Question about LG LSC121PMA Split System Air Conditioner
Related to cooling
My Split was installed such that the copper run between the indoor and outdoor has a number of turns although it is not necessary.Is it OK or not?My Room gets hot as soon as compressor goes off snd I cannot feel the chill effect of cooling Why?
    Scholar:
  • 101 Answers
Sounds like you have poor insulation in that room or the unit is undersized for the room it is cooling. It should not get hot quickly is there is good insulation and is big enough to do the job. Since you do not mention the age of your home/room or the size of the room, I can't be more specific. The number of turns may or may not be an issue. Depends of which of the lines are taking all the turns. Are the lines insulated? If they are overly long this could take longer to cool down but not much else if the system in full of Freon. If you do not feel cold air coming out of the unit at all and the compressor is running then check the air filter. If it is the littlest bit dirty and the unit is undersized for the room then any restriction would make it even more ineffective.
Posted on Apr 22, 2014
greenspan
  • 1734 Answers
SOURCE: LG split (3 indoor) LMU360CE
The LED #2 is only flashing while in disconnection or short in Thermistor (3 sec off / 0.5 sec on). If you want to change it, note: this is not an easy job to do! You will need to remove the top panel, then remove the control paneland then the front panel to gain access to the thermistor. The part isnot available to the public and requires an authorized service techfrom LG to take care of this problem. You will need a special tool toremove the front door seal spring clamp.
But you can call customer service @ 800 243 000 and see if theycan transfer you over to parts. Just give them the model and serial #and see if they would be willing to sell you the thermistor part. Youwill also need the door seal spring clamp removal tool to make the jobeasier.
Posted on Aug 02, 2009
  • 9 Answers
SOURCE: problem with compressor
Normaly on this units the problem is the PC boards if i'm not mistaken they have censors this censors give problems sending the unit to a Protection mode when the units works too hard sounds like thats your problem room 2 big and the High preasure presostat it's telling the unit to stop.
Posted on Jun 03, 2010
mpcheeseman1
  • 1400 Answers
SOURCE: Hi. I recently installed 1.5 T, 3 * Split AC, LG.
Hello
Sounds like the compressor is shuting down on high heat.There could be a couple reasons for this.
1 Check that proper voltage is being supplied to compressor.
2 Freon level may be low.This would be a service call.
3 Bad or intermitent connection at thermostat.
4 Main contacts to compressor sticking,usually burnt or pitted.
Posted on Apr 08, 2011
  • 413 Answers
SOURCE: AC Starts normally but after some time of coolinf
Probably overheating. Check the outdoor coil and see if it is stopped up with dust, grass etc. If so, disconnect power to the unit, and clean the condenser coil with water or air. Be careful not to bend the fins if you use a water sprayer.
Posted on Apr 11, 2011
hxn1
  • 78 Answers
SOURCE: in Split AC, implace of hot air blowing from
The 4 way valve in outdoor unit is not functioning properly.
Posted on May 18, 2011
What is the split pump
A split system has the parts split up between indoors and outdoors. A heat pump heats and cools your living space with the same unit. A split heat pump has the system split between indoors and outdoors and heats or cools your living space. a SPLIT PUMP sounds like something that has broken.
Feb 01, 2015 | Heating & Cooling
36VDC Indoor split in a 240VAC country
if you use the correct inverter and transformers
best if you just get new units designed to run in that country
Jun 23, 2017 | Heating & Cooling
My wall split a/c 24000 btu work about 1 hours or more after no cooling and u can see frost in the indoor coil and on the coppers on out door unit and i have low pressure 40
Low pressure and frost on your indoor coil with the copper pipe to your outdoor unit is almost guaranteed a low refrigerant charge. It can also be a bad metering device. You will need to check you high and low side pressures to be sure and make sure you let the frost thaw before checking pressures.
Nov 16, 2013 | Heating & Cooling
Mistral mss 1.0kw unit - When switched on the indoor unit & the outdoor compressor runs normally but the air coming out of the blower is not cool even after a long time. Is there a reset button to...
If the indoor unit blower is running and the outdoor unit fan is turning, you will need to make sure that the compressor itself is actually running and that it is not just the outdoor fan that is turning.
Get close and listen to the end of the unit were the compressor is located, also carefully feel the two copper lines, where they connect to the outdoor unit, they can be very hot - if working properly, so be careful.
There is no reset button that is easy to get to, the limits are usually auto resets, I would hazard a guess that the system is low on refrigerant and will require a HVAC tech.
But before that, make sure that the coils / fins on the outdoor unit are clean and not plugged with leaves, grass, cottonwood, ect.
You can turn power off to the unit and carefully wash the coil out with a garden hose, do not use a nozzle, as the higher water pressure can bent the fins.
As the water runs thru and drains off of the coil, watch and see if it is very dirty, rinse till the water is clean.
Restore power to the unit and try it, If it still does not work, the unit might be low on freon or the safeties might have been already damaged.
Once the unit is repaired, in the future make sure and keep the coil rinsed and free of any blockages.
Paul Gibson
Mar 30, 2010 | Sanyo 24KS32A Cool Mini Split Air...
Split unit, I get heat but no cold
I have run into this with the LG brand systems. try shutting power off to the outdoor unit to reset all units. If problem persists, it could have to do with a charge level of refrigerant (freon) or possibly a failed control board.
May 16, 2009 | Fujitsu 24R1 Air Conditioner
Displaying "Co" code, and running when turned off with the remote
It sounds like you have lost communication between the indoor and outdoor units. This can be one of two things. Either the connection indoor or outdoor is loose or bad, or a rat may have eaten the cable in cieling.
Feb 28, 2009 | LG Art Cool LA121HNP Split System Air...
York Mini-Split Not Cooling? : (
This can only be a gas problem.
the split units goes on on and off if a shortage of gas is involved, the chances that you would here it wont be that big for the fans would make too much noise.
get a repair man for a re gas and all is well.
Good luck.
Wouter.
Oct 21, 2008 | Sanyo 09KS51 Mini Split Air Conditioner
Lg split indoor fan runs non stop
Hello Hamid,
The unit is designed to run the indoor fanmotors continuously when in cooling mode on both indoor units (evaporators). The reason is that this circulates the air and the temperature thermistor or sensor is able to sense return air temperature and in turn start or stop the outdoor unit and compressor as required according to the setpoint temperature. The reason for either unit not reaching setpoint temperature can be a couple of reasons. A) Incorrect design - the unit may be too small for the application. You can calculate this roughly at 650BTU per square meter of room in a relatively warm ambient climate. Or secondly B) The outdoor unit has leaked and is short of refrigerant. You can check this when the outdoor unit is running by feeling the thicker copper tube on the right hand side of the unit. This should be cool to cold. If no temperature difference is felt, it is short of refrigerant. Hope this helps you. Goodbye
Aug 11, 2008 | LG LS-L1210CL Mini Split Air Conditioner
Not cooling
can u give me more info? have you felt of the large copper valve at the condenser? have you checked your air filter? get me a temperature reading of the large copper line and the ambient air around the condenser, and out going air of the condenser. also what is the sq. ft. of your home, and the model # of the indoor and outdoor unit. thanks J
Jul 12, 2008 | Ruud Matching Split Air Conditioner
Heating & Cooling Logo
48 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
