Question about Radio Communications
Error tone in gp328 plus radio
Hearing a continous tone in all channels, cant even read or write frequencyy
    Problem Solver:
  • 13 Answers
Generally due to power low. It may also be a PPL issue, this should be checked out by a radio repair shop. Did you get the set wet or damp?
Posted on May 06, 2014
Testimonial: "Thanks for reply .No Battery Problem & the MEmory has to be refreshed."
  • Patrick Patterson
    Patrick Patterson May 25, 2014
    While it is very ware, it sounds like your firmware is corrupted since you can't read or write the radio.
    Master:
  • 517 Answers
It is also possible you are using the wrong software. Motorola is very careful to lock down software from working on versions of their radios that were meant for export. I believe the GP328 is not a US version of the GP300 radio. I know you cannot use the GP300 software on a GP328. It will read, but not write correctly.
Posted on Jul 09, 2014
I need to tune my baofeng gt-3 mk2 to the same frequency as my baofeng bf-888s I can hear the bf-888s with my gt-3 but cannot talk I've tried every website why cant i talk over it????
1. Make sure both radios are transmitting and receiving on the same frequency (no repeater offset).
2. Either turn off CTCSS tone or make sure both radios are set to the same tone on both Tx and Rx.
Jan 20, 2015 | Generic Walkie Talkie BAOFENG BF-888s Two...
I have midland wr-100 weather radio. radio is programed with right codes and channel numbers all i get is a high pitch tone coming out of the speaker
Good morning, afternoon, evening or night; whatever time you're reading this. Thank you for choosing FixYa to assist you with your problem. The problem is that you are hearing a high pitch tone coming from the speaker. First check to make sure the weather mode is on. To do this, switch the radio to the right side and make sure the Weather Radio On/Off switch is switched to On. You should also check the alarm to make sure it's not on and set. If the alarm is on, turn it off. Your alert type may also be a cause for this. If your alert type is set on TONE, try changing it to DISPLAY or VOICE. Reply back if you still receive problems. Thank you for choosing FixYa as your one-stop solution spot for your problems. Have a nice day, evening or night; whatever time you are viewing this. Hope this helps and remember our site the next time you need troubleshooting assistance.
Apr 27, 2011 | Midland WR-100 Weather/RDS Radio
VIZIO GV42LFHDTV10A loud tone/buzz frozen function
I bought the same TV for my Mother last Christmas. She is having the very same problem. If you have come up with a solution, please let me know.
Feb 03, 2010 | Vizio GV42L 42 in. LCD Television
My lg dare has no audio i cant hear or be heard, I cant even hear the dial tone, how can i fix it?
I plugged in headphones that didn't work, and that messed up the audio on my lg dare phone. So to solve the problem I just got headphones that worked plugged it in and the audio worked.
May 11, 2009 | LG Dare VX9700 Cell Phone
Can't dial buttons while in a call..
you need to go into menu-settings-tones - set the key tones to continous
Jun 11, 2008 | Motorola Mobility RAZR V3
Nokia 6070
what you need to do is just for you to change your ear piece
Jan 07, 2008 | Nokia 6070 Cellular Phone
Cant talk through mic
Sounds like a bad or miswired mic. Try a new mic ( use the proper cobra mic ). If the problem still continues, check all the swiches on the front of the radio and make sure you don't have any cold solder joints ( broken lead to board connections ). Good Luck
Ed
NC Electronic
Mills, Wyoming
Dec 19, 2007 | Cobra 29 WX NW ST 40-Channels Base CB...
I can't pick up anything...
Hello even though everything is connected properly, have you checked for standing waves on the antenna to radio connection? Also you may have to perform a sensitivity test on the unit. The problem is you need a RF generator for that. Set you RF generator to the frequency that is equal to the CBs middle frequency and modulate the CW with 1KHz at 50% modulation, tune to the middle of the CB band on the radio and set the output of the RF generator to .1uv and loosely couple the signal to the CB antenna with a loop of wire. Your CB should be picking up a 1KHz tone gradually turn the power level down and when the tone cuts off that level is cutoff level, then increase the level until you can hear the tone again when the tone cuts on that value is the sensitivity of the unit. Compare the measured value to the value in the owners documentation. if the sensitivity is low this could denot a problem in the RF/IF section of the CB.
Oct 04, 2007 | Uniden Bearcat Pro PC68LTW 40-Channels...
Cannot get 2 tone pager to work
under zone edit change your optional signalling rules to qt dqt and optional signalling then the radio will only hear when all rules are satisfied ie right pl tone and decoded two tone make sure yoou only turn on optional sig on the page channel
Oct 02, 2007 | Radio Communications
Constant tone on an HT1000
You will get a constant tone on any channel that isn't programmed. it sounds like the previous user ha a freq programmed on channel 1. Channel 11 is strange, but possible. Usually guys program these radios in order.... they don't put 2 freqs in soo far apart from each other..... I would expect channel 1 AND 2 to have freq programmed in them.... but channel 1 an channel 11 is strange... but possible. Anytime you don't fill up all the channels on these radios (commercial radios in general) you will get a constant tone on the channels that don't have anything programmed in them. Program the radio and your good to go. If you don't program freqs into al the available channels, expect to hear that "constant tone" on any unprogrammed channels. The channels that you hear a tone on do not have a freq programmed into it. Its normal. Good luck
Jul 05, 2007 | Motorola HT1000, MTS2000, MTX8000/9000...
Radio Communications Logo
131 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
