Question about Makita BMR100 Radio
How to bypass the dc conction on a makita radio
The battarie shows it is allways empty
Makita DC9700 charger output listed as 9.6 v.Meter shows 16.43v across+ - terminals.Problem??
Its good that charger is made to fitted different types of dc voltage batteries thats the way of more or less voltage it is automatically measured by the used battery.
Jul 21, 2014 | Makita Tools & Hardware - Others
Makita radio stoped working
mine shows 'E' on display. was sent away to be tested by Makita they said nothing wrong, faulty battery. bought new battery, still doesn't work. Makita not pulling their weight
Jul 04, 2014 | Makita BMR100 Radio
try to empty the battary and after a 15 min charge the battary and try to reboot.
May 17, 2014 | RaueSoft Reboot Manager Widget
Nokia c1-01 power on after few second display on show battary empty than power off
Try pulling the battery out and putting the battery in the freezer for 24hrs. Has worked for me before.
May 07, 2014 | Nokia C101 Cell Phone
I have a clevo m761su , when i turn on, the 3 leds on the front (capslock,numlock...) keeps blinking then teh laptop turns off.
make sure that battary is charged , the blinking leds in some laptops is usually a sign for empty battary.
Feb 07, 2012 | Computers & Internet
Letter E comes up when switched on, I have changed the batteries but still the same
Check the black DC connection on the little supply board. Connection is open.
Sep 13, 2011 | Makita BMR100 Radio
Hi I have a Makita BMR 100, the clock display is working but everything else is not. The original battery is a 18 v ni cad, also tried a 14.4 lithium iron but still no luck. am about to have a look...
Check the black DC connection on the small supply board. Bypass it. Put external 12V DC on the supply board (white and blue wire, I thought).
Sep 07, 2011 | Makita BMR100 Radio
Turn on the letter e comes on the display
DC from the battery is not passing thru the small black connection on the supply board. Bypass it. Check radio with external 12V DC supply.
Aug 03, 2011 | Makita BMR100 Radio
Nokia 5130c2 show charging but not charg battary and discharg battry
nokia 5130c2 show charging but not charg battary and discharg battry
Jan 09, 2011 | Cell Phones
Makita BMR100 Radio Logo
Top Makita Audio Players & Recorders Experts
Gil Shultz
Are you a Makita Audio Player and Recorder Expert? Answer questions, earn points and help others
