Question about SIRIUS XM Radio XM SkyDock
After engine stopped screeching noise for 4 seconds
Carstarts 1 vsecond then stops with loud screetching noise only rund a second then screech any idea what wrong?
either the water pump or alternator is seized up and belt is screeching . see if you can turn pulleys by hand
Sep 08, 2015 | Cars & Trucks
Engine screeches when running. revving the motor makes it stop momentarily
Could be a belt screeching. Fan belt, A/C belt, Serpentine Belt, alternator belt, etc. Easiest way to isolate which belt is to open the hood and use your ears to see where the screeching is coming from. Left, right, front, behind the engine? Spray some WD-40 on the belt you think is making noise and if it quiets right away, then that is the belt making the noise. Either the tensioner needs adjusting or the belt needs replacing. The WD-40 does not hurt the car, it'll start screeching again in a few days when it wears off.
Sep 30, 2013 | 2005 Chevrolet Express Cargo
Galaxy ace makes screeching noise when calling
try to reflash your phone because it mustnt hardware problem
Jan 29, 2013 | Samsung Galaxy Cell Phones
I have got a 2003 Mazda etude 160 ie and recently changed the clutch and pressure plate. There is a noise coming from the engine and whenever i press the clutch (even slightly) the noise stops. Could this...
You posted this question in the "Tripods" area of FixYa. Please repost in a more appropriate area so that the proper experts can see it and give you a solution.
Sep 26, 2012 | Sima B00006jq6c Universal Quick Release...
Obnoxious screeching sound when the drum turns. Short consistent screech on revolution, which turns into one long non-stop screech. Stops after 45 seconds or so, then starts all over again with longer...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Sep 05, 2010 | Fisher and Paykel DEGX1 Electric Dryer
Screeching noise after water starts going in
Hi just read your posting.Now put the machine to a spin cycle and push start,Does the noise happen in this cycle? If the noise doesn't happen then try a cold water fill but turn the hot tap off first.If the noise still doesn't happen then try a hot water fill but turn the cold water off first. This noise sounds like one of your water valves is faulty.Please reply with additional information on the questions and I am sure we can rectify this fault.
Jul 07, 2010 | Fisher and Paykel GWL11 Top Load Washer
Loud screeching noise coming from car after stops.
the screeching noise is most likely caused by a slipping belt or pully. transmission probably needs fluid and filter changed.
Jun 02, 2009 | 1990 Ford Tempo
98 gs300 loud screeching noise that last for about 5-10 seconds
The only four rotating items under the hood are
engine
power steering pump
A/C compressor
and smog emission pump.
==== I would check the fluid level on the power steering first. Check for pink fluid leak on the ground,
==== Check the A/C system with the wheel turn to one side and APPLY ALL LOADS.
Example: high beam on,A/C max,radio on and deforster on.
This will give you system a stress test.
All eyes on the pully and locate to part that generate the loud screeching noise.
My bet is on the power steering pump.
Please post more info on the comment window.
I will follow up on it.
Feb 12, 2009 | 1998 Lexus Gs 400
SIRIUS XM Radio XM SkyDock Logo
74 people viewed this question
Top SIRIUS XM Radio Apps Experts
Erin Wood
Erin Wood
Are you a SIRIUS XM Radio App Expert? Answer questions, earn points and help others
