Question about Whirlpool Washing Machines
Washer is diplaying F 20 - Whirlpool Washing Machines
  • 135 Answers
6 Steps to fix F20 washer problem.
1.After a time the small hose that comes from the pump area to the pressure switch located at the top of the machine can clog.
2.Unplug the machine.
3.Remove the top or the back of the washer.
4.Locate the pressure switch near the top of the washer. It is about 4 in round and has wires and a 1/4 inch black tube attached to it.
5.Pull the tube from the switch and blow through the tube until clear.
6.Reassemble, plug in and test.
Posted on Apr 20, 2014
My machine diplays an error code SUD during cylce and stops. I have to restsrt it
This usually means too much soap or the incorrect soap if it is a HE washer you only need enough to coat the clothes and FYI never use non HE soap in HE washer the difference is regular soap suds up too much and HE has less sudsing ingredients hope this helps
Apr 16, 2016 | Samsung Ecobubble WF80F5E5U4W White 600 mm...
How to solve erro code of p-20
Before anyone can help you, you need to include information about what printer brand and model you are using.
Feb 22, 2013 | Office Equipment & Supplies
GWL11 washer diplay won't light up or power on. drain pump leaked, replaced both, still nothing
your main board is out very come with a bad drain pump the new pumps and boards come with a fuse to stop this problem. water hit the pump and shorts out the board
Aug 13, 2012 | Fisher and Paykel GWL11 Top Load Washer
Due to an unidentified problem, windows cannot diplay windowa firewall settings.
most likely something interfering
try running Malwarebytes
www.download.com (on the top 20 list)
Jan 22, 2011 | Microsoft Windows XP Professional
When using the dryer I constantly get the 5e error flashing. What do I do to fix it?
An SE is caused by a temporary sensor error. If this error code is diplayed, turn off the power to the washer and unplug it.. After 10 seconds, plug it back in and attempt to restart the washing cycle. If the problem persist, the unit may require service.
Dec 31, 2010 | LG WD-12126RD Front Load Washer / Dryer
F 12 whirlpool 6 th sense washing machine.
hello,
simple ,The "F 12" error code is an indication of a water temperature sensor error. There is a chance that there is a loose wire connection on the water temperature
what you need to do to fix up your washer is to check on the wiring connection from the power supply to the water temperature indicator.
thank you and thanks for using fixya.
Jun 01, 2010 | Whirlpool AWM8143 Front Load Washer
Washer is diplaying Ld and won't restart
Ld stands for long drain.
Here is what the manufacture says about that error, my comments will follow.
LONG DRAIN If the drain time exceeds eight minutes, Ld will be displayed, the water valves will turn off, and the pump will stop running.
Press PAUSE/CANCEL to drain the machine. The display will be cleared and the machine will turn off after a maximum of eight minutes. Possible Causes/Procedure
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check the drain pump filter for foreign objects, and also make sure the hose from the tub to the pump is not plugged or kinked.
4. Check the electrical connections at the pump and make sure the pump is running.
5. Plug in2_bing.gif washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Phil's comments -----> This error is usually due to something getting stuck in the drain pump or drain hose, typically after washing a rug with a rubber backing that has come off or small articles like baby socks that were not put into a garment bag prior to washing.
To clean out the pump the machine would need disassembled and is best done by a service professional unless you are up for a good challenge.
Apr 20, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
I'm getting an OE error on my LG washer diplay
You are likely using the wrong kind of detergent and the suds are not being washed away.
Use high-efficiency detergent and/or lessen the amount of detergent you are using.
Jun 05, 2009 | LG WM2487H Front Load Washer
Have front load washer kenmore elite getting 2 codes dl f and it beeps
that is a door lock failure its actually one code just not enought room in the diplay. recommend changing the door lock assembly here is a place to get that Door Lock Assembly. Washer Parts
Apr 26, 2009 | Washing Machines
Washing Machines Logo
19 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
