Battery been discharged for ages. Plugged it in & turns from red to green almost instantly. Put it on scooter & scooter emits a bleeping signal & doesn't work. Charge display states fully charged but scooter doesn't work. I assume battery is knackered. Thoughts? Original has a lead with an XLR plug on end & replacement batteries just seem to have 2 battery terminals. How would I connect a replacement
Hi, the battery's sound okay, have you made sure the scooter not in free wheel mode ? check the lever attached to the side of the brake ,,,
Check the wiring going to the axle .. At worse the controller has called it a day...at best a loose connection,,, controllers are repairable..
Regards
Rob
www.gewizrepairs.co.uk
SOURCE: battery power on mobility scooter
The Hand Control has probably bent in from use. ( Where she Pushes the throttle Control )
Grab a hold of it and bend it out towards you slightly
The part about the indicator going down when she moves and back up when she stops is normal
SOURCE: The battery takes a charge, but will not power scooter
This scooter require two batteries, not one. It is usually a good idea to replace both batteries at the same time, even though one is obviously bad, and the other "seems" okay. These 12 volt DC batteries (VDC) work in tandem to produce the 24 volts that the scooter operates on. In a perfect world, they would both live a long and happy life, but reality is that some die young, others old. Since they are joined together, the one that's going out saps the life out of the other one, so take a bullet and replace both batteries. Make sure you completely charge the scooter when you get the new ones in. Verify that your charger is working properly. To properly charge the 24 VDC system, the chargers have to have an output of about 26-28VDC. The output must be higher than the rated voltage of the two batteries put together to charge. While you have the shell off the scooter, you can see if the charger is working by measuring across the terminal on each battery with the charger off. Note the meter reading. It should be 12-13 VDC. Put it on the charger and retake the reading, and each battery should show an increase in the voltage due to the boost from the charger. After three hours, each battery should show about a 13.5 VDC reading which should hold above 12 for a good 8-10 miles. Always charge your batteries overnight, and if not in use, disconnect them completely with a full charge on the batteries.
SOURCE: AXS Mobility scooter loses battery power quickly.
hi , two problems can cause this,
1. batteries are weak, is the charger ok ? just because it 's green does not mean the charger is ok, can you validate the charge, try some other batteries ?,
2. Brake be activated or on at all times,
The best way to prove this is to remove the brake mech from the side of the motor completey now try the scooter, if the problem goes away then check the resistance of the brake, is it open or shorted ?
If you feel the brake, batteries and charger are working ok then the controller must be activating the brake and this is the fault but please double check the voltage on the brake leads.
Regards
GeWiz.
SOURCE: electric mobility scooter says charge is full but won't run
This sounds she has tripped her circuit breaker. It works just like the one on your house, when you ask too much of it it suddenly goes 'pop' and seems to be dead.
Looks like you have the same scooter as mine, it should be a little white button on the back of the base. If you follow this link, it will give you a pdf version of the older model pride victory manual, (Mine is a three, they are up to about 10!) See fig. 8 on page 20 and 'Circuit Breaker' on page 21. Also, Page 33 has the troubleshooting info. Hope this helps.
http://www.rentascooter.com/downloads/_manuals/pridemobility/Pride%20Victory%20Owner's%20Manual.pdf
SOURCE: just bought my dad a second hand go go 3 wheel elite scooter
Hi Linda. Sometimes if there is a blown fuse or faulty connector on the battery leads, the charger thinks the batteries are charged as the voltage coming out of the charger rises to the high level. Some chargers will cut out if this happens. It is probably not the charger.
Make sure the batteries are plugged in correctly, sometimes during transport they will get knocked and become disconnected.
Also make sure that the battery terminals are not loose where the wires connect to the batteries.
Good luck. Neil.
