Question about Simplicity for Children 4-in-1 Convertible 3045 Bassinet
How to attach Safety Rail
I have the instruction manual.However i still cant get the rail on the side to attach.Am i using the wrong nails?I need help
  • 340 Answers
Please contact "The Hardware Specialists" at Products America. The numbers are 800-205-9642 or 800-772-1041 and their customer service reps would be more than happy to help you with any problems you are having. You can also check them out at www.productsamerica.com or www.productsamerica.net.
Posted on Jun 19, 2009
The gun won't work right
As a safety precaution, nailers have incorporated a safety foot that will prevent the gun from firing unless you push down hard. Some guns also have a system where the gun will not fire at all if there are no nails in the gun. To dry fire this type of gun you must pull back the pusher or open the side door. If nails do not feed properly, check for wrong nails, bent rails or weak pusher spring. If all is good with rails and pusher, suspect that the driver/piston is not at top of cylinder and lower part of driver blade is preventing nails from advancing. Remove airline and push the driver to top and retest. If driver is slipping down the cylinder under its own weight, replace oring. Good luck
Nov 10, 2012 | Tools & Hardware - Others
The gun will fire the first time but will jam when i try to fire it again.
Assuming that the gun will not jam with nails removed and the driver returns to top of cylinder when fired without nails. If the driver is bent the nailer will jam without nails. Jamming is usualy caused by bent driver, driver tip worn (not square), or wrong nails. If the driver is not bent and the tip is square, suspect wrong nails. Easy test. Place a strip of nails on outside of rails with the nail heads aligned with top of rail. Move the strip of nails toward the nose if gun. With the heads aligned with the top of the rail, the first nail should align with the path of the driver. If the first nail does not align with the path of the driver and the head is angled slightly away from the path of the driver, the driver may strike the shaft of the first nail pushing the nails back into the rails. If the head of the first nail is forward with the nail shaft angled back away, the nail will flip causing jam. The first nail should align with the path of the driver to prevent jam. It is difficult to find perfectly made nails that align correctly. But certainly check the nails with test mentioned above with every new box for accuracy. You might find that you will need to change brands to get a good fit. Good luck.
Nov 06, 2012 | Air Tools & Compressors
Mislaid assembly instructions trying to get a email copy if possible for "Adam Cot Bed"
Here you go: http://www.babystyle.co.uk/pdf/CalgaryCotbed_AI.pdf
May 24, 2011 | Toys
Trying to reinstall the roof cargo racks on the rails of a 01 jeep cherokee my son took off and cant remember to put on
That's usually easier to do if you remove one side rail.
There are usually six access holes in the rail that the screws go into. (pretty sure the screws are torx type) Once the rail is off, you can easily attach the cross bars and re-attach the rail to the roof. Ends of cross bars are held on with a screw that goes in from the bottom side. When replacing roof screws it is good to put a dab of silicone sealer on each screw hole to prevent rust or leaks.
Dec 29, 2009 | 2001 Jeep Cherokee
I need to remove the luggage racks from my 2007 Hummer h2 SUT
I have the same vehicle and was able to remove mine with the following steps: 1) remove light behind each rear of luggage rack rail using phillips screwdriver (one screw each side). 2) remove molding underneath each light using T20 torx driver (2 screws each side). 3) Loosen cross rails nobs. 4) Side cross rails off of roof.
Nov 27, 2009 | 2007 Hummer H2 SUT
Need to find Do Your Room Convertible Crib Manual (from Target)
Hi !!!
I also have the same crib.
I didn't have the manual but you just remove the side nails from the front part (two each side) and the front part will release with a few movements.
I also that the problem to find the toddler rail (the small one) do you find something yet?
I called Target (where I bought it) and they said that they don't sell it anymore. They give a phone number that is in Taiwan. I'm having a real trouble to find the rail to convert the crib to a toddler bed. My little daughter already fell from the crib and she had a broken arm.
Apr 21, 2009 | Baby Gear
I dont have the instructions to turn my simplicity 4 in 1 crib to a toddler bed
Install Safety Rails
Mattress support must be in lowest postition
Remove the Front Panel Contoured Top rail and Front Panel
Loosen connector pieces on the end of the leg of the Safety Rail to the End Leg using two of the Allen Bolts (11/2 in). Loosely attach the leg of the Safety Rail to the underside of the Mattress Support using one of the short Allen Bolts (3/4 in) through connectors. Tighten all three of the bolts holding the safety rail to the unit.
Repeat procedure with the other safety rail.
These are the instructions in the manual. Basically, you take off the front cross board and rail, attach the safety rails to each of the front legs. They kind of go 1/3 of the way across the front with about a 1 1/2 foot opening in the center.
Apr 08, 2009 | Simplicity for Children Ellis 4 in 1 Sleep...
Trying to turn our crib into a toddler bed
Part needed: Allen Wrench
Safety rail
Safety rail bolt
Make sure the mattress support in in lowest position. Remove the front top rail and front panel. Attach both safety rails ( small side pieces) to the crib end leg using the safety rail bolts.
Mar 25, 2009 | Delta Enterprise Baby Gear
Side rail
honest answer: take super heavy duty zip ties and tie the drop side in place in like 8 places to be sure it will stay put.
i did it with my crib to be safe when simplicity recalled theirs for rail issues, i would start with trying to get a hold of a person st simplicity for children your crib may be one of the ones recalled for rail failure issues then they would send you parts free
they should also be able to help you find out if the crib is theirs or not too
you should under the crib for a sticker with numbers, usually the model number / serial number and date of manufacture if you come up with a model number type it into a search engine online if manufacture name not on that label to find out who makes it, then contact them for pieces
hope that helped
Aug 05, 2008 | Evenflo Jenny Lind Crib
Jardine convertible crib instructions
Hi, I know it looks hard but It's really simple .just take out the screws that are on each side on the bottom and top 1 on the top and one on the bottom each side( 4 in total )(Sides not on the front) and that's it, the front part comes off and you save it for when you make the bed a full size bed wich that part becomes the foot board. Hope this information helps! Good luck!!
Jun 11, 2008 | Baby Gear
Simplicity for Children 4-in-1 Convertible 3045 Bassinet Logo
Top Simplicity Baby Gear Experts
Charles T Nevin
Charles T Nevin
Marvin
Marvin
ray gallant
Are you a Simplicity Baby Gear Expert? Answer questions, earn points and help others
