Question about Kenmore Washing Machines
When trying to start a wash I get error D L then F the washer
Has some water in it so I tried to drain it and I get the same error, this problem it start it intermitently, I was able to reset it by unpluging the power cord, but now is solid, please Help!!!
Let our Expert solve your problem, for FREE that's what your add says. Not only did you not offer a FREE solution for my washing machine problem, you want me to tell you how I solved my problem, well I'm going to call the Sears repair person. You should be fine for FALSE ADVERTISING. Thanks for nothing...
Posted on Jun 20, 2009
Smart Drive machine on starting, water runs straight through into drain, thus not filling up
Most likely the water coming into the washer through the Water Inlet Valve could be siphoned out to the drain pump and out the drain hose because of an issue with the pump or plumbing. Is your washer overfilling?Is the washer detecting an overheat error? Observe carefully as to what part of the washing cycle the water is draining out. By watching the washer as it goes through its wash cycle, you can find out which part or error is causing the Washing Machine To Not Fill With Water and Keep Draining issue.
Washing Machine Will Not Fill With Water Keeps Draining How To Fix
Dec 03, 2017 | Washing Machines
My front loading Crosley washing machine is showing error code 21. What does that code mean?
Can't remember the exact error code, but my crosley front loader would not spin. I found out this was because all the water was not being pumped out. I wash a lot of dog blankets and found out the drain basket was completely blocked. I was able to remove and clean from the back and this fixed my problem. I guess it could be the pump but check this basket first. The way I did it from the back was hard so I suspect there is a better way to access the basket.
Jun 23, 2014 | Crosley CW5000 Front Load Washer
Wfw9050xw00
You should check the hot/cold water from wall to the inlet of washing machine, make sure it all are corrected. I came across the case that those hose were reversed from the first installation but the owner was never use hot water until the next owner faced the issue. Else, the control board need replaced.
Oct 05, 2013 | Whirlpool WFW9050X Washer
I have a model #110.47561601, Kenmore HE2t Front load washer Type 832. I am getting a code of F-24, when I try to start the cylce. What is the problem that prompts a F-24?
Hello
F-24 is a water temp snsor error.Try running the machine in spin and drain.Once empty unplug machine for 3 min.Then try load of wash again.This time use cold water until error clears.
Aug 27, 2011 | Kenmore HE2 Plus Front Load Washer
Washing machine not draining the water
the weater pump is bad replace....
Apr 13, 2010 | Neff W5340X0 Washer
Displaying error 20
E20 is a drain problem.
Most likely is is blocked, so a good clean out is needed.
(turn off water and unplug) Pull out the machine, take outlet hose out, and clear drainpipe with a drain cleaner - then rinse through.
Clean outside of pipe, and check inside condition.
Replace & reconnect.
Try 2 cups of washing soda in the machine and do 2 hot washes to try and flush blocks through.
If this does not improve matters, you may have to strip the machine to clear the pump and outlet pipe manually.
Aug 20, 2009 | Frigidaire Affinity ATF6000F Front Load...
Neff washer dryer has error code e06 and the water wont drain
same problem, just replaced pump and cleared all outlet/inlet pipes (passed water through unhindered, still throws E06 when I try to start.
Feb 24, 2009 | Neff V4380X0 Front Load Washer / Dryer
Washing machine not starting
1 Beep/E10--Error: Water doesn't enter Cause: Water supply problem, Check kinks and faucets
1 Beep/E10--Error: Water leaks Cause: Water connections loose,household drain clog,oversudsing. Correct problems.
1 Beep/E10--Error: Dispenser drawer is open Cause: Washer will not operate if drawer is open.
2 Beeps/E20--Error: Water dosen't drain. Cause: Drain is kinked or household clog. Correct.
3 Beeps/E30--Error: Drum overfilled. Cause: Inlet valve,pressure switch or control board failure.Select drain/spin to remove water. Restart.
4 Beeps/E40--Error: Door is open. Cause: Washer will not operate if door is open. Close door.
5 Beeps/E50--Error: Motor is overheated. Cause: Wait 30 minutes to cool down. Restart.
7 Beeps/E70--Error: Cold water doesn't enter. Cause: Hoses crossed,faucet problem.
15 Beeps/EF0--Error: Oversudsing. Cause: Too much detergent,or improper detergent for machine.
15 Beeps/EF0--Error: Hot water doesn't enter. Cause: Hoses crossed,faucet problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 03, 2009 | Washing Machines
Bosch Nexxt 500 Series Washer Will Not Add Water
during a normal wash cycle the washer stopped and gave an e;4 error code
Dec 21, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
F21 Drain Problem with empty washer
Please see what I (royale) have done with my problem.
May 06, 2007 | Kenmore 46462 Front Load Washer
Washing Machines Logo
20 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
