Open the gate with remote - Televison & Video
    Guru:
  • 135 Answers
Replace batteries
you can try troubleshooting the problem by inspecting your IR emitter on the remote How to figure out if your remote control is dead or not
Posted on Apr 21, 2014
New FM502 Dual gate opener pressed remote which starts the second gate opening then the master moves a few inches stops. Hear 3 beeps 2 seconds 3-. .Conections are good to circuit board! What up!
reprogram the opening sequence in the control box
it should that the first gate opens then the second gate opens a few seconds behind it
closing is the reverse
you can program that only one gate opens
you can also program that one gate is a entrance gate where it opens until you stop it , then when you have passed through , press it again and it closes
read the operating instructions and follow the programming procedures closely
Oct 24, 2016 | Miscellaneous
I have an ET 500 gate motor. My neighbour's remote opens my gate as well when she opens her garage door. How can I change my ET receiver to prevent the neighbour opening my ET gate motor?
Most garage door openers and I assume gate actuators have jumpers or settings if computerized to change frequencies.
Both the remote and unit will have to be changed.
Larry
Aug 05, 2016 | Building Materials
Gate will open pushing open button but cant use remote
General answers only, sorry. Look for loose or corroded connections, especially where wire nuts were used. Reprogram the remote receiver. Disconnect power to the receiver for a short time. Reconnect and reprogram. I hopes that any of this helps. I have operators to the much like witch craft, a black science!
May 10, 2016 | Elite Gate Opener Sl3000 Slide Gate...
I lost my remote for my Viking R-6 gate opener. the store sold me a liftmaster 890Max remote for it but how do I program it. I can not find the learn button on the viking R-6 gate opener????
The Liftmaster remote you purchased should have come with instructions for programming unless it is preprogrammed to work with your Viking gate opener. You may have to return to the point of purchase for clarification.
Oct 19, 2014 | Building Materials
How to program a universal gate remote ?
If you still have the remote that came with the gate controller then you simply match switch positions on both remotes. If that isn't possible then you must open the gate actuator to expose the receiver in it to see what position the switxhes are in then set the universal to match. Be aware that all universal remotes may not have enough code combinations to work. If that's the case then you'll have to get the correct remote for the gate actuator.
Jun 06, 2014 | Multicode Stanley One Button Gate Remote...
I have a 2014 Audi 5. I have had no problem programming my garage opener but cannot seem to program my security gate key. I follow instruction with negative resutls. I even go to the gate and park in...
I had the same problem with my 2014 RS5. The solution was to keep pressing and releasing the gate remote until it was picked up by the Audi, instead of just pressing and holding the gate remote button. My gate has a Mighty Mule gate opener but the remotes are the same for most makes of gates.
Aug 20, 2013 | Audi A5 Cars & Trucks
How do I install the remote control
a remote control chain link gate is a common site in rural parts of the country, although the popularity is growing in more suburban neighborhoods, too. Remote control gates serve two main purposes. The first purpose is security. A closed gate is one obstacle to keep intruders and burglars off of your property. The second purpose is convenience. A remote control gate does not require you to get out of the car to open or close the gate. In rural areas, the gates also function to keep pets and livestock from wandering off your property
ceiling lights
Dec 24, 2011 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
I have a liftmaster keypad and remote and my code all of a sudden won't work.....additional question...i have an apollo gate that the lift master is wired to ... how do i set up the remote to open the...
My first inclination is that your keypad and remote have been removed from the Logic board memory.
If you have the Opener's instruction manual, then go to the programming section for how to re-program your keypad and remote.
If you do not have your manual then you can go to the Liftmaster website and download / view the manual for your particular unit. You will need the model number for your unit. That can be found near the light fixture on the unit (if you have two light fixtures, then look for a data sticker that indicates Model number and Serial number. You may have to remove or lift the light cover in order to find it.)
This is the link to the Liftmaster website: http://www.liftmaster.com/consumerweb/service/manuals/instructionmanualslanding.htm
To answer your second question, I will need to know what model of gate opener you have, and also need to know if there is a separate Receiver box unit or not. Most Gate operators will have the receiver unit built into them. Some however do not, and an external one will be wired to the gate motor unit, and possibly mounted to a wall near the gate motor. question: do you use the same remote for the gate that you use for the Garage door opener or do you have a separate remote for each? If you do, I need the model number on the remote for the gate operator. That will tell me what kind of tx/rx you have and possibly where to locate the learn button.
May 14, 2011 | liftmaster Chamberlain Garage Door Opener...
How to use 2 button remote for two mighty mule gate openers
I understanding that the chamberlin is a two button remote so as long as you have the same kind of recierver (a box hooked up in your operator that has dip switches,it recieves signals when the remote and it are set the same.) you should be able to use the two button remote on both machines. If not their is a reciever that is called multi-code and it is universal to work with all gate openers. the chamberlin remote you have will work with it.
Feb 23, 2010 | Chamberlain Clicker Universal Remote...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
