Question about Husqvarna Designer I
Touch screen cable
Touch screen only responsing on one stitch
  • Husqvarna Master
  • 1,388 Answers
How do we fix a repeating touch screen on a Janome 5700. The touch seems to be ok., but the display is not.
You might try recalibrating the screen. Short of that, could be a computer screen component is failing.
Nov 13, 2016 | Janome Sewing Machines
Embriodery cards not working
the card reader may need to be checked, or the computer and the card reader are not communicating the way they should
Apr 25, 2016 | Sewing Machines
Touch screen turns on when machine is turned on but no response to go to the stitch screen.
A computer component in your machine is malfunctioning. Probably need to take it for service.
Nov 20, 2015 | Sewing Machines
Ribbon cable in sewing machine
Leave such repairs to a trained technician.
Apr 20, 2014 | Brother PC-6000 Pacesetter
I have a janome 9000 and the computer touch screen will not take me to any other stitch except stright stich
Go on line for janome machines as they have fault finding section that may be of a help. Otherwise take it to an authorised rep[airer and have it fixed It will be cheaper in the long run.
Apr 01, 2013 | Janome Memory Craft 9000 Computerized...
Hi Can u please tell me how to calibrate my Designer 1? Have not done it for a few years and now I've forgotten. Also my touch screen is only partially responding....I'm not getting any response...
Hi Vina, Since you can't get any response to your Menu-Norm-Prog-Rep-Set-or Help on your touch screen but you can get into your stitches, It does sound like you need to re-calibrate your touch screen. Normally you would get into your Set Menu to access your touch screen calibration. But as suggested on another solution. You turn off your Des 1, Holding in the reverse button (bottom left of the eight buttons) and the pivot button (the second one from the bottom of the four buttons) at the same time and turn on your machine. This is the Service menu that pops up (try not to touch anything on this screen, it could really mess things up if you don't know what you are doing) After this screen pops up go over to the eight buttons on the far left of your machine and touch the needle up, needle down button (top right button of the eight) the Calibration Screen will pop up on your touch screen (two plus marks labeled 1 & 2) In your sewing sitting position touch the center of the #1 mark and then the #2 mark. Once you've done that the Service Screen will pop back up. Shut off your Des 1 and restart it normally. Try getting into your different menus- Menu-Norm-Prog Etc. Hopefully that fixed your Calibration issue! ** Note: If the service menu doesn't pop up when trying to hold in these 2 buttons together and turning on your Des 1 the buttons weren't held in properly and you need to turn it off and try it again. Hopefully that helped you out!! Happy Sewing!! Kathy
Nov 24, 2010 | Husqvarna Designer I
My touch screen on my Designer 1 is off-kilter. You touch to the right to get the left box to work. For example, if I use the first stitch I touch the second stitch. The touch also does not work well...
You need to access the SET menu. Try pushing to the right of this in various spots and hopefully you will be able to get in to this menu. Then you need to keep hitting More until you get to "Colour touch screen adjust" . Select this (by trial and error - keep touching to the right of the square until it is selected). Now get your stylus and carefully press it directly in the centre of the crosshatches - first the one marked "1" - it should turn green - then the one marked "2" - it too will turn green. Your screen is now re-calibrated and you should be able to push the buttons and get the correct selection. If not, I think the machine should be seen by a technician. There may be problems either with the screen or the motherboard.
Oct 13, 2010 | Husqvarna Designer I
Touch screen not responsive
You need to re-align the touch screen using the following routine:
Accessing Alignment Mode:
Then you will see a text message something like
"Press + to align"
STOP
Don't touch the "+" in the text message !!!!!
The one you want will be elsewhere on the screen and all on it's own, with no text around it.
Using the non pointed end of a needle, or the spare spool pin (nothing sharp) gently but as accurately as you can, touch the centre of the +
The + will move to several more locations as it organises the height, width and orientation you give by touching the centre of the + as it appears each time.
When it is finished, turn machine off, then on as normal.
If this does not correct the issue, it may well be something else, so please, if you want any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
Jan 06, 2008 | Janome Memory Craft 9000 Computerized...
Sewing Machines Logo
142 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
