Question about Light Outboard Motor Boat Bass Fishing Saltwater Base
Not running I cant get my Suzuki 6hp 4stroke to run right it wonts to rev really high with the choke out then when u put the choke in and rev the motor past the idle lik it cuts out and I don't know why can anyone help us or should I book in into the shop to get looked at thx
  • What you describe is exactly what happens when a 2 stroke engine carburetor is clogged / float stuck. For that type of engine you simply use use a carb rebuilt kit, a simple repair, and all is well. I do not now if your 4 stroke is fuel injected or uses a carb, but if it has a carb and is a 4 stroke, I understand 4 stroke carbs are much more complicated to rebuild. I know this does not directly answer your question, but maybe it will get you thinking in the right direction.
Posted on Apr 22, 2014
  • 45 Answers
I would check all of your fuel delivery system first. Make sure your gas line at the motor end has pressure and that you haven't hooked up the hose in reverse ( it happens). If fuel squirts out when you push in the little ball with a pointy object, you're good. Next, I would check the screen /filter on the fuel pump and maybe clean up the screen with a little carb cleaner. If it was running good last time you used it, the last thing I would mess with is the carb.
Posted on Apr 20, 2014
2 Suggested Answers
  • 86 Answers
SOURCE: My mercury 35 hp outboard motor idle's fine but won't run
While at the river try to adjust the fuel air mixture. When you are on the water it puts the engine under a load and if that dont work then dont be afraid to bump up the idle stop screw slightly.
Posted on Aug 06, 2009
How to adjust choke on a suzuki carry
sounds like a fuel pressure/fuel return malfunction. Go to A d.i.y page on line and should be an easy diagnostic, especialy if ur getting a malfunction indicate light....check engine light.
Dec 01, 2014 | Suzuki Cars & Trucks
Suzuki outboad 6hp 4stroke
outboard motor yes ? only run in a tub or water attachment turned on before starting ! after 2 or 3 min the choke should be able to go off ! if not then remove the carb and clean jets etc with carb cleaner ! been stood a while ? fuel older than 5mths is off so replace also ! ??
Apr 20, 2014 | Motorcycles
Poulan chainsaw, I rebuilt the carb with all new everything. Now it will start with choke all the way out. Idles really high. If I push choke in, it dies instantly. The hi-lo and Idle is off I know for...
get it running on idle,adjust the idle down till it runs hairy,then adjust low speed mixture screw till you get it highest revs,then keep repeating that till you get it idling normal.rev saw up max revs,adjust high speed jet, in or out till you get max revs,then screw out one quater of a turn.That lets enough fuel thru to cool the sparkplug tip..If thats no good,redo the carbi.Check the tiny filter under the needlevalve hole.Check the needlevalve diaphragm height.recheck gaskets are right way round
Nov 03, 2013 | Husqvarna Chain Saw 20" Bar
Hi i have a ns125f it will run ok but wont ride unless u keep it above 6000rpm have cleaned carb and got right jets for it has been set up by a garage and new coil new plug but still dont work unless u...
yes it did iv fixed it now tho it was the reed had a bit missing from it so go new reeds and it runs ok but it redline a 8000 could u help me on that??it runs and drives like a dream but wont rev over 8000 and used to go to 9 or 10???i cant find the problem can u help me or point me the right way for things to check??thanks
Jul 06, 2011 | Honda NSR 125 Motorcycles
I have a kawasaki250gpxr.when i put choke on it starts up but when its warm and i take choke of it will high rev tjhen die on tick over ,but the bike rides fine
Sounds like running lean fuel condition running with choke on high rev when choke off and cutting out all points to lean condition
Get it serviced and tuned if you not confident to adjust fuel mix your self also you could try some fuel cleaner additive to your fuel tank that may clear it if is just dirty pilot circuit you might get lucky
But I would suggest get it serviced and tuned some where you trust ASAP you wont hurt anything it will just let you down when you need it AS THEY DO!!
May 22, 2011 | kawasaki GPX 250 R Motorcycles
Runs good at idle wont rev after quater thottle bogs .revs good if choke is on
HI,,,you have blocked carbs,,they are running lean,thats why it runs better with the choke on,,carbs need to be removed from the bike disasembled and cleaned.
Apr 20, 2011 | 1977 Suzuki GS 750
Motor wont rev up when starting cold with choke on trys to run on idle but will not rev up
the motor wont rev high on choke.the motor is suppose to fire once on choke. then turn the choke off.pull the start cord and the motor should start and run.check that the throttle conrol is on full. it should run fine.
Dec 26, 2010 | Honda 8 HP Engine
I recently bought a suzuki rm 125 and it wont run with out me giving it revs y is this . i cant leave it to tick over because wen i let off the throttle the bike dies????
the idle buddy is too low,on the carb is a screw the ide screw turn it in 1/4 of a turn with the bike running untill it idles the way you want it too and it will idle the pic below ill help ya buddy 34c510c.jpg
Sep 22, 2009 | 2003 Suzuki RM 125
Homelite leaf blover run with choke soon when chokeis off ,cant rev up and die
if he put fuel in it dump it out & put yours in it , if problem persist there are 2 screws on the carberator turn the 1 on the right or th bottom 1/4 turn to the left!
Jun 02, 2009 | Homelite 'Yard Broom' Leaf Blower
Light Outboard Motor Boat Bass Fishing Saltwater  Base Logo
119 people viewed this question
Top Light Boating Experts
ray gallant
fordexpert
ka4iup
ka4iup
Are you a Light Boating Expert? Answer questions, earn points and help others
