Question about Daewoo Washing Machines
Daewoo repair manual
The washing drum does not turn on wash cycle. does on rinse and spin
  • 185 Answers
SOURCE: washing machine agitator & drum spin during wash cycle
check the dogs in your agitater
Posted on Mar 25, 2008
SOURCE: washing machine will not advance through the wash cycle
Hi, Your timer motor burnt out, or timer faulty, remove top back panel (back of timer) and check timer motor, if timer motor are built-in (electronic type) you'll have to replace timer, or if timer motor can be remove, replace it, check back of timer, (knob you turn to change cycles or programs) locate timer motor, you can check appliance store to purchase timer motor, or let mechanic check, surely it's your timer motor or timer, check let me know,
Posted on Aug 12, 2009
  • 228 Answers
SOURCE: Washing machine doesnt rinse and spin
IT SOUNDS AS THOUGH ITS NOT HEATING IF IT DOESNT IT STAYS IN WASH MODE AND WONT COMPLETE CYCLE NEW HEATER REQUIRED
rylee_smith
  • 8619 Answers
SOURCE: Frigidaire FWS833AS1 - My washing machine recently
Hi
Thanks for using FixYa. The smell might be due to burning of lid switch. If the washer isn't spinning then it might be dueto a Lid switch or due to a bad motor coupler. You can check for the lid switch& replace it--
First unplug the washing machine. Then remove the two screws that hold the top consolein place; these are located in back of the main console (where the dials are).Once removed, the entire console swivels back, exposing the wiresunderneath.
After this unplug the wiring harness that is connected to the washing machinetop flat surface. Now remove the two s-shaped brackets with a screwdriver byprying underneath. This will allow you to remove the main sheet metal framearound the washing machine. The lid switch assembly is located under the topconsole. Now, remove it and replace with the new assembly and put it backtogether.
Please look this schematicfor lid switch location(part # 50)--
You can buy the lid switch from this link--
Frigidaire FWS833AS1 Lid switch/assembly
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Posted on Oct 16, 2009
SOURCE: Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Posted on Mar 21, 2010
Oko 72630. Why is it stuck on rinse cycle?
Could be several reasons:
- Selected the "Night cycle" program (means standing with the drum full of water, reason: too much noise in the spin cycle)
- Set to the "Rinse hold" (means standing with the drum full of water, reason: wrinkles on the clothes)
According to your description I think that this is not a failure otherwise error E20 will be appears on display.
Once the washing programme has come to an end, END illuminates on the programme progress display.
If RINSE HOLD was selected, the display beside the START/ PAUSE button flashes.
1. After a rinse hold, the water must first be pumped out:
- Either press the START/PAUSE button (the water is pumped out and the washing is spun according to the completed programme;
After the START/PAUSE button is pressed again, the spin speed can still also be changed during spinning), or
- Turn the programme selector to PUMP OUT and press the START/PAUSE button (the water is pumped out without spinning),or
- Turn the programme selector to SPIN or SHORT SPIN and press theSTART/PAUSE button (the water is pumped out and the washing is spun or gently spun).
At the end of this programme step, the END indicator will illuminate.
2. Open the door.
As soon as the DOOR indicator lights up green, the door can be opened.
Dado
Aug 15, 2015 | AEG Washing Machines
Machine worked fine to start with . Then stopped. Will fill water but drum wont turn on a wash cycle. And wont spin on spin cycle.But Belt seems fine. Can you help.
The pump needs to be replaced. The pump controls the agitation for the wash cycle, also controls the tub for draining & spinning after the wash & rinse cycle. The belt has nothing to do with it. Pump is very simple to remove & replace, and not too expensive, it's plastic.
Jun 03, 2015 | Washing Machines
E47 and no spin cycle on ATF8000fs1
E47 error is for the door lock assembly. Here is the part to order.
Here is a video to show you how to make the repair.
Dec 06, 2012 | Washing Machines
Rinse Light flashes on Miele W829 novotronic
Remove all the load and try to move the drum manually clockwise and anti clockwise. If you notice any friction check the motor separately and the agitator assembly separately.
It could be due to alignment shift causing a wobbly motion or a failure of the bearings.
Check these links:
http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.htmlForreplacement of bearings check for tips on this visual link: http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html.
Jul 29, 2012 | Whirlpool Washing Machines
Front load kenmore will not spin at end of wash
I have to know a little more detail before I can give you a reasonable solution. Does the washer drum fail to spin period? In other words, if you select rinse cycle manually, after the rinse cycle completes, does it fail to spin? Also, please give me the model number so I can look it up on my tech site. Thx Rick
Oct 06, 2011 | Kenmore HE2 Plus Front Load Washer
Whirlpool washer won't rinse or spin w/o manually turning knob
It is most likely that you have a faulty water inlet valve. Some machines have a seperate valve for rinse to flush in a fabric softener I suspect that your detergent flushing valve is faulty.....Good luck Nomess
Apr 23, 2010 | Washing Machines
Kenmore 80's series top loader only works on wash and rinse cycle
This is a problem with the pump being stuck so the motor cant turn the whole thing. Turn the washer on its side, underneath you can acces the pump, which is connected to the motor by two long clips. remove the pump and take out the colg that caused it to get stuck.
Jul 01, 2009 | Washing Machines
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Washing machine fault
im having the problem now with my daewoo that every time i put a wash on its giving me a H6 message error
Nov 09, 2007 | Washing Machines
Washing Machines Logo
Top Daewoo Washing Machines Experts
Paul Bade
Are you a Daewoo Washing Machine Expert? Answer questions, earn points and help others
