Question about Brother BRTPT65 PT-65 Label Maker Printer
Brother pt 65 too much tape feeding
Too much tape at end
2 Suggested Answers
komguy
  • 2306 Answers
SOURCE: Tape on Brother PT-65 wraps on roller
If the end is already messed up you may need a new cartridge, if you can remove the tape and feed the end under the guide on the cartridge and re-install it should work properly again.
Posted on Sep 17, 2009
What is the reason the tape won't play on sa-ak95
It may be the tape(s) themselves. Pre-recorded cassette tapes are usually no problem for most players, but many user-recorded tapes were of the C90 or C120 variety. These cassettes use much thinner tape in order to get the recording time. This can cause the tape, after many starts and stops and partial fast-forwards and rewinds to get tight on the reels. This will cause the tape sensor to think that the tape is at the end of the reel when it is not. Sometimes rewinding from end-to-end will help, but not always,
Nov 07, 2014 | Microwave Ovens
P-Touch Model PT-65 Home and Hobby Label Maker - Loaded a new cartridge and it will not feed through
Sir/Madam
Its Very Easy To Fix This Issue,Just Follow Few Simple Step and You Solve Your Problem By Your Own,
Read Below Instruction,
1Turn off the label maker before installing the tape.
2Press the part marked as "<<" and lift the cassette cover.
3 Position the tape into the slot. Make sure to feed the end of the tape under the tape guides.
4Check that the lever is up before closing the cover; the cover will not close if the lever is pressed down.
5Close the cassette cover.
6 Press the power key to turn on the device. If using an AC adapter, plug the adapter into the wall then press the power key.
7Type a sample to test if your installation was successful.
Read more: http://www.ehow.com/how_7526530_install-tape-ptouch-label-maker.html#ixzz2pMqUU0oU
Jan 02, 2014 | Brother BRTPT65 PT-65 Label Maker Printer
Switches direction without reason
It thinks it has reached the end of the tape and should play the other side.
Here's what to do: take the cassette and slam it (gently) against a wall or desk. Turn it over and do it again. This loosens up the tape pack.
Then fast forward the tape all the way to the end and then rewind it all the way to the other end.
Before you play the tape make sure the cassette screws are tight. And make sure your tape heads are clean .
May 16, 2012 | Audio Players & Recorders
How do I connect my CD Player, Tape Deck and Tuner to the SU 300 Technics Amplifier
hi,
For connecting these to your amplifier you need 4 Stereo RCA Cable.
1.Connection for cd:
Take one of the RCA cable connect the one end (red/white) jack to the line out of your cd and connect the other end (red/white) to the CD input of Your amplifier.
2. Connecting the tunner:
Take one of the RCA cable and connect the one end (red/white) jack to the line output of you Tuner and connect the other end (red/white) to the TUNER input of your amplifier.
3. Connectiong the tape deck:
Now you have two RCA cable. Take one of the RCA cable and connect the one end (red/white) jacks to the PLAY out of the Tape deck and connect the other end (red/white) to the TAPE 1 play input of your amplifier.
Now connect the last RCA cable. Connect the one end (red/white) jack to the record input of the TAPE deck And connect the other end (red/white) to the TAPE 1 Record input of your amplifier.(this connection will help you to record to tape from cd or tuner. if you are not interested in recording then you can avoid this connection.)
Now you can select these three items from the frond plannel control switch of the amplifier.
ok
Jul 28, 2011 | NAD 218THX 2-Channel Amplifier
How do i get a piece of tape out of my disk player, it stuck in there from i disk i made. could i take out the panel some how and look at it from the top.
If you can see the tape, try using a piece of stiff wire with a strong tape (strapping tape or duct tape) fastened SECURELY to the end otf the wire. Get the sticky side of the tape at the end of the wire onto the sticky side of the tape inside the player; tape sticks to tape incredibly well. Gently pull the offending tape out of the player.
Jun 26, 2011 | Chevrolet Uplander LS Cars & Trucks
I have a Brother label maker, model number pt65. How do I install the tape. I cant get it to feed through. Thank You
1) Remove the back cover by pressing in on the rough
area at the top end of the machine and pulling off the
back cover.
2) If a tape cassette is already installed, pull it straight out
and remove the paper tab from the new tape cassette.
Make sure that the end of the tape in the new cassette
feeds under the tape guides.
3) Insert the tape cassette, making sure that it clicks into place.
Check that the cassette fits properly around the two
metal guides in the cassette compartment.
4) Attach the back cover by inserting the two hooks on the
bottom end of the back cover into the slots on the bottom
end of the machine, then pushing down firmly on
the cover until it snaps into place.
5) Feed the tape by holding down and pressing ,
then cut the tape by pressing in on the tape cutter button.
The amount of tape remaining is visible through the
window in the back of the P-Touch.
When the usable tape is finished, green ribbon appears
Hope this helps
Bruce
Jun 14, 2011 | Office Equipment & Supplies
Sep 15, 2009 | Brother PT-65 Personal P-Touch Electronic...
How do i load tape in pt 65?
Remove back cover by pressing down on dots. Make sure you have the correct size replacement (they start with an M and are 9mm or 12mm).
Put the side of the tape that has the open V in it over the silver metal holder in the PT65. Snap the left side of the cartridge in. This should line up the black roller with the exposed part of the tape.
Snap the lid back on and turn on the unit. Hold the CODE button and press the space bar so some of the tape feeds out of the top.
Apr 23, 2009 | Brother BRTPT65 PT-65 Label Maker Printer
Brother BRTPT65 PT-65 Label Maker Printer Logo
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
