Question about Yamaha WaveRunner FX Cruiser SHO Boating
I was cruising at around forty kilometers per hour when suddenly it just lost power and could only go about 6km/h. Motor is fine.
When I flushed the motor at home the engine was running fine and water was circulating out the side?
PyroPCMan
  • 405 Answers
SOURCE: 88 Bronco ii Coolant not circulating
Good Day,
Sounds like the thermostat is working properly, the only other cause for the valve/lifter noise could be the oil pump is not pumping enough oil up to the top of the motor. I suggest doing an oil change(if you haven'y aleready), be sure to flush several quarts through, after sitting for 5 years I'm sure the old oil is pretty sludgy, this well help rule out this possibilty. As far as the water pump goes, It either works or doesn't typically when they are on there way out the will leak from the gaskets. A bad head gasket would cause white smoke form the exhaust as coolant get's into the oil and is burned off, so I don;t hink this is the problem.
Here's a start for you, hope this helps and good luck
Posted on Jul 01, 2008
  • 54 Answers
SOURCE: Sudden loss of engine power
Your alternator is going out on your car. You need to get a new Alternator
Posted on Dec 03, 2008
  • 59 Answers
SOURCE: engine stalls
my friend had one that did the same and he replaced throttle positioning sensor and it fixed it. but when you put a new battery in them they wont idle until you hold at steady low rpm for almost a minute because it has to relearn its position. so check your voltage meter and make sure it is around 13-14 volts when running and not on 12 while running because it could be too low of voltage for it and would be the same principle as disconnecting the battery because it takes 12 volts to keep computer on. hope I wasnt too confusing but I just want you to check your voltage for free before you buy electrical parts.
Posted on Dec 22, 2008
SOURCE: motor stopped
Go to the aerogrow aerogarden website they have step by step instructions on how to fix this problem. I had the same problem and was able to fix it by following the steps outlined there. http://www.hydroponicgardens.net
Posted on May 15, 2009
  • 15 Answers
SOURCE: I have a Homelite recirc pump AP-125. Motor runs
usual if the pump is dry you need to try bleed get some water to the pump. either pouring some in the lift pipe some pumps have a bleed screw to pour into to get it pumping. if it still wont could be the fins in the pump that are not working proper
Posted on Oct 16, 2009
How do i change the speedometer on 1998 Avalon from kilometers to miles per hour ?
install a spedometer with kilometer markings or manualy paint markings on at proper locations. 88 kph = 55 mph, etc.
if you were thinking you could push a button, not gonna happen.
Jul 01, 2014 | 1998 Toyota Avalon
600 KNOTS PER HOUR TO KILOMETRS PER HOUR
Knot is a unit of speed so knots per hour is a unit of acceleration.
600 knots is 1111.2 kilometers per hour.
600 knots per hour is 1111.2 kilometers per hour per hour.
May 09, 2014 | GPS
49 Knots per hour is
Knot is a measure of speed. Knot per hour is a measure of acceleration. Are you sure you want 49 knots per hour?
49 knots is about 56.4 miles per hour or about 90.7 kilometers per hour. A good pace for a car and a very good pace for a boat.
49 knots per hour is about 56.4 miles per hour per hour or about 90.7 kilometers per hour per hour. Not a very good performance if a car or a boat takes an hour to get up to that speed.
Feb 20, 2014 | Boating
Convert kilometers to knots
You may have to do the calculations yourself.
1 knots = 1.8520 kph 50 knots = 92.6 kph
Oct 17, 2013 | GPS
Meter to kilometer
There are 1000 meters in a kilometer and 3600 seconds in an hour (60 seconds per minute, 60 minutes per hour).
Press 8 0 0 / 5 0 * 3 6 0 0 / 1 0 0 0 =
or 8 0 0 / 1 0 0 0 * 3 6 0 0 / 5 0 =
The result should be 57.6 kph.
Nov 11, 2011 | Casio FX-115ES Scientific Calculator
What is the speed of an automobile in kilometers per hour if it is trveling 45 miles per hour?
There are 1.609344 kilometers in 1 mile. So you can just put it this way.
45 miles x 1.609344 kilometers
1 mile
The answer is 72.42048 km or just 72.42 kilometers
Therefore the automobile is traveling 72.42 kilometers per hour.
Hope this helps.
Jun 27, 2011 | Casio FX-9860G Graphic Calculator
I've misplaced my manual for my Free Spirit (Sears Canada) treadmill and can't remember how to change the distance calculator from miles to kilometers. I recall it being very simple to do. Anyone know?
[from my Owner's Manual]...
On MY Free Sprit mdl 309180:
1. Remove the safety tether from the treadmill.
2. Press POWER button and hold.
3. While pressing the POWER button, insert the safety tether.
4. After lights on the LED display go out, release POWER button. You will hear a beep.
5. Press POWER button again. You are now in kilometers per hour.
* Repeat steps 1 - 5 to convert to miles per hour.
* If you are in kilometers per hour mode, you will see a "Si" in the time section when the safety tether is inserted.
* If you are in the miles per hour mode, you will see a "bri" in the time section when the safety tether is inserted.
Hope this helps,
gyro_john in Saskatoon, SK Canada
Jun 29, 2009 | Exercise & Fitness
While passing another car on fairly steep upgrade at about 95 kilometers per hour, my 2004 chev aveo suddenly lost power. I was able to allow the other car to pass me and pull over to the roadside. I have...
Apparently the timing belt came off and caused considerable engine damage. On checking problems on internet this appears to be a not uncommon problem with this model.
Jun 25, 2009 | 2004 Chevrolet Aveo
How to change mph to kmph
ther is 1.6 kilometers to a 1 mile
Mar 25, 2009 | 2008 Suzuki GSX 1300 R Hayabusa
Boating Logo
53 people viewed this question
Top Yamaha Boating Experts
Phil Walker
Phil Walker
Colin Stickland
Colin Stickland
Mike
Are you a Yamaha Boating Expert? Answer questions, earn points and help others
