Question about Panasonic KX-T7431 Corded Phone
The display reads ring off. how do i turn on.
Hi
The ring is "Off" when the volume is turned down to zero
Turn the ring volume up and it should go off
Posted on Sep 23, 2009
How do I turn off the silent mode on a Uniden 6.0 dect phone, so it will ring?
For the Uniden model D1680 & similar...
You ENTER "Silent Mode" by pressing and
holding the [ # ] key on the handset for a few
seconds until the display reads "Please Wait".
It will (chirp) and display "Silent Mode ON".
You can EXIT "Silent Mode" by pressing and
It will (chirp) and display "Handset #".
Another easy way to end "Silent Mode" is to go
to the BASE and press the [ANS ON/OFF]
button to turn off the answering machine system.
(Push the [ans] button, do not unplug the power)
"Silent Mode" will clear a moment later while the
control voice tells you "Answering System is OFF"
Now you can again turn on the answering machine
system as desired.
Jun 13, 2016 | Uniden DECT 6.0 Cordless Telephone...
How do I turn off the silent mode so the phone will ring?
system as desired.
How do i reprogram my speeddial numbers on jazz 4400?
Hello.
From NorStar Support:
To Program Personal Speed Dial Numbers: (Numbers 71 - 94 only.
1. Press the Feature button, then * 4
2. Enter the 2 digit code (71 - 94). that you want to assign to that phone number
3. Enter the telephone number, then press the OK softkey
4. Display will show: "Entry xx stored"
If the above doesn't work, try:
  1. Press [Feature] [*] [4]
  2. Enter a two-digit code from 71 to 94.
  3. Specify the external line by pressing a line button, a line pool button, or the intercom button. If you don't specify the external line, the system automatically chooses a line for the call.
  4. Dial the telephone number you want to program (up to 24 digits).
  5. Press [Hold].
  6. Record the code and number you have just programmed.
Hope this helps.
Feb 02, 2011 | NorStar Jazz Plus 4400 Corded Phone
My camera won't take pictures. Display reads fEE. Just bought new film and batteries.
Turn the aperture ring on the lens to its smallest setting (largest F/number). If the ring also has a lock, lock it in place. You control the aperture from the camera body, just as you would on a lens without an aperture ring.
Dec 31, 2010 | Nikon N75 35mm SLR Camera
How do I turn off the ringer on a Nortel T7316E?
If you want to temporarily turn them off use do not disturb (feature 85, feature #85 to turn DND off)
Turning off the ringing permanently will require you to program the set. Programming2.gif is done on M7310, M7324 and T7316 sets.
To set up ringing you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you wish to program ringing on. Press the show key (top right arrow)
The display should sat LINE ACCESS
Press the show key (top right arrow) .
The display should say LINE ASSIGNMENT.
The display ask for a line number. press list
The display should say line 001: appear & ring press CHNG til it says appear only.
press next key (lower right arrow)
The display should say line 002: appear & ring
Repeat same procedure as line 001 til all available lines are done
press the release key when finished
Sep 24, 2009 | NorStar T7316E Corded Phone
My playststion3 turns red as soon as i turn it on
The Red Ring OF Death!!!
Its a heating problem, the system has become to hot in its period and melted the soldier inside.
Right if you give microsoft a ring, they extended there warrenty to 3 years as this was a very popular problem, and they will arrange for it to be picked up free of charge and fixed for you.
hope this helps
alex
Apr 30, 2009 | Sony Playstation 3 (PS3) Console
FEE message in display when using 50mm lense
The FEE message indicates that the lens is not set to smallest aperture (highest number). The camera body expects this so it will have full control of the aperture. It sounds like you may be accidentally bumping or turning the aperture ring on the lens while using it or changing lenses. There is a little slide lock to lock it at f/22 to prevent this. Turn the aperture ring to 22 and move the slider so the white dot is next to the orange mark on the lens barrel.
Feb 28, 2009 | Nikon Normal AF Nikkor 50mm f/1.8D...
Nokia 6301 won't turn on properly..
Your display circuit is broken, even if the LCD-panel,
seems to be ok the display is damaged.
This is a very common problem in Nokia phones.
The only way to fix this is to change the display.
You need a T-6 Torx Skrewdriver to do the job.
You can find displays for fair price at :
www.mytrendyphone.com
This is your solution! Please vote!
Feb 01, 2009 | Nokia 6301 Cellular Phone
I have a Brother Intellifax 2800 and it can send faxes but just rings and rings and won't receive them.
what does the display read. If you want the fax to auto answer. the display needs to read ( fax only). to chang this setting if not reading that massage press the receive mode button till fax only is in the display
Jan 30, 2009 | Brother IntelliFAX 2800 Laser Fax
Cannot recieve faxes
I just spoke with customer service live chat.
-press the "Fax Mode" button
-press the menu button
-The Fax menu screen will be displayed
-press down arrow button 5 times until the screen displays "Ringing and Answering."
-press the select button
-the display will show the "Ringing and Answering menu
-press down arrow button 4 times untip "Pick-up On?" is highlighted
-press the right arrow button 2 times until the screen displays "1st ring"
-press the "select" button and now "1st ring" will be set as the default.
Apr 01, 2007 | Lexmark X8350 Print, Scan, Copy and Fax...
Panasonic KX-T7431 Corded Phone Logo
889 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
