Question about Garden
Honda hhh25 hedgetrimmer
Oil leak and smoking badly
4 Suggested Answers
duane_wong
  • 6826 Answers
SOURCE: Losing oil, no visible leaks. 120,000 miles
Hm. In my experience if you lose oil at the rate of 1 qt. per 800 mi. it's going somewhere. Actually, if you lose 1 qt. per 1000 mi. and change your oil every 3,000 mi. it's under $10 in oil you have to buy to keep it topped off, and some places say that's there's nothing wrong.
But, your case is a little more serious.
I think that it's probably leaking past the rings and/or valves and the catalytic converter is eating up the oil, so you see no blue smoke, like you would in a car that has no converter (I'm assuming you have a catalytic converter on your car as my 1981 Honda had).
After 100,000 mi. little irregularities in the piston cylinders can develop, and seals can gradually degrade. So, this is normal for that kind of mileage, although there are people who get over 400,000 mi. on their cars with just regular maintenance and driving highway mi.
You might want to try one of those slower burn oils designed for cars with 75,000 mi. and above. That might slow the burn off of oil down to acceptable levels.
Good luck with it.
Posted on Jul 26, 2010
sundriveauto
  • 137 Answers
SOURCE: My Honda is leaking oil
us gasket seal to seal the rocket cover.
Posted on Aug 23, 2010
vtu1314
  • 1335 Answers
SOURCE: I have a 2001 Honda civic and dosnt leak oil can't c smoke But in 6000km uses a liter of oil
It could be burning it, just not enough to see the smoke from the tail pipe. Have you checked the intake tubes or the coolant for contamination ?
Posted on Nov 17, 2016
How much engine oil goes into the honda HHH25 4stroke easy start petrol hedge trimmer ?
Sitting the trimmer on a level surface you add oil til it is level with the oil filler plug. Shows how in the maual.
Here's a PDF manual -
http://campaigns.hondampe.com.au/.../ownersmanuals/hedge-trimmer/hhhd25own01.pdf
Feb 14, 2018 | Honda Garden
Honda fourtrax 350
Hi, if there is smoke 10-20 minutes that is fine, probably just residual oil from the top engine work.
if the smoke is a hour coming off the engine because of external oil leak, sounds like head gasket is leaking. If you continue to run the machine like this, make sure to always check oil levels and add oil when low. As long as your smoke is not coming out the tail pipe which would mean you are burning oil and would need to be fixed.
side note: Its always good to have a Haynes manual for any machine you own, they have great troubleshooting tips.
Honda ATV Repair Manuals Do It Youself DIY Manual to Repair Honda...
Sep 06, 2014 | ATVs
Oil level keeps going down and no sign of leak
Recheck that there is no smoke particularly at first startup. I suspect the Valve Guide Seals are going bad and need to be replaced.
Apr 10, 2014 | 1995 Honda Odyssey
Why does my honda 700xx use a lot of oil
Possibly bad rings or a leaking gasket
Sep 16, 2013 | Honda 2008 TRX 700XX
Leaking valve seal
smoke doesnt necessarily mean the valve seal is bad, check the valve cover breather. sometimes they plug up and **** oil up from motor. start it up and watch inside of carb for oil dripping.
Jul 16, 2012 | Honda Horizontal OHV Engine 50cc, GX...
Why does my honda accord smoke reel bad
This is either worn valve stem seals or worn out oil rings. Have someone follow you if the car smokes more as you release the throttle on deceleration it is most likely valve stem seal if it smokes more on acceleration it is worn oil piston rings. If the smoke is white you have a blown head gasket blue smoke means burning oil, black smoke means too rich (to much gas reaching motor)
Jan 05, 2010 | 1991 Honda Accord
Leaks oil on the exaust.smoke comes up from back
the tapping is probably from low oil level,you need to keep it full untill you repair the oil leak
Dec 28, 2009 | 1995 Honda Accord
Garden Logo
32 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
