Question about Samsung LA40A450 40 in. LCD TV
NEGATIVE COLOUR DISPLAYED
Displays a correct picture for about 2 seconds then flips to a negative image.
    Top Expert:
  • Samsung Master
  • 74,383 Answers
Sounds like T'Con fault. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Posted on Apr 20, 2014
SOURCE: 1/turning the unit on the screen or panel is all white
You need to resolder the video IC processor they are one smd device
Posted on Apr 15, 2010
Mas Baz
  • 177 Answers
SOURCE: What is causing my TV to display inverted colors,
TV display inverted colors, like a negative photograph because defective panel. Mostly from T-con board. Replace T-con board.
I hope that will solve your problem.
Thanks.
Posted on Mar 10, 2011
Mas Baz
  • 177 Answers
SOURCE: picture looks like a colour negative
That problem from PCB T-Con .
Replace it.
Posted on Mar 18, 2011
SOURCE: HI I have a Samsung LN-T4661F
Is it like this?:
http://i691.photobucket.com/albums/vv275/oldskewel/samsung_LNT4661F
I think I have the same problem on my LNT4661F. I happen to also have a 4061F and just temporarily swapped main boards, which confirmed that it is NOT the main board which is bad. Swapped LVDS cables to confirm that's OK too. If you replaced the T-con board, then that leaves the power board or the panel. Did you make any progress on this?
All the caps on the power board look good, but I hear a whistling noise from one of the power transistors.
Posted on Nov 18, 2011
gopakumarg43
  • 74383 Answers
SOURCE: Picture Clarity- Seeing like a negative image
Negative image denotes a fault to its T'Con board. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
Posted on Oct 17, 2013
Negative image from lcd toshiba
You must first try to check the setting of your lcd tv if the features are set properly. Go to picture adjustment then you will see AV format select the negative function this setting will display the image correctly without distortion or picture clipping.
May 14, 2011 | Televison & Video
How to change setting picture just opposite
If opposite means that you want to rotate the image or picture for projector mount in the ceiling.
KEYS location: (keys are located back side of the projector there is 2 keys 1 for menu and second is a joystick witch have 4 arrow keys and center press is a enter key)
Press MENU button to display the menu screen.
then use joystick UP and DOWN to select the OPTION menu. Press joystick for ENTER to display the option screen. Then press joystick UP and DOWN to select INSTALLATION.
Then press joystick RIGHT and LEFT to select your required image rotation there is four type of rotations.
1. FRONT DESK
2.FRONT CEILING
3.REAR DESK (A translucent screen is required for rear projection)
4.REAR CEILING (A translucent screen is required for rear projection)
If opposite means negative to positive so there is no any setting in your projector witch is chang your picture or image positive to negative.
Jan 21, 2011 | Panasonic PT-LB60NTE LCD Projector
How do I change the battery?
  1. change-wireless-mouse-battery-1.1-120x120.jpg jQuery(document).ready(function(){ jQuery('#jsArticleStep1 span.image a:first').attr('href','http://i.ehow.com/images/a04/sq/7e/change-wireless-mouse-battery-1.1-800X800.jpg'); });
    Flip your mouse over and remove the battery cover. Gently pull it up and set it down in a safe place.
  2. Step 2 change-wireless-mouse-battery-1.2-120x120.jpg jQuery(document).ready(function(){ jQuery('#jsArticleStep2 span.image a:first').attr('href','http://i.ehow.com/images/a04/sq/7e/change-wireless-mouse-battery-1.2-800X800.jpg'); }); Carefully remove each battery.
  3. Step 3 Insert the new AA batteries into the mouse. Make sure the positive and negative connectors are lined up correctly. Do not force or jam your batteries into place.
  4. Step 4 Place the battery cover over the opening and click it into place. Flip your mouse over. If your particular mouse has a charged or not-charged display light, make sure it is showing full strength.
Mar 14, 2010 | Logitech Cordless Mouse
There is problem in getting natural colours in picture
Its problem of defective ccd imager in your Canon A95 camera and that part will be replaced.
Canon offers free of cost repair for ccd image problem in A95.
Click Canon CCD Imager Advisory for details.
Mar 22, 2009 | Canon PowerShot A95 Digital Camera
Television screen is showing mirror image not the actual image.
There's a button on the original remote control that does exactly that:
(Please vote or comment if my solution helped you!)
Adjusting PICTURE FLIP Settings
You can set the orientation of the picture.
Directly setting the PICTURE FLIP
Press PIC. FLIP to display the
PICTURE FLIP screen.
2 Press PIC. FLIP to change the
setting.
Setting the PICTURE FLIP on the
MENU screen
Press MENU to display the MENU
screen.
2 Press a/b to move the cursor to
PRESET, and press ENTER.
3 Press a/b to move the cursor to
PICTURE FLIP, and press
ENTER.
4 Press c/d to select the desired
picture flip setting, and press
ENTER.
5 Press MENU to return to the main
screen.
NORMAL MIRROR ROTATE
UPSIDE DOWN
A•
The PICTURE FLIP screen automatically
disappears in 3 seconds.
• [NORMAL]: normal image
[MIRROR]: mirror image
[ROTATE]: rotated image
[UPSIDE DOWN]: upside down image
Oct 22, 2008 | Sharp LC-15AV7U 15 in. LCD Television
Negative/inverted pictures
If the images in the camera are inverted , then could mean repair or replacement is the remedy and I suspect only replacement will be the answer.
When you say Photo Gallery- do you mean as displayed in your computer after uploading?
If so then an image editor such Irfanview or Picasa will revert them.
Jun 23, 2008 | Fuji FinePix A350 Digital Camera
Negative display on a screen
The flip models phone some times fails the display so please change the display in your nearest service center
Jun 04, 2008 | LG VX8300 Cellular Phone
I have an LCD TV. All of a sudden the picture colour has gone wierd. The best way to describe it is that it is similar to either a colour negative or one of those scientific 'false colour' images. This...
TFTs can produce a wide array of colors, but it takes an enormous number of transistors to make up a display, and a problem with any one of them creates a defective pixel on the screen. Typically this shows up as a bright spot on a dark background, caused by a damaged TFT failing to turn off a pixel. Most active matrix displays contain a few bad pixels, but a few bad pixels are not going to have much of an impact on the overall picture.
The properties of liquid crystal material can create problems with viewing angle effects, causing the image to darken, disappear, or reverse the dark and light tones when the viewer is not directly in front of the display (kind of like looking at the negative of a photo). The light bulbs make LCDs heavier than the plasma TVs (though they are still lightweights compared to CRT televisions.
Benefits of LCD TVs include a picture that can't burn in and doesn't deteriorate over time. Because of their flat-panel nature, placement options are plentiful, optimizing the cool factor over standard TVs
Apr 30, 2008 | Televison & Video
CanoScan 4400f
Keep the protective cover on except when scanning slides or film.
Jan 27, 2008 | Canon CanoScan 4400f MultiFunction Color...
My scanner doesn't scan negative
" I can only select platen as the sourc. the film setting has vanished" - I had the same problem. Unplugged the USB cable from a shared usb 2.0 hub and plugged into an old USB 1.1 dedicated port and it started working. No ideas why (perhaps in the hub it couldn't detect the scanner model correctly)
Aug 12, 2007 | Canon CanoScan D1250U2F Flatbed Scanner
Samsung LA40A450 40 in. LCD TV Logo
140 people viewed this question
Henry  Thomas
Henry Thomas
