Question about Craftsman Garden
Husqvarna crt51 cultivator
No drive to the wheels,the rotors will enguage and work but no drive to the wheels.I put the rotovator on a block and took the wheels off and put it into gear and the wheel shaft would rotate forwards and reverse would work as well...i held the wheel shaft and it rotated well,but soo has i put it back together and put it into gear it wouldn't turn.Any ideas? thank you
  • 8 Answers
SOURCE: MTD reartine tiller, wheels won't turn in or out of gear
broken drive blet or chain, check accordiningly
Posted on Nov 16, 2008
  • 10 Answers
SOURCE: Russian Lomo (Biolam?) old monocular-coarse focus wheel slippage
The right hand shaft knob contains the coarse focus locking clutch adjustment mechanisim( big name-simple design). This solution applies if you have the model with the fine adjustment wheel mounted in the base and may or may not apply if your fine focus is in the left-hand knob.
Inside the right hand knob ( as viewed from the rear of the scope) is a threaded disk/nut which has two pins (Slightly and for reasons I don't understand: they are offset vertically, they have different pin diameters and different pin lengths) In theory, they lock into the bushing within the knob proper to keep tension on the clutches while keeping the knob from falling off.
The repair can proceed in two ways depending on if the disk/nut has totally been unscrewed from the focus shaft.
Gently pull the left knob and as you do turn it slowly to see if the pins reseat. If they do you'll feel a slight lurch outward of the knob. Hold gentle outward tension( so as the pins remain seated) as you turn the knob clockwise until the slippage in the clutches is so lessened that your knob is firm and the focus adjustment is operating to your liking.
IF that didn't work it is likely that the threaded disk/nut has come off the shaft and will need to be reset and screwed back down. The disk is easily cross threaded and you'll need tweasers or micro plyers or a hemostat and/or a flat headed finishing nail. Plus I recommend a small bottle of LOC-TITE(tm) semi-solid thread sealer--NOT the kind that freezes the threads
As you unscrew the knob counter clockwise pull on the knob to slid it off the shaft it should come off in your hand revealing about 6-8 washers on the shaft. These are the clutches so be careful not to loose them.
The knob should have a slight rattle and that is the disk nut. To get to the disk/nut put a small finishing nail head first into the shaft whole and push to release the plastic knob insert cover out being careful to not loose the disk/nut.
To clean the threads and insure an easier repair screw the disk onto the focus shaft to insure the threads are clean.
This next part works better with the scope lying on its left side.
This part is optional but not necessary to get the scope back in operation. Place a tiny amount of LOC-TITE thread sealer on the shaft threads. This will make the knob clutch adjustment more stiff but will also reduce the likelihood that the knob will be adjusted out too far again. The loosening occurs when the knob is turned before the operator realizes the pinion gear limit has been reached or by someone who dosen't understand correct opperation of the focusing assembly.. So long as the clutches are engaged the and there is no slack in tension the disk/nut shouldn't come off the shaft again.
Observe the pins in the disk/nut and match them up with the holes in the aluminium/brass knob bushing. You'll have to wiggle the disk around to get it reseated properly. Once you do, hold the disk firmly against the bushing to keep the pins seated as you put the knob back over the shaft, pushing it all the way down against the shaft.(The clutches are springy so don't worry about it locking in place just now).
You may prefer to hold the disk/nut and knob firmly with a finger and spin the left hand knob counter-closkwise for easier threading of the nut but remember this will also move the focus arm. Not a problem if you start with the focus in the range centered.
If using the right knob: Turn the knob clockwise feeling for the threaded shaft maiting back up with the threads. IF it cross-threads, back it off try again. Once the threads are engaged keep the outward tension on the knob so the pins don't slip out. When you/ve screwed it down far enough, the clutches will take up the slack and keep the knob from slipping away from the disk/nut. You'll know the clutches are engaged when the focus shaft turns.
If you are happy with the repair slip the knob cover back on and snap in place. It if falls out place a little of the thread sealer on the rim and try again.
If you like this solution it took me an hour to write it up. Please consider volunteering an hour with a local non profit. I support the American Red Cross, Habitat for Humanity and the USO.
Regards
Posted on May 11, 2009
pippall
  • 1486 Answers
SOURCE: roper rally rototiller wont till
Check belts
Posted on Jul 06, 2009
shadtremonky
  • 353 Answers
SOURCE: how to put a steering wheel back together
special tool required
Posted on Aug 07, 2009
SOURCE: sears rototiller wheels locked up engine runs great
After taking the transmission/frame apart, the drive chain for the tires broke and wedged in the case. I cleaned the rest of the gear box and washed all of the gears and sprockets. Ordered up the chain, gasket and grease. I re-installed and greased all of the pieces and reassembled the case. I used a marine wheel bearing grease for the water resistant properties. I installed a zerk fitting right over the shifting lever. This should help keep the grease on the top end of all the gears. After a few hours it is good to go and works just like new.
Posted on Sep 07, 2009
I have a 4 wheel drive 1993 ford f150 and i replaced the little motor that controlls it. but the 4 wheel drive doesnt want to work? what could ot be?
sounds like you getto chase wires but did you try the sillinoid befor u put it in. if not take it out and have some one try to push the button and see if it enguages
Jan 04, 2013 | 1993 Ford F150 SuperCab
I have a 17
wheels can be removed by using a needle nose pliers to remove the hair pin clip.
Jan 26, 2012 | Husqvarna 17" 90Torque Rear Tine Tiller
ABS enguaging on its own. Replaced both front wheel bearings. What would cause this? Had a recent MVI done and the Mechanic said the front Right wheel bearing need to replaced. He put a new on on and...
Not supposed to use air gun on axle nut
Torque Wrench -- as you did
Check Wheel Sensors -- one may be bad or more
likely the mechanic damaged it.
Use a Volt Meter --put on A/C unplug sensor &
put meter on wires and spin the wheels
Do all four & compare
Jul 24, 2011 | 2003 Cadillac Sts
2002 2500 silverado - 4-wheel drive makes clicking noise some times, mainly when cornering. Now the nose went away, and no 4 wheel drive anymore. 4-wheel drive light is on, but no 4 wheel drive. Vehicle...
well typically is there is a noise when making a turn its caused by a bad cv-joint but if your having problems with the 4 wheel drive i would look at the linkage to the transfer case and make sure there is not to much play or bent or broke rods and stuff.
Dec 04, 2010 | 2002 Chevrolet Silverado 2500HD
How do i put the brake assembly back to gether
If your saw is indeed a Husky there is likely an illustration of the chain brake on the IPL here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – for use with IPL
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
Oct 26, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Have barreto 13hp hydralic rotovator but it seems to be slow speed slow drive speed when fully engaged
they are all the same it's a small price to pay for the quality of work they do we. have 4 of these and they have been such good machines for us we use them on a daily basis.
Aug 06, 2009 | Garden
4 wheel drive enguage problem 89 Jeep
This system is run off a vacuum line get under the jeep its on the passenger side a hose runs into the axle housing make sure that it is plugged into the connector.
Jan 28, 2009 | 1989 Jeep Wrangler
2001 Jeep Grand Cherokee
Do you have manual lock in hubs??? Alot of these work off of vacuum. check you hoses, and also a pull off valve which enguages the front end. One bolt to replace this the valve the enguages the front end.
The defrost has leaves in heater box , blocking air flow on pasenger side most likely???? Check it out.
Dec 29, 2008 | 2001 Jeep Grand Cherokee
Garden Logo
95 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
