Question about Honeywell Programmable Thermostat Heater
Inside unit running outside want come on temp on
Inside unit running outside want come on temp on thermostat 80 deg
  • 284 Answers
Check circuit breaker in house panel labeled a/c or outdoor unit
check box near outdoor unit for a breaker or fuses
some thermostats have a 5 min delay when switched to a/c
check for external reset buttons at outdoor unit some are red depending on brand
check that all wires are intact at outdoor unit------none cut or hanging and not hooked to anything?
Posted on Jun 20, 2009
Auto/On set to ON. Fan runs.
Sounds like the thermostat, the way to verify is to unplug indoor unit, remove thermostat, take pic of wiring with phone or label the wires as to the terminals. Carefully twist the yellow,(Y) Red (R) and the green (G) together. Plug the furnace back in, if the unit operates normally, replace the thermostat. I am basing this on the fact that the blower speed is changing. This could also be an anomaly within the circuit board in the furnace section, not likely though as the outside unit (condenser) is not controlled n by the indoor board unless this is a heat pump. hope this helps. D
Jul 21, 2015 | Dometic Rooftop RV Air Conditioner
Tip
How to change thermostat on AUDI 1.9 TDI
Heed of antifreeze solution temperature!!!
You must check the thermostat operating. The thermostat location is on back of alternator at the bottom side of the bracket. IMPORTANT: It is NOT necessary to replace the alternator if you want to change the thermostat !!!
Thermostat checking:
1. Cold engine. Start up the engine and watch of the water temp indicator. After first value 60 Celsius Degree you still warm up the engine until the lifter (pointer) reach 80 C deg. (second mark after 60 C deg.). At this time you let engine running at idle speed and check with your hand the thermostat plastic housing and hose temperature in bottom left side of the engine. Heed of alternator driving belt and ventilator fan !!!
2. If the thermostat is good the hose must be cold until the water temp indicator reach almost 90 C deg.
3. The thermostat opening temperature is 87 C deg.
4. If the hose is already warm the thermostat is out of order.
5. If the thermostat and the temp sender are OK the last piece out of order will be the instrument cluster.
on Dec 19, 2009 | Audi A4 Cars & Trucks
Where is the thermostat located on golf v1 1999 1.6,car been standing 6 months worked fine now water not circulating!!!!!!
Heed of antifreeze coolant temperature!!!
First time you might check the thermostat operating.
The thermostat location for VW Golf 1.6 is inside of coolant thermostat housing placed on back side of the cylinder head. See pictures below.
Thermostat location, Part number: 032121110B, in german - "Kuehlregle" (Price around $20):
Important note: Always replace the thermostat round seal, position 6 in the above picture.
Please do rate my response. Thanks!
Jan 29, 2011 | 2001 Volkswagen Golf
Where is the thermostat on an Audi A4 diesel, 1998
Feb 22, 2010 | 1999 Audi A4
ASU9RLS/AOU9RLS unit Froze outside/ won't defrost
The drain had pine needles clogging the drainb so it couldn't drain.
In 2 months.... Thanks anyhow!
Jan 05, 2010 | Fujitsu Electronics - Others
UNIT RUNS AN EXCESSIVE AMOUNT OF TIME AND AIR IS COOL NOT COLD COMING OUT OF VENTS CARRIER 58DLA / 58DLX CENTRAL AC FAN AND COMPRESSOR ARE OPERATING BLOWER IS WORKING UNIT IS TURNED ON TO AC TEMP SET AT 76...
DOES THE HOUSE FEEL DRIER IF IT IS 80 OUTSIDE WITH ALOT OF HUMIDITY THE UNIT WILL RUN FOR A LONG TIME TO REMOVE THE MOISTURE(HUMIDITY) OUT OF THE HOUSE BEFORE TEMP DROPS DRAMATICALLY IS THERE WATER COMING OUT OF THE DRAIN PIPE OUTSIDE
May 03, 2009 | Carrier Heating & Cooling
Dryer runs at 120 deg tops
you can install a higher temperature cycling thermostat. They normally have a 140* cycling thermostat. Make sure heat element is not broken. Some models have a double element hand only half will work. post make and model
Jan 14, 2009 | Kenmore 60172 Electric Commercial Dryer
Heating & Cooling Logo
76 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
