Question about Air Tools & Compressors
Colt 282 where do I drain oil from colt 282 and how much new oil do I put in.
2 Suggested Answers
  • 58 Answers
SOURCE: spare parts for colt 282
hi this is a crazy situation if it is only 2 wks old it must be under warranty /i accept it is not a manufactors fault but there must be an adress on the warranty or some contact number failing that go to a comprressor co (yellow pages) see if you can find a simlar compand buy the bits you need hope that helps merlinv12
Posted on Aug 19, 2009
Change the oil on a 2000 Dodge Caravan
Jack up pass side.Put cardboard, BIG piece under engine just in case. Using a pan to drain the oil in put under oil pan drain plug. Remove drain plug with socket wrench. Let drain 5 min. Check the gasket on the drain plug, if bad replace with new gasket .99 cents to replace gasket only on plug. Put plug back in DO NOT OVER TIGHTEN the plug. Slide drain pan with drained oil to the front to remove oil filter. Using a filter wrench remove oil filter. Let drain. When installing new filter put a little new engine oil on the rubber gasket on the filter with your finger. Screw filter back on tighten with filter wrench. Fill van with oil from front valve cover opening.
Nov 21, 2009 | 2000 Dodge Caravan
What type of oil for Mitsubishi Colt gear box
First drain completely out whatever is in it. All the gear boxes and rear ends use 90w gear oil. Buy a name brand.Some of the really cheap stuff is recycled used oil.
I hope this helps you.
Sep 11, 2009 | Mitsubishi Colt Cars & Trucks
What gearbox oil for 1992 K reg Mitsubishi colt
IT IS SEPERATE FROM ENGINE THERE IS A FILLER BOLT AT FRONT OF BOX DRAIN PLUG IS AT THE BOTTOM NEAR THE OUT UT SHAFTS DRAIN IT AND REFILL WITH A SYNTHETIC CASTROL AUTO TRANS FLUID THIS WILL IMPROVE YOU GEAR SHIFTS
Sep 10, 2009 | Mitsubishi Colt Cars & Trucks
Spare parts for colt 282
Aug 16, 2009 | Air Tools & Compressors
Hi, I have a colt Mk 282 air compressor that won't auto shutoff. eg the compressor keeps running on trying to fill the holding tank even thou it is full!! it will then blow the rear saftey plug out of the...
The shutoff valve (usually has a set of contacts like a relay) is probably stuck. For the most part, these are not adjustable. They can usually be removed, cleaned, and reinstalled to correct the problem. Sometimes that permanently fixes it. Sometimes, you have to bite the bullet and by a new shutoff valve.
Mar 20, 2009 | Air Tools & Compressors
Air Tools & Compressors Logo
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
