Question about Bunn Margarita Machine Ultra 2 Slush Granita Maker
Paddle does not turn what parts are needed
As above
  • Bunn Master
  • 2,237 Answers
What does the display say? the shaft has an optic sensor. if the shaft pins or the sensor board are broken, it'll say sensor error. if the torque springs are broken, replace the shaft.
Posted on Sep 08, 2014
My welbilt bead machine model 2H22 needs a replacement pan as the paddles won't turn
Parts can often be found on ebay.
Welbilt Bread Machine Parts eBay
Some brands may have been OEM manufactured under another name or use identical parts. Check for user forums on your maker and brand.
Mar 03, 2015 | Welbilt Kitchen Appliances - Others
Piece that connects to motor and then paddle fell out
Yes, the C-clip holds the shaft for the paddle in place. I think the only relevant replacement part is the entire pan. Expensive!
Dave Kristol
Mar 23, 2017 | Breadman TR2500BC Bread Maker
It won't knead :(
Hi and welcome to FixYa, I am Kelly
When you reach in the bottom of the unit with the bread pan installed is there resistance felt as you move the kneading paddle in either direction? Yes = Motor problem No = belt or kneading paddle problem. (Since this a twin paddle machine they both must move at the same time)
The belt can be found here: PN: 8-BBV-P540
http://www.thegourmetdepotco.com/items/?item=2131
The paddle can be found here: PN: 8-BBV-P290
http://www.thegourmetdepotco.com/items/?item=1550
The manual: (6.83 mb)
http://www.zojirushi.com/servicesupport/manuals/manual_pdf/bbcc_x20.pdf
If you need parts other than above contact their customer service using the number below.
Customer Service:
If you have any questions, please call ZOJIRUSHI Customer
Service Dept. at (800) 733-6270 or (323) 722-1700.
Thanks for choosing FixYa,
Kelly
Apr 07, 2011 | Zojirushi BBCC-X20 Home Bakery Supreme...
The part that the kneading paddle connects to in the machine is not working. Will not turn the kneading paddle
Hi, The sealed bearing that the paddle shaft fits through is frozen and has failed. You could try filling the pan 1/2 way with hot water for a few times to see if it turns but otherwise a new bread pan is needed. Hank
Nov 09, 2010 | Black & Decker Kitchen Appliances - Others
The machine gets warm but the paddle doesn't turn.
Hi, The paddle should turn freely by hand with the bread pan out of the machine. Make sure the pan is inserted in the machine correctly. If the motor shaft turns but the paddle doesn't then the sealed bearing that the paddle rotates on has failed and is frozen so the paddle does not turn.. You may need a new bread pan. Hank
Jul 01, 2010 | Kenmore KTR2205SPR Bread Maker
I need to replace bread maker paddle
Your model number for the all in one pro should be a B1650 (single paddle model)
If that is correct then this is one source for the paddle:
http://www.abtecparts.com/commerce/search/products/?product_id=01XBD42959200&merchant_id=1933
An informationl note about Black and Decker products is that there are replacement parts for anything they make as long as they have no discontinued the model number. Once the model number is discontinued they have aftermarket replacement parts for 5 years only.
(your replacement paddle is starting to show up as no longer available)
The orignal paddle part number is: 429592-00
Here is a 2nd source for the paddle:
(96 in stock)
http://www.radioequip.com/servlet/the-Home-Appliances-cln-Black-and-Decker-cln-Bread-Makers/Categories
Thanks for using FixYa:
Kelly
Apr 23, 2010 | Black & Decker B1561 Bread Maker
Need a paddle for a Cookworks Breadmaker
Had the same problem. Phoned Argos' customer servies and have just bought one through them for £7.50 (incl p&p).
Hope that helps.
Jan 17, 2009 | Kitchen Appliances - Others
Bread paddle isn't "strong" enough to knead
Hi bex_ta,
If the paddle doesn't have the power to knead, you're probably losing torque at one or more of several points:
1) Where the paddle attaches to the shaft (is there evidence of slippage/wear in the paddle socket?),
2) Where the shaft goes through the pan (possible friction point - presumably this is what you oiled)
3) The belt might be slipping, either due to friction in the shaft, or because the belt is worn and loose.
You need to determine if the shaft is sticking, and if it's because it's bent (fairly unlikely) or if there's something fouling it. You'll need to isolate and fix that first. If you can rotate the shaft freely, then we look at (1) and (3) above - these are simple parts replacements, but the shaft would be more involved.
Belts are getting tough to find - if you can provide specs/measurements, I'm going to start contacting a small-run manufacturer to see about making some new belts, as I'm seeing multiple online requests for belt parts. If you happen to have a broken one, I'd like to get one as a sample to send to a manufacturer.
If I can be of further assistance, or if you have questions about any of my response(s), please let me know before rating me.
If this solves the issue, please rate it accordingly. My goal is to earn a "FixYa" rating from everyone I help.
Thanks for using Fixya.com,
Jon
Dec 08, 2008 | Regal Ware K6725 Kitchen Pro Bread Maker
Error code
C11A0
Paper holding drive
failure
• The exit paddle home position sensor (PC6) is not turned ON
even after the set period of time has elapsed after the exit
paddle solenoid (SL2) is activated (beginning of paddle
retraction operation).
OFF even after the set period of time has elapsed after the
exit paddle solenoid (SL2) is activated (beginning of paddle
paper-holding operation).
This will probably need parts as the paddle assembly is likely to be broken.
Nov 20, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
Replacement mixing paddle for cbm 310 automatic breadmaker
07XTM34923 AbtecParts.com
Toastmaster Bread Machine part - works great, according to other website
I ordered mine today
Feb 13, 2008 | Magic Chef CBM310 Bread Maker
Open Questions:
See all Bunn Margarita Machine Ultra 2 Slush Granita Maker Questions
Kitchen Appliances - Others Logo
100 people viewed this question
Top Bunn Kitchen Appliances - Others Experts
jasbo
jasbo
Kelley Hopper
Jerry Greenberg
Jerry Greenberg
Are you a Bunn Kitchen Appliances - Other Expert? Answer questions, earn points and help others
