Question about Kitchen Appliances - Others
I have a quick cup deluxe tefal but doesn't work won't switch on what could be the problem changed the fuse
2 Suggested Answers
  • 19 Answers
SOURCE: I need to descale my tefal quick cup but have lost
Hi. Post the link below into your browser, it takes you direct to the Tefal site wher the full instruction manual is. All you then need to do is save or print the information contained in the ten page PDF document:
http://www.tefal.co.uk/NR/rdonlyres/56C464A4-21F4-478C-A376-C40A50AE592D/0/quick_cup.pdf
Good luck, hope its what you are looking for. Let me know?......Regards ...Cornwellnet (UK)
Posted on Jul 09, 2009
Tefal quick cup kettle water coming out in slow spurts,have changed filter but no improvement.
If you are in a hard water area you may need to descale the heater element. Try adding 1 cup vinegar to 3 cups water and run the machine should clear up the scale. Rinse thoroughly before use.
Sep 12, 2010 | Tefal Kitchen Appliances - Others
Just bought a tefal quick cup from john lewis and we have lost the instructions, could you tell me how to turn the blue light off on the top when you change the filter . thank you.
Follow this procedure when you change the filter:
Press the hot water button H and the ambient water button G, for at least 5 seconds.
After 5 seconds, the indicator light will go out. The appliance will then have recorded the cartridge change.
If you are happy with my response pease vote for this answer.
Thanks
Mar 05, 2010 | Tefal Kitchen Appliances - Others
Hello tefal quick cup water is no longer hot only
we had to return our first one for the same problem Gavin. Tefal (surprise surprise) claimed that nobody else had EVER had that problem. 2 years down the track though, and i've discovered that mine turns itself on at random intervals, and floods the kitchen bench. My advice - get a refund while you still can...
Mar 03, 2010 | Tefal Kitchen Appliances - Others
Tefal HA-36825 10-Cup Rice Cooker
replace the thermal fuse, it was like a resistor which is connected in the main line inside your rice cooker
Jan 08, 2010 | Tefal HA-36825 10-Cup Rice Cooker
Tefal quick cup
Press the Hot and Cold button for 3 seconds,
The red indicator light will start to blink,
Release the hot and cold buttons and while the red is still blinking, press the and hold the hold water button, Once the desired amount of hot water is reached release the hot water button.
Now press and hold the hot and cold water buttons simultaneously for about 3 seconds.
The red light will stop blinking to the end of the programming.
NB the RED LIGHT WILL BLINK FOR THE DURATION OF THE PROGRAMMING.
Repeat the process for the cup quanity selector for the cold water.
------------------------------------The end -------------------------------------------
Feb 28, 2009 | Tefal Kitchen Appliances - Others
Tefal Quick Cup
ALERT :- Tefal Quick Cup can TURN IT SELF ON. Tefal know about this but it is a potential fire hazard. Mine turned itself on and dispensed the water reservoir over my kitchen. Dread to think if I had been out shopping what could have happened. Tefal know about this problem but are not doing anything to advertise the fault!!
Jan 19, 2009 | Kitchen Appliances - Others
My tefal quick cup now just flows cold water ?
Your unit more than likely has a thermal fuse built into the electrical circuit which is open. This is a built in safety to prevent overheating in the event someone failed to shut off the unit when they finished.
Nov 06, 2008 | Heating & Cooling
I have a 4 slive tefal deluxe toaster which has stopped working
often is the switch as you press down its a steel wire like a pin that snaps i have repaired 2 same problem i soldered a fine steel wire on its easy part to replace but so far i cant buy a replacement switch
Sep 08, 2008 | Tefal Avante Deluxe 4 Slice Toaster
Kitchen Appliances - Others Logo
29 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
