Question about geaxgame Poker KinG OnlineTexas Holdem
They keep taking my chips away
This is the second time this has happened I want my chips back
  • Rob Lauzon Apr 20, 2014
    You need to provide more details then that, how are they taking your chips away?
Deleted chips
Same thing happened to me. I contacted them about it. Unfortunately they were no help and i didnt my chips back.
Jun 01, 2013 | Evermoremedia DoubleDown Casino
White lines that are constantly on will go away for a few seconds then pop back up.. Mitsubishi 73" model number WD-73640
You need to replace the 4719-001997 DLP Chip. this should solve the issue.
This chip can be expensive so look around before you purchase. This is a common problem with these TVs, both white lines and white dots. You can find out how to replace the chip by going to this website: http://www.fixyourdlp.com/2012/09/04/solve-the-mitsubishi-wd-73640-white-dot-problem-with-a-new-4719-001997-dlp-chip/.Hope this helps
Feb 27, 2013 | Televison & Video
I have an HP desktop computer. I got a usb power overload message and now it won't even boot up. Is there any way to fix it?
What happens when you try to boot up now?
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous. Most times the problemis with the memory or Video Card. Count the Blinking Lights or Beeps and takenote of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.Maybe your DC Power Jack which is where the power cord plugsinto the computer is bad. Take an ink pen and push the tip inside thejack and see if the little pin wiggles, if so the jack is bad. You'll have totake the laptop apart to fix it. Most times it is soldered onto themotherboard, so you will have to desolder the old and solder a new one.Maybe your memory is bad or the memory slot is bad.Remove the Power Cord, Open the Case and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
May 01, 2012 | HP Computers & Internet
My Packard bell pc won't turn on an keeps making a
The number and timing of beeps will tell you what's wrong. You'll have to find the motherboard manual to find what the beeps mean though. Would be worth taking the RAM chips out, blowing any dust away and putting them back in.
Apr 20, 2012 | Computers & Internet
Screen will not turn on unless I reboot it 2-5
This computer sounds like it has the same problem as every other DV series laptop and that is the fact that if they overheat in the slight bit, the solder on the Nvidia chip hits its de-solder point and the chip looses contact with the motherboard and causes all kinds of issues. I have "reflowed" dozens of these motherboards and have a 90% success rate and getting them to run again. If you have a heat gun, I can walk you through the steps to reflowing the board. You have to understand though that it may work and again it may not. In the times when I have not been successfull, I simply replaced the motherboard.
Take the laptop apart, I'll give you a link below for the service manual that explains the process.
The Nvidia chip sits next to the processor chip, wrap the motherboard in aluminum foil to ptotect all the areas except for the top and bottom of the affected chip.
Now, clamp the motherboard to a desk so it will not move and make sure that the underside of the chip is accessable from underneath.
Get a quarter and wad up a small amount of solder and place it on the quarter. Now put a small amount of thermal paste on the chip and place the quarter on the chip with the solder up. (The solder will be the indication to you that the chip has reached the proper temperature to melt the solder on the chip).
Now, take the heat gun and on the first heat setting start heating the top of the chip for 30 seconds, then switch the gun to the bottom of the chip for 30 seconds, then go back to the top for 30 seconds and then to the bottom for 30 seconds.....now, switch the gun to high and hold it to the top of the chip where it will blow down on the quarter, keep the gun at least 6 inches away from the board at all times. When you see the solder on the quarter melt into a drop, switch the gun to the low heat setting and put the gun about 12 inches away and sweep the gun from side to side or have a ceiling fan over the area and let it blow air softly down on the board to help gradually cool it. Do not bump, hit or disturb the board until the board has at least 30 minutes to cool down. Once the board cools down, remove the quarter and reassemble the laptop. Power the ****** up and see if it fires up. Below is the link to the service manual, copy and paste it to your web browser address bar. It is in a PDF format and is free to use, copy and print.
http://tim.id.au/laptops/hp/hp%20pavilion%20dv2000.pdf
Jul 30, 2010 | HP Pavilion dv2000t Notebook
Laptop keep freezing for no reason
Laptops freeze for many reasons. Since you've eliminated the easy ones I'll take you through the hard ones. Freezing other than software is caused by a temperature failure of the RAM chips, the video chip, the video ram chips, slow or non moving fan, dirty heat sink or failing CPU. You can take out your RAM chips one at a time. If the problem goes away then thats the culprit. (Take out the RAM chips with the computer off). You can clean the heat sink yourself. Get a can of compressed air from an office supply store. Somewhere on the back of your machine there are exit vents. Turn the unit off and unplug it and remove the battery. Spray the can of air into the vent area. Now put the battery back in and plug the charger in. Turn on the unit and determine if there is air flow from the vent. If you can't feel it with your hand then holding a single ply kleenex in front of the opening may help. If there is no air flowing from this vent or very little air then the fan is/has failed. To replace the fan requires a strip down of the computer as well as all the other chips that I mentioned that could be bad. Take it to a reputable repair person or check my website www.micromendllc.com. Good Luck
Mar 02, 2010 | Acer Aspire 5500 5570-2609 Laptop
My PS3 shuts off immediately after i turn it on. get orange light for about 2 seconds before it shuts off
This problem is called the Yellow Light of Death. It is caused by fractures in the solder on the underside of the Graphic chip. The only safe way to repair this problem is using an Infra Red BGA rework station to reflow the solder. The best place for this in the uk is:
http://www.playbackups.com/Playstation3-xbox-360-repair-repairs-manchester-bga-solder.html
Nov 09, 2009 | Sony PlayStation® 3 (60 GB) Console
Menu box keeps appearing on the screen
There are meny reasons this might be happening. here are a few obvious ones.
1. The remote is under a cushion and buttons are being pushed.
2. The Sensor on the set is in the sun and the sun is confusing it.
3. You neighbor is messing with you
4. The set has a bad chip/loose connection/etc.
[you might try something as simple as unplugging it for a minute.]
5. it's set to 'DEMO' mode.
Ken
Jan 01, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My fridge won't keep temp..
most samsung have a fan in the fridge and an evaporator. take off the back plate of the fridge and melt off and excess ice especially round the fan.; if it keeps happening then you have a fault in the defrost system
May 21, 2007 | Samsung RS2630SH Side by Side Refrigerator
geaxgame Poker KinG OnlineTexas Holdem Logo
123 people viewed this question
Top geaxgame Apps Experts
Andrew Taylor
Andrew Taylor
 Mikey
Mikey
sdfOYXT
sdfOYXT
Are you a geaxgame App Expert? Answer questions, earn points and help others
