Question about Kenmore 24032\24036 Top Load Washer
Kenmore lid switch
Hi, I have the lid case off but cannot get the switch out the plastic hole that hold the screws in broke but i cannot remove the wire and dont want to rip the switch out wrong. i have limited space to work as the washer is in a corner is there a trick to releasing the wire?
thanks
  • scottjarus Jun 20, 2009
    model # 110.22902 100
    thanks scott
  • 999 Answers
Can I have the complete model number starting with 110.?
Eric
Posted on Jun 20, 2009
I have a Kenmore washer that locks automatically through entire wash from start to finish. I was locking and stopping so I forced it open and broke the lock. It also broke the hole thing part but I don't...
You need a set of "star keys" you can buy them at a auto parts store. I can't see the model number otherwise I could get you the part number for your lid lock. It is suppose to lock start to finish as you described it was doing. I'm a tech so can get you part number but only with a model number
Feb 19, 2015 | Kenmore Washing Machines
Kenmore model 11020842990 series 80. had a severely unbalanced load in the rinse cycle. opened lid, rearranged clothes, would not start up again. Removed clothes to dryer, luckily most of water had...
when it went unbalanced the tub most likely broke the lid switch part
3949238.open the lid,on the right side of lid you'll see a strike,it goes into a hole and this is where the lid switch is,stick a screw driver into the hole,if you don't hear a clicking sound the switch is broke
http://www.youtube.com/watch?v=MFsvLiuTniU
Oct 15, 2013 | Kenmore 24032\24036 Top Load Washer
Kenmore elite 80 series washing machine model110.26824690 cg11808832 put a heavy load (a blanket) in the machine. the top part of the agitator seems to work but i can't reach in a physically turn the...
Greetings,
check for a faint click when you close the lid..if you hear no click, paying close attention for sound..the lid switch is most likely bad..on some models..it prevents machine from spinning, but lets it wash..there is a way to get it to spin by hooking switch up direct...this is only good for checking as its a safety feature...raise console after UNPLUGGING and you will see a small block with three wires coming out of cabinet at right corner ...there will be a plug that goes into this with three wires and it comes off by holding a little tab and pulling it off. its this block that you want to make bypass..do not use the green wire as its ground, but make bypass beteen other two wires and it should drain and spin. make sure you tape this with electrical tape and purchase a new lid switch.
Jan 23, 2011 | Washing Machines
Mine wont spin
Your problem is more likely a broken lid switch. To test for this, lift the washer cover and look for a small hole in the washer top where the cover was. Push a toothpick gently into the hole and press the piece of plastic you see in the hole downward and listen for a soft clicking sound. If you don't hear a click or the plastic tab is not in the hole replace the lid switch.
Unplug the washer. Check the actuator on the lid that operates the lid switch to see if broken. Open the console of the washer. After removing the screws, the console will lift up and hinge back. Disconnect the plug going to the lid switch. Picture. Check the lid switch [lid closed] with an ohm meter from the wire plug-in leading to the switch. If no continuity, replace the lid switch. You will need to remove the cabinet to replace the switch. There are only a couple screws holding the lid switch assembly and a ground wire connection to the cabinet. Reassemble the washer and test the operation.
Unplug washer, remove the two console screws and tilt console back, remove cabinet clips, unlock lid switch block and then remove the cabinet. Remove the lid switch mounting screws, disconnect ground wire and remove lid switch assembly. Compare old switch to the new one. If the plastic sleeve of the new switch is longer, break off at the score mark. Pull wire partially out of sleeve before shortening sleeve. If the sleeve had to be shortened, the wires must be looped to take up the excess wire. Use supplied wire tie from the new kit. Install new switch assembly. New lid switch
Pay VERY close attention to assembling case back onto base so that sides engage tabs in base.
Sep 21, 2009 | Whirlpool Washing Machines
The washer does not drain the water or spin. Does the drain work when the spin cycle starts?
pull end caps from both ends of back splash remove 2 screws flip control panel back...remove 2 clips(use screw driver to pry up)...disconnect wire plug lift lid put hands in opening pull the case to you and up to remove entire case...remove 2 screws that hold lid switch install new switch...(don't forget to plug the wire plug back in...ho ho
Aug 26, 2009 | Kenmore 23822 Top Load Washer
When checking out the lid switch on my roper washer as jsrock suggested in another post, i heard a screw drop from the inside of that area which caused the lid switch to become unmounted completely. also,...
Top lid pull up. Look in seam between top and front cover. On each side you will see where top clips to front cover. Put a screwdriver in there and lightly pry up till clip releases. Front cover will now pull up and be removed, so you could get what fell in.
Jul 26, 2009 | Roper RAS8445KQ Top Load Washer
I have a Kenmore Oasis HE 27082 and the lid lock bolt broke. How can I replace it?
Disconnect your Kenmore Oasis washing machine from its power source. Make sure that your washer is unplugged before beginning to disassemble it.
Remove the screws that hold the control console to the top of your Oasis washer. In some Kenmore Oasis models, the two screws may be covered by plastic end caps. After removing the screws, set them aside until you are ready to replace them.
Flip the console up, back and out of the way.
Locate the cabinet clips on the top of your Kenmore Oasis washer. These clips are located toward the back of the washer top and would be hidden by the console if it were not currently flipped up.
5
Slide your screwdriver underneath the metal cabinet clips. Wiggle the screwdriver back and forth to gently pry the cabinet clips free.
6
Disconnect the group of colored wires that plug into the top of the washer from the control console. These wires control the lid switch on your Kenmore washing machine. To disconnect, grasp the white plastic clip and pull gently.
7
Remove the washing machine cabinet. Tilt the cabinet towards you, and then lift the entire cabinet up and off of its platform.
You can access the lid switch at this point.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 22, 2009 | Kenmore Washing Machines
Kenmore 90 Series Washer
this came from my research of the web...
Lid switch broke off (plastic housing broke in half at the screws). This definitely gets easier after doing it just once. Took me a while to figure out I needed to pop off the plastic caps on the sides of the top control panel, to expose the two screws that others mention. Remove the two screws, lay the control panel forward exposing the two metal clips on top holding the cabinet in place. Unhook the clips, voila. The plastic connector of the replacement switch didn't exactly match the old one so I cut and splice (wire nuts and tape). Cleaned everything well while I had it all apart. If I ever have to do this again, it should take a fraction of the time.
im sure its the same as yours.
tnx 4 using fixya,
drcool
Sep 23, 2008 | Washing Machines
The lid switch needs to be replaced how do i do that
Real easy Unplug unit, remove the two screws holding head of unit, lift the head up and back, there will be two clips on each side use a flat head screwdriver and pry up clips by inserting it in the front hole and pushing towards back of machine, unplug lid switch, remove case by pulling towards you lid switch is on under side of case.Reverse steps to put back together.PIECE OF CAKE
Nov 27, 2007 | Kenmore 23822 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
91 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
