Question about Kitchen Ranges
Hello. My name is Jeff. I rent an apartment with a GE P7 Oven/Range Model Number JB500 W5. We lifted the burner elements to clean under them one day and when we went to use it afterward. There was a large arc when we turned on the front right burner. Upon further investigation, it was found that one of the wires connected to one of the elements on that burner had come free from the crimped connection and had shorted to the chassis. I have also found that the ground wire for the burner is missing about 6-8" of insulation and is bare wire. After I removed power, I re crimped the connection and tried to use the stove, but with no luck. Nothing works on the appliance at all. I also wonder if it is a huge problem that the ground wire is missing that insulation. I have removed the back panels to do a visual inspection, but nothing has been obvious to me. I have some electrical knowledge, but when it comes to vintage range/ovens, I am left in the dark. Any suggestions as to where I could start the trouble shooting process? Thanks
  • 4 more comments
  • chalnger86 Jun 20, 2009
    Thanks for the reply.  I'm not sure why I didn't receive it in my email account, though.  At any rate, I have not located a fuse in the appliance either.  I have checked the circuit and I do have 225AC at the plug.  I have continuity through the pigtail  and I can observe no burnt wires in the back of the stove or under the drip pans.  It is a rather perplexing issue since there really aren't many parts in the range to go bad.
    Jeff
    I also just took a look at the manual you were able to dig up for me.  The manual definitely has the beginning letters to my model, but my model is most definitely a lot older than the manual suggests.  My best guess is vintage 1960ish.  Everything is completely analog which would lead me to believe that this would be a relatively easy fix!  I'm going to try to do some continuity checks on the wires from the burner elements to the controls in the rear of the range.
    Jeff
    I have checked continuity from the main breakout in the back to the controls and from the controls to the burners.  I have continuity  in all those places.  The problem, I think, is not specifically with the burner controls since nothing on the stove works at all.  The oven will not come on, the clock will not work and the light in the oven won't even come on.  I'm baffled and amazed.  It is difficult to follow the wiring in t back since everything is hand wired and there's a million of them.  How do I check the controls?  I believe they are simply rheostats that adjust the resistance to the burners to control the temp of the burner.  Would I do a resistance check between each hot terminal to the common connection?
    The voltage goes from the pigtail to a terminal breakout where it then goes off to different places.  from there both legs go directly to the controls for the burners (the one that had the initial issue is a selectable three element burner with a selector knob in between the control and the burner which I checked out to be OK) to the burner and back to the control, through an indicator light and then back to the neutral terminal.  Checking voltages while the oven is plugged in would be difficult since the pigtail is not long enough to pull the stove out far enough from the wall to check safely.  (i.e. there are cabinets on either side of the stove)
    Ok.  Major revelations have been made.  First revelation is that the breaker was tripped due to another short with that same burner.  When I applied power (finally) to the range and turned the burner on, it arced again.  Could that bare wire be the cause of the arc?  It is the common lead from the burner back to the control.  My guess is that wire needs to be replaced to stop that ground fault from happening again.  Thoughts?
    Yes.  I will be heading off to the appliance store for some wire and some connectors.  I'll be replacing all the wires for that burner.  The stove is so old, that the connection point at the burner is actually a ring and screw crimped connector  for each wire.  I wish it was so simple as to just plugging and unplugging the burner.  I understand completely  what happened now.  I can't believe I really didn't get this before.  I ignored my own motto K.I.S.S.  Most people laugh, but it will help you 9/10 times.  I'll update once I get the wires replaced.  I have to leave town this weekend in a few hours, so I'll have to do it Monday morning.  Till then, thanks for the guidance.
    Jeff
  • 19,396 Answers
Hi Jeff,
as you probably already know the arching was caused by discharge between the bare wire and the grounded chassis.
To fix the problem replace the wiring harness to surface elements.
You can find all replacements for your range here.
Regards.
Posted on Jun 20, 2009
  • 334 Answers
I wouldn't worry about the ground wire, it may have been the path the short took to ground or it's just old. Hopefully your problem is just a fuse. I'm sure you checked your circuit breaker. If you have some electrical knowledge, can you use a multimeter on a live circuit?
Posted on Jun 19, 2009
  • 5 more comments
  • seth veloso Jun 19, 2009
    still looking for a wire diagram but did find the manual if you want it
    http://genet.geappliances.com/DocSearch/...
    I'll continue looking to see if there is a fuse inside but I may need you to eplain waht you see on this one
    seth
    Don't believe there are any fuses inside, its either your circuit breaker or maybe the same wire you found burned, is burned at the other end where it ties into the main power supply terminal strip.
  • seth veloso Jun 20, 2009
    OK, TRY CHECKING CONTINUITY FROM THE PIGTAIL TO THE BURNER AS LONG AS YOU DON'T HAVE DIGITAL CONTROLS. THEN CHECK FROM THE PIGTAIL UP TO YOUR CONTROLS
    I'M THINKING MAYBE YOU BLEW OR BURNED SOMETHING IN THE CONTROL PANEL
    Ok, what you need to do is find where the voltage comes from the plug up to the control panel. That may be the path that is lost or right there where the power is tying into the panel.
    that selector knob can't be getting voltage through it or to it. Is there any way you can fasten the leads of your meter to the terminal and then push the stove back in to apply power to it?
    oooo yes, I'm sorry I thought you replace the burned wire. Do not leave any wires exposed, and the burner that you cleaned, check down inside where the burner plugs in and make sure it is clean. Try that then let me know, keep an eye on that breaker lol.
How do I get to the bake element on a GE range Model JB655ST1SS?
Hello Gerald;
My name is peter. I am a retired field service appliance technician.
Go into the following website. Put in your model number. You will get diagrams, part numbers and cost. Search the internet for best price. Water Filters Lawn Garden Appliance Parts
Apr 15, 2016 | GE Kitchen Ranges
How do I clean under the electric elements on my basic westinghouse stove
Hello friend, thanks for your post!
I understand that you would like to clean under the cooktop on your Frigidaire range. Could you provide me with your model number please? You can locate the serial tag (which lists your model number) on the storage drawer on the right hand side. With this information I can better assist you. -Matt
Sep 16, 2014 | Electrolux White Westinghouse Stove Range...
OUR HOME WE BOUGHT CAME WITH A RANGE, BUT NO MANUAL, WHERE CAN I GET A COPY OF THE MANUAL FOR THIS RANGE?
You will need to find the model number to get a manual. http://www.geappliances.com/service_and_support/literature/ provides a search box for looking up the manuals. For GE ranges, the model number could be in several places: on the frame behind the warming or storage drawer or kickplate, on the left leg behind the warming or storage drawer or kickplate, on the frame of the oven behind the door, under the left front surface burner, or under the lift-up cook-top at the center or on the right hand side.
If you clean the oven with non-abrasive products and avoid the spray on oven cleaners, you are unlikely to damage the surfaces/range even without the manual for your range. (Use glass cleaners for glass cook-top.) Warm water mixed with a mild detergent is useful for most spills. Avoid cleaning the seal around the oven door; damaging the seal may cause major problems.
I hope this helps.
Jan 27, 2012 | GE Kitchen Ranges
I want to lift the cook top on GE range jbp82shss so that I can clean out all the dust. can I do this
Yes. Disconnect power to range. Open oven door and remove hex head screws at front edge of cooktop from the bottom side. Lift up front of cooktop. Burner units can then be removed from the underside of the cooktop. Be careful not to damage the gray insulating material around the burner elements if you remove the elements from the cooktop glass.
Mar 05, 2011 | GE JBP82SHSS Electric Kitchen Range
I meant to push broil, but pushed clean and my food is locked inside. How do you cancel the clean?
Look at following areas for the model number
  • Under Right Front Burner
  • Under Left Top Burner Front Or Rear
  • Under Main Top Left, Rear Or Center Front
  • Under Left Rear Or Right Front Element
  • On Nameplate Inside Burner Box
  • On Front On Burner Box Bottom
  • On Nameplate On Oven Door Liner
  • On Main Front Behind Oven Or Compartment Door
  • On Front, Center Bottom Of Burner Box
  • On Thermostat Cover Under Main Top
  • Get me the model ,number for your oven and I will be able to help you better, Thanks, Sea Breeze
Mar 29, 2009 | Maytag MER6772 Gemini Electric Kitchen...
P7 bottom element
Open the door and look for a slim, plate in the op right corner of the trim that the door would touch, if it were closed. It should be held on with 2 screws and have the model and serial numbers along with voltage. The element can be removed with a socket wrench (1/4 size), and costs about $45 delivered from pcappliancerepair.com . You'll need to unscrew the screws on the inside, back wall and then pull the element out about 2 inches, so that you can unscrew the connectors.
Jan 04, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Want to clean under stovetop
Hello
welcome to Fixya,
This stove has sealed burners and there is no need to lift or clean under anything except the burner caps.
You can not get inside the top and you can not lift the top like the old pilot stoves!
When you clean the burners and around rings do not spray or saturate the are and or the igniter element that creates the spark.I'll be back in a moment with your user manual.
first what is the complete model number of your range as written on the sticker in the door jam of the storage compartment down below. left side!
Huuum
Dec 15, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Would anybody know where the fuses are on old stoves? I have an old stove, which I am renting with my apartment. There is no brand name on it but since it is olive-green, it must go back to the 70s, if...
Hello Lucie,
If the range or oven is receiving power but doesn't work, the unit may have its own fuse or circuit breaker assembly. This assembly is usually located under the cooktop of the range. In some units, lift the top of the range to gain access to the fuse assembly; or lift the elements, remove the drip pans, and look on the sides of the cabinets. Inside the oven, look to the back to spot the fuse assembly. I would highly recommend that you remove or disable power to the stove prior to making any component changes...
If the unit has this additional fuse or breaker system, components such as the oven light, the range heating elements, the timer, and a self-cleaning feature may be separately fused.If these components or features fail to work, don't overlook the possibility that the fuses have blown. To replace a blown fuse, unscrew the old fuse and install a new one of the same type and electrical rating. If the unit has circuit breakers, push the breaker or reset button, which is usually located on the control panel.
I would think that your landlord ( since you are renting) would be responsible for the maintence and/or replacement of your stove,,,
Good Luck..
Regards,
Rick
Dec 04, 2008 | Stoves Kitchen Ranges
Oven fire
wrong call ge@ 100-851-6200 and they will help you have the model number handy before you call
Apr 21, 2008 | GE Profile 30" Free-Standing 5 Burner Self...
Kitchen Ranges Logo
75 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
