or six times to spread the toner evenly inside the cartridge. Pull off the protective cover. Put the new toner cartridge firmly into the drum unit until you hear it lock into place. If you put it in properly, the lock lever will lift automatically. Clean the primary corona wire inside the drum unit by gently sliding the green tab from right to left and left to right several times. Put the drum unit and toner cartridge assembly back in the printer. Close the front cover.
If you want even more detailed information, there is a how to guide with ilustrations on each step on the Brother website.
Dec 07, 2010 | Brother HL 2140 Laser Printer
TONER LAMP FLASH
To reset the toner level.. you will need to push the level at the left side of the toner...
First remove the toner from the printer, and you will be able to see the white level on the left side of the toner.. to push it up, you will need to unscrew 3 screws which is holding the side cover.. once done..push the white level the other way and then close back the side cover. Screw back and then put the toner into the printer.
This should reset the toner. But make sure there is still toner in the cart, else it will damage the drum..
May 24, 2010 | Brother HL-2040 Laser Printer
Yellow light on Toner light on) Cannot print a thing
take out the toner.. at the left side of the toner, there is a level, unscrew the 3 screws and turn the level to the other side, this will reset your toner.
make sure the printer is on when you put back the toner.
Jan 18, 2010 | Xerox DocuPrint 203A Laser Printer
Black Toner issue
Does your toner cart have any little clear plastic windows?
HP printers shine a light through this window to ***** toner level.
Cover one of the windows with tape & the printer will think the cart is full.
Sep 03, 2009 | HP LaserJet 4600dn Color Printer
Oki C3200n Says Order K Toner after install
Two possible problems:
1. You actually got a partially empty new toner. This has happened to me once.
2. The sensor on the printer is dirty and not seeing the toner. With the toner there is a little wipe that says it is for cleaning the LED. There is an LED sensor that "reads" the presence of the toner. If this is dirty it will think there is no toner cartridge.
Jul 09, 2008 | OKI C3200n Led Printer
OKI C3200N laser printer, low toner problems
For each toner there is an individual toner sensor. There is a real good possibility that the metal contacts on the sensors have become dirty. Typically, a little bit of canned air directly on the sensor contacts will resolve the issue.
After removing a toner cartidge, look to hte left side of where that cartridge rests. The sensor is located there.
May 05, 2008 | OKI C3200n Led Printer
Ink supply level
Hello!
There is usually additional HP software provided on the CD the printer came with which which is capable of indicating  the ammount of toner left int he cartridge.
If no such software is provided, then you can only tell when your toner level is low by a flashing light on the printer itself.
Hope this helps!
Apr 01, 2008 | Computers & Internet
Konica Minolta Magicolor 2530 DL Laser Printer Logo
328 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
