Graphic equalizer i connected my dvd player to the mixer and out through to the equalizer into the amplifier, but there was no sound coming out through the speaker and none of the machine is not working, the mixer is behringer x1222usb graphic equalizer is soundgraph 6012 the amplifier is PA-9200 my english is not good, i hope you can help me, with which wire goes into what place between these sound controller and the name of the wire name. Thank you for your help.
    Champion:
    New Friend:
  • 231 Answers
You connected your dvd player to WHAT mixer?
Connect your DVD to any one of your LINE IN jacks and your equalizer to one of the TAPE IN-TAPE OUT loops.
Posted on Apr 20, 2014
marsrover
  • 682 Answers
SOURCE: How to connect a Technics Graphic Equalizer to a JVC stereo system?
your situation is not so easy to solve but the ideal solution to connect everything to mixer(line in) and connect equalizer to main inserter in mixer(in this you got equalizer work with all media)(check mackie mixer dealer and ask about model have main inserter.
Posted on Jul 19, 2008
marsrover
  • 682 Answers
SOURCE: using graphic equalizer on a Pioneer CD player
try to connect it in tape in-and confirm that you select the right input in the receiver(in our situation you will select tape as input source).
Posted on Dec 04, 2009
  • 61 Answers
SOURCE: I've never used PA systems or vocal setups.
Hi, the speakers are unpowered, but that desk is also unpowered, so you need an amplifier in the circuit. This can either be in the desk, in the speaker, or a separate device, there are advantages to each.
Posted on Dec 19, 2009
caroldon
  • 17130 Answers
SOURCE: how to wire up kenwood ge-760 graphic to my
First of all connect the source, the tape or the DVD, to the input of the equaliser, use the output to connect to the AUX of the amplifier. make sure that the L&R are not crossed over. In case your amp has an in and out of the preamp section use then connect the source to the amplifiers input specified for the source like tape or DVD or TV and use the preamp output to the equaliser input and the output of the equaliser to the input of the main ampflier. Now the bass and treble of your amp can be set to the mid point - 12 noon position and use the boost or attenuation according to your choice of music. hope you find my advice helpful. Good day
Posted on Jul 21, 2010
cjsound
  • 26 Answers
SOURCE: pls send me a connection diagram of how to connect
ftp://ftp.dbxpro.com/pub/PDFs/Manuals/English/dbx2SeriesManualA2.pdf It's all in there. Here is a little extra guidance. if you are getting your left and right channels out through RCA you will need a RCA to 1/4 in adapter Radio Shack carries them relatively cheap. If it's already 1/4 or XLR skip this Left goes into Left in, Right goes into Right in. Then work backwards Right comes out of Right out, Left comes out of Left out. channel 1(left in) and Channel 2(right in) of your powered mixer. you should be set.
Good Luck, Cody J.
Posted on Dec 17, 2010
I no nothing about hooking these things up my mixer is un powered mixer so i bought a 1200 watt amp to power it mixer yamaha
Humm??? a mixer in a car ?? what a concept !! could bring an entire new dimension to "air guitar on the freeway " but might you mean an equalizer ??? if so its easy to connect a equalizer before the amp as it comes from car stereo , the round "rca" jacks are the best way to do it if you have the means !! then its a simple wire out to each speaker and whoola !! you got sound !!
Nov 22, 2016 | Car Audio & Video
How to hook up a 7 band pioneer equalizer great 470 to a Kenwood kr-v6030 receiver
Connecting an Equalizer to a Receiver Before beginning, purchase RCA cables. In order to run the signal from a stereo receiver to the graphic equalizer and then on to the amplifier, two sets of RCA cables are needed. These are basic cables used to connect auxiliary components like record players and CD players. The length of the RCA cables should be about the same length as the distance between the receiver and equalizer.
1. Connect Graphic the Equalizer to the Receiver
The first step in this setup is to connect the graphic equalizer (EQ) to the receiver. Most receivers will have preamp-in and preamp-out connections. Some have tape monitor connections. It's preferable to connect the EQ to the preamp-in or preamp-out because the tape monitor won't allow for connection to the amplifier as well.
2. Connect the RCA Cables
The first set of RCA cables should connect the receiver and equalizer. Connect one pair to the preamp output channels and the other end to the left and right input channels on the EQ. These are on the back side of the equalizer. Usually, the colors will correspond to the RCA plugs. That means connect the red plug to the red jack and the white plug to the white jack. Then connect the second pair of RCA cables between the receiver and the amp. Match the colors in the same way.
3. Connect the Amp to the Receiver
Now the amp can be connected to the receiver via RCA cables in the amp inputs on the receiver. This will create a loop from the receiver through the EQ and amp and back to the receiver so that all three units are connected.
4. Test Graphic Equalizer
Turn on the receiver, amp and equalizer. Once they are powered up, try controlling the sound with the equalizer knobs. They should fine tune the music according to your preferences. It's easy to change the frequency response or tone of the music with the equalizer knobs.
May 09, 2016 | Pioneer Audio Players & Recorders
How do i set up a Peavey xr560 mixer and graphic equalizer
PUT OUT PUT EQUALISER IN INPUT RETURN PUT IN PUT EQUALISER TO OUTPUT MIXER
OR JUST PUT EQUALISER BETWEEN MIXER AND AMPLIFIER MEAN OUT PUT EQALISER TO IN PUT AMPLIFIER AND INPUT OF MIXER TO OUT PUT OF MIXER
Oct 12, 2014 | Peavey Audio Players & Recorders
Studiomaster manual
On the rear panel there are two jack socket marked: Left and Right Insert.
These are connected to the graphic equalizer using two insert cables, one for each channel ( L & R). The cables have a stereo 6.35mm jack plug which plugs into the mixer, the cable splits into two mono jack plugs marked tip (or send) and ring (or return). The send (tip) connects to the input of the graphic equalizer and the return (ring) connects to the output of the graphic equalizer. How it works: The stereo jack interrupts the signal in the mixer and sends it to the equalizer, the equalizer processes the signal then sends it back to the mixer. Typical cable is shown below. If the equalizer has a different type of socket, phono for example you will need jack to phono adapters or insert cables with suitable plugs. Hope this helps.
Apr 05, 2014 | Audio Players & Recorders
Technics su-a808 amp & sh-ge70 graphic equaliser.
connect your media source(dvd-cd player)to equalizer in-connect equalizer out to amplifier line in-or aux in-connect amplifier out to your loudspeaker.
Jun 24, 2008 | Audio Players & Recorders
How can I make this sound great.
line out from mixer------to crossover in---------crossover out-------to amplifier line in-----------from amplifier out--------to loud speaker.
---from low output(low frequency)of crossover-----to line in in subwoofer.(mixer is ordinary mixer not powered mixer- and in case of powered mixer take care it is line out(0db---to4db)not amplifier out which you connect it to loudspeakers.
May 19, 2008 | Digi-Tech DOD-Digitech 231 - 31 Band Per...
How do I install my pioneer stereo?
this way should work : connect the OUTPUT of stereo ( ke-4535) to the INPUTS of GRAPHIC EQUALIZER ,then the speaker outputs of the GRAPHIC EQUALIZER to speakers , in this order you have control to adjust the sound coming from the PIONEER stereo . hope this helps
Apr 25, 2008 | Car Audio & Video
103 people viewed this question
 Grubhead
Grubhead
