Question about Omega Watches
Watch losing time
The seconds needle stops, loosing time, when tapped sometimes the second needle starts and sometimes it does not. It does sometimes start to move normal of its own after stopping. What could be the reason?
    Problem Solver:
  • 19 Answers
Sounds like there is dirt in the movement that is blocking the train and stopping the watch a service should sort it out
Posted on May 10, 2014
  • 203 Answers
SOURCE: second hand moves every 4 seconds
the battery need replacing this is what its supposed to do when batt low. if this helps please rate joe
Posted on Nov 22, 2008
  • 4 Answers
SOURCE: watch second hand
I had the same problem with my Tag. Same 4 second jump. It's definitely the battery. I'm surprised at only 3 months, but maybe it sat a while in the display case. Mine was over a year and a half.
Posted on Feb 16, 2009
freetek
  • 5568 Answers
SOURCE: the second hand stop moving but the watch is still
The hands of an analog watch are often only press-fitted on the shafts (hour and minutes are tubular, seconds solid shaft) and the second hand has probably only slipped so it is no longer being driven. I suspect a watch-maker could reattach it for a small charge.
Posted on Sep 25, 2009
SOURCE: The second hand of my Tissot watch T870/970 starts and stops.
Hello!
Absolutely astonished by this "solution" from escapement.
This watch is working perfectly - it is simply giving its "end of battery life warning".
Posted on Dec 11, 2009
SOURCE: Sweep 2nd hand operation & watch time setting on my Pulsar watch.
The larger second hand on the Pulsar PF8036 is part of the stopwatch feature. The upper button starts/stops the stopwatch feature, and the lower button operates the lap/reset function. Why they made the larger hand work only with the stopwatch instead of the smaller hand to the left is beyond me, but that's how it is designed.
Posted on Mar 25, 2010
How do you know if a watch battery is fading. On some watches the second finger moves two seconds at a time but on one of my watches it is just losing time.
If it looses time and it has been like more than 2 or 3 yrs since replacing the battery it could be that the battery is loosing power. loosing time is a symptom of a fading battery power.
Mar 10, 2015 | Nixon Watches
Akribos xxiv watch
Sounds like it may be a bit sticky or need demagnetizing. A light sharp tap on the side on something like a wooden or plastic surface might help!
Jan 29, 2014 | Watches
My watch works with movement, and will work for a few seconds then stop, even thought I'm continously moving. Is it a shortage or something? I can shake the watch and it will work but only for a few...
I would take it to a watchmaker/jeweler to have them check the battery. Some watches have a battery bar that holds the battery in and it may have come loose. Or the battery is losing charge. It should not cost you anything to have them check the battery for you. Good luck
Jul 22, 2010 | Anne Klein AK Round Brown Crystals Watch...
Stopwatch second hand stops/jams at 57 seconds point, jamming the whole works. watch stops. keeps excellent time otherwise if stopwatch not used. 2003 SS model. bought new from rolex.
this watch will need a service from a rolex trained repairer wich wont be cheap 700 dollars min or 500uk pounds min..you could try tapping watch in palm of hand to see if a batton or luminous paint has come loose,then all it needs is movement taking out and blown clean inside case.any decent repairer can do this.sometimes the teeth on a wheel can wear in one place hence it always stops in same place.recomend service as best action,you never loose on a rolex...
Mar 26, 2010 | Rolex Daytona 116520 Wrist Watch
Seconds hand starts ticking then stops
Your band may be too loose. This is the model that moves when worn correct?
May 12, 2009 | Tag Heuer Automatic Chronograph Series...
Automatic watch seconds hand stops at 8
The 'dit' at the 8 is higher than it should be. Slightly lifting or unbending the tip of the second hand will correct the problem.
Feb 20, 2009 | Watches
I have an Oris BC3 which was never a great time keeper; gaining or losing 5-10 seconds per day. Recently, it started to gain at an alarming rate and I took it to be cleaned and regulated at a watch...
Take your watch back to the watchmaker and ask to regulate the watch again. After a decent repair watch shouldn't loose or gain that much and if properly regulated and tested can keep good time. ORIS is using the same Swiss made ETA movements as Tag Heuer, Ebel, Montblanc, Tissot, Maurice Lacroix etc. These are very good mechanical movements and can be adjusted to allmost perfect timekeeping.
Dec 22, 2008 | Watches
Time
Hold in the MODE button until the alarm time appears.
VERY IMPORTANT - Tap the MODE button again, and the time should appear with the seconds flashing.
Use StART/Stop to choose among seconds, hours, and minutes, and
Use ADJUST to increase the selected number
Press MODE to put the thing back in regular operational mode
May 06, 2008 | Timex 1440 Nylon watch
Timex 1440 sports WR50M
Solution #2 by Guest, posted on May 13, 2008 solved my problem. OUTSTANDING solution #2!
1. Hold in the MODE button until the alarm time appears.
2. VERY IMPORTANT - release and TAP the MODE button AGAIN, and the time should appear with the seconds flashing.
3. Use StART/Stop to choose among seconds, hours, and minutes, and
4. Use ADJUST to increase the selected number
5. Press MODE to put the thing back in regular operational mode.
After several attempts with other directions over the last four months, these 5 steps WORKED.
Mar 30, 2008 | Timex 1440 Nylon watch
Chrono
pull out the crown and press either the start button or split button. One of those will move the sec needle.
Jun 09, 2007 | Fossil CH2332 Wrist Watch
Watches Logo
91 people viewed this question
Top Omega Watches Experts
Geoff
NavigatorX
Level 1 Expert
Are you an Omega Watch Expert? Answer questions, earn points and help others
