Question about Lands Phones
Fs 29639 remote phone adaptor setting required. Is it 9 V or 6 V?
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 41 Answers
Look right by the hole... The info will be there
Posted on Apr 20, 2014
Where can I find an adaptor to fit a Hohner Keyboard PSK75 9 volt
You can actually use any 9 Volt adapter, as long as the adapter's Amp rating is higher than what the keyboard requires, and the polarity of the plug corresponds to that of the keyboard.
The keyboard consumes 7.7 Watt maximum, which means any 9V 1A (1000mA) adapter will do, but check the polarity on the plug.
Dec 31, 2015 | Computers & Internet
Why i cannot send a fax from my kyocera ecosys fs-1135 mfp?
If you can receive but not send, maybe the number you are sending to should include some pauses, especially at the end of the number. If you have a good dial-tone when you do "On-Hook" then there is nothing preventing you from sending on the machine end. Has the phone system just gone digital? You may need a filter to translate pulses properly. Can you call your cell-phone using On-Hook dialing? I would say there's nothing wrong with the machine. But you'll get blamed for the communication problem in any case. Try manually dialing using On-Hook dialing (turn your Monitor sound up high) and listen for some kind of message. It's a number or line problem. Did they just start requiring an 8 or 9 to be prefix-dialed to get "out?" Or stop requiring it? Maybe there is a prefix number programmed through the default menus that you don't need anymore.
Sep 06, 2014 | Copystar Kyocera FS-1135 MFP/DP Printer
Amp turns on but puts out no sound except for faint noise which dies out after a few seconds.
It sounds like a defective/incorrect AC-to-DC adapter may have caused your problem. These adapter come with different output voltages, AC or DC output and different amperage ratings. AC-to-DC adapters list the polarity of the DC voltage as it relates to the DC power plug and you must match both the devices voltage and power requirements. As for the amp...not working on batteries either, I would suspect output transistors or IC.
May 23, 2014 | Marshall Amplification Marshall MG2FX...
I have a used JVC FS-B70 with no remote. How do I set the time on the clock?
To set the clock go to the link below page 9 will tell you how to set clock.
http://resources.jvc.com/Resources/00/00/97/MB002ien.pdf
On the remote control ONLY:
1 Press CLOCK/TIMER.
The hour digits start flashing on the display.
2 Press UP or DOWN to adjust
the hour, then press CLOCK/
TIMER.
The minute digits start flashing.
• When you press and hold UP or
DOWN, the hour digit changes
continuously.
3 Press UP or DOWN to adjust the
minute, then press CLOCK/TIMER.
The built-in clock starts.
• When you unplug the power cord or if a power failure occurs
The clock is reset to "AM 12:00" right away. If this happens, set
the clock again.
• The clock may gain or lose 1 to 2 minutes per month
If this happens, reset the clock.
Mar 02, 2011 | JVC Audio Players & Recorders
Whats the polarity of lexicon ionix u22 audio adaptor? should i set plus or minus polarity on the adcd transformer/adaptor? thankx
Easy answer: You DON'T set the polarity because this particular device takes a 9 VAC at 2.1 amp adapter. (Not a DC one like so called universal ones)
It sounds like you have one of those universal adapters which probably would not deliver the 2.1 amps required even if the lexicon took DC. Note that stuff might light up, but the unit will not work using a DC adapter..
You had better get an official power supply for this unit as what you have will NOT work, period!
I did a quick search to try and find a link to a supplier, but they are RARE !!! Every one I found would require you changing the plug to match the Lexicon.
You should just order the correct one from Lexicon.
Feb 04, 2011 | Lexicon U22 Ionix U-22
What are the remote codes for transonic dvd player and recorder DVR-R2
I recommend using the auto-search function to try and find the codes you require.
To search for a code for your DVD:
  1. On the remote control, press DVD once.
  2. Press and hold SET until the LED blinks twice, then release SET.
  3. Enter 9 - 9 - 1.The LED will blink twice.
  4. Aim the remote control at the the DVD and slowly alternate between pressing POWER and DVD. Stop when the DVD turns off.
  5. To lock in the code, press and hold SET until the LED blinks twice, then release SET.
Hope that helps.
Nov 04, 2009 | One For All URC-3021 Remote Control
Downloading from digital camera
Serial data bus interface 9 pin to a 25 pin are they still available. may be a computer salvage place the adaptor is shaped like a flat flask I rember them from the late 80. serial bus cards use to have them as standard features.
I have the adaptor and saved it for someday I may need it. have not yet .
Jul 29, 2009 | Cameras
How do I preset individual radio station frequencies?
To set individual presets: 1. tune to the station you want as a preset 2. hold down the number (ie "1") on the remote until the number blinks on the system 3. repeat for all other stations
press the number on the remote to tune to your preset
this is very similar to setting the presets on my car radio
May 04, 2009 | JVC FS-D88 Shelf System
Firestore FS-4
Try a factory reset - it will probably fix the problems you're seeing. These are the instructions I got from Focus Enhancements: FACTORY RESET
a. With the Firestore powered OFF.
b. REMOVE the “battery” and connect the “AC Adaptor”.
c. Press and HOLD down the "ON” and “OFF” buttons for 15' seconds, then release just the “ON” Button.
d. Count to five (5) then release the “OFF” button.
e. The Firestore should be powering back up to the home screen.
(It takes the firestores settings back to the normal setup. This "will not" erase any current footage on the drive) (You may have to re-do current update/upgrade version)
Aug 10, 2008 | Focus Enhancement Firestore FS-4 Hard...
Hampton Bay Ceiling fan
The replacement remote will work fine. All you have to watch out for is that the remote receiver and the remote transmitter are a matched set.
Jul 21, 2008 | Universal Remote Control Hampton Bay...
Lands Phones Logo
22 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
