I recently replaced Head Gaskets, cleaning and sealing as I went. While I was away my curious daughter tore off the tape i wrote on to identify the reinstall Ignition wire placement on my coil pack. Any help would be great, as I have found 8 different posts online claiming to be the order...:(
As you standing in front of the engine looking at the coil pack from left to right....2-5-4-3-6-1. cylinders 1-3-5 are on the passenger side and 2-4-6 are on the drivers side.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
I am not having luck with that order :( . It started up a few days ago with 524163, which is written on the front of my Coil Pack, but It was missing i believe. I drove it a bit that day, then sunday morning, No Start. I am going to pull off the front and recheck the Timing marks, and make sure it didnt slip a tooth, and will check that order you provided again. and that was for the 1995 Montero LS v6 3.0l 24 valve? Just double checking, I have gotten alot of the 12 valve engine version they also made that year.
SOURCE: Power tr. pack is the one supplying voltage to the
Hello! The engine timing sensor (Camshaft Positioning Sensor) is inside the Distributor Assembly and can not be purchased as a stand-alone item...Sad but true; The Distributor Assembly needs to be replaced...Cost is around $350 (includes $50 core)
Guru................Saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
SOURCE: 1995 montero 3.0 no spark on coil #3
check the jack pins condition, check for brakes, check the harnhes for broken wires, try an other ecm from a junked or salvage or borrowed and see if it makes any difference
SOURCE: have a 1998 mits. Eclipse 2.4 L. Won't start. Has
need more info is the 12 volts steady ? have u checked wires and plugs? if the 12 volt to coil is constant have a look at your crankshaft position sensor...
Here: https://dl.dropboxusercontent.com/u/3324... ; hoope it helps.. (cuiorus daughters are the future mechs ;)
That is a diesel inline 4 Manual? How does that apply sir?
