Question about Uniden BCD996T Base Scanner
My pc is not recognizing the scanner
I've installed a program that should include the software to run
the scanner - but I'm having problem with the scanner - I have it connected with a USB Serial-Controller
  • 4 Answers
In your printer and fax folder you probably have more than one printer installed and your default printer is not the one you just installed, Select the printer you just installed and set it as your default and try again
Posted on Jun 19, 2009
How do i install epson stylys TX410, i've lost the disc
What OS is running on your computer? Epson has the drivers/software available on their site: http://tech.epson.com.au/downloads/category.asp?sCategory=Multi_Functional&id=StylusTX410&SelOS=Y . Download and install the appropriate software before connecting the USB cable from the printer to the computer.
Note: the software from this site does not include any third-party software that may have been on the original CD.
I hope this helps.
Oct 20, 2012 | Epson Stylus Multifunction Inkjet Printer/...
Hi! My computer (Macbook pro) doesn't seem to recognize my Nikon Coolscan IV software and I get the following message
You've not said what the message is but I suspect that the software is too old to be used on the macbook if it is running OS X 10.7 (Lion) or if you are running snow leopard, it may be a non-intel version of the software. It may be asking you to instal rosetta which would be on your snow leopard instal disk.
If the Nikon website does not have updated software you could try vuescan which according to this page http://www.hamrick.com/vuescan/nikon_coolscan_iv_ed.html does work with the film scanner and you can download a demo version which you can trial before you buy. Hope this helps.
Jul 02, 2012 | Nikon Coolscan IV ED Film Scanner
My PC (running XP) says it doesn't recognize my scanner or its software, but I did the installation properly and it shows up on my list of installed programs.. It is supposed to have OCR built in and I...
Did you go to Device Manager to check if driver is correctly installed ? If you see a yelllow triangle next to the " imaging devices " , go to it and delete ( not only uninstall ) driver .
Now disconnect scanner and go to the Control Pannel \ programs and delete the software . I preferably use a cleaning tool for this such as the free version of Revo Uninstaller from http://download.cnet.com/3001-2096_4-10687648.html?spi=813daf819502a35822c69ef942f383fe
Reboot . Do not connect scanner yet . Download and install correct and latest version of HP scanner's software from http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=298549&lang=en&cc=us&prodTypeId=15179&prodSeriesId=298547&taskId=135 .
Reboot . Wait for Windows to be completely settled . Connect scanner and wait for confirmation of successfull instalation of driver .
Regards .
Jan 01, 2011 | HP scanjet 3970 digital flatbed scanner
I have a kyocera cs-1650 and am trying to scan to pc. I have scanner file utility installed, yet it shows no connected scanners in the status box. How do I get scanner file utility to recognize and...
You have to make a folder on you computer to scan to. you have to configure the scanner file utility with the path to that folder. You have to setup the scanner NIC with a sender ans a destination. The destination has to point to the PC running the scnner file utility by inputting the computer hostname or IP. The scanner nic can be configured with your web browser by putting the scanner NIC IP in the address bar. You have to make sure your firewall is not blocking the file scanner utillity. For more help go to www.gfbm.net.
Dec 31, 2009 | Kyocera Copystar CS-1820 Black and White...
Camera Kodak EasyShare C140 was tested in a Kodak representant and worked OK including the transference of photos to the computer however when trying doing the same at home I receive an advice "ESApp.dll...
Last options that you can do is to reinstall the Software.
First check the compatability of Easyshare, Right Click the icon on your desktop and click compatability tab, then remove all check marks under that tab.
Remove the Easyshare Software from the Control Panel, Add Remove programs
Then Run the clear utility software from the web at this site
www.kodak.com/go/clear
After that restart the PC
Then try reintalling the software from the web
www.kodak.com/go/easysharesw
Make sure that there are no other devices connected to your PC while installing the software, including printers and Scanner.
Aug 26, 2009 | Microsoft Windows XP Home Edition
Scanner no longer communicates with the pc
Have your scanner turned on when you boot up your computer. Go to Programs, Acessories, Scanner and camera wizard, and it will give you directions if the scanner is not installed and recognized.
Aug 21, 2009 | Pacific Image PrimeFilm 3600u Film Scanner
Mustek Scanexpress A3 USB scanner stopped working
my scanmagic 1200ub is recognized by my pc but i keep getting a message saying"cannot locate component.could it be that particular port?
Mar 29, 2009 | Mustek A3 USB Flatbed Scanner
Vupoint FS-C1-VP scanner installed
i have vista home and mine worked fine until i installed a web cam and then it just gave up. But now it works great - here is what i did
unpluged both the scanner and the web cam
uninstalled everything to to w/ the scanner and the web cam.
Installed the driver from the CD and restarted my machine
Install the Photo 6 software
plug in the scanner - works like a champ.
have not reinstalled the web cam
Oct 02, 2008 | Office Equipment & Supplies
Hp scanjet 6200c scanner recognised only as printer by pc
Download this program that will help you solve the problem.
Click here
May 27, 2008 | HP ScanJet 6200C Flatbed Scanner
Computer does not recognize scanner
ensure that the scanner is compatible with the operating system you have installed on your pc,as some older scanners are not with XP & vista
good luck
Terry
Mar 05, 2008 | Microtek ScanMaker s400
Uniden BCD996T Base Scanner Logo
135 people viewed this question
Top Uniden Radio Communications Experts
Steve
eradiostore
eradiostore
Marvin
Marvin
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
