Question about Nespresso C100B Essenza Single-Serve Automatic Espresso Machine, Black
Magimix nespresso jammed capsule
Cannot open the capsule holder
4 Suggested Answers
SOURCE: water leaks from the top of the C190 Espresso Machine
in our case the problem was fixed easily: the metal piece in which the capsule sits is screwed in on the top. When it became loose our machine started to leak water from the top. So the problem was solved by retightening it!
Posted on Feb 02, 2009
SOURCE: The lever of the nespresso C101 will not open. The capsule seems to be stuck inside
Had the same problem. I think this happens when the pressure builds up inside. U cant try and open the lever when the machine is in the extraction phase. Just switch off the machine and wait. Mine opened about 3-4 hrs later. Had to exert some gentle pressure on the lever, though to lift it.
Posted on Nov 30, 2011
  • 6 Answers
SOURCE: My Nespresso Magimix Citiz does
-the short term solution-
1. take your affected capsule. set it on its un-punctured/un-perforated bottom (the thin foil surface) on a flat surface. the three puncture holes should be facing upward on the top of the capsule. by the way, if you shake the capsule you should hear the grounds sound dry as if the capsule was new.
2. find a thin small rubber band. size-wise, ideally, the rubber band will fit loosely around your thumb; with a very small gap between the rubber and your thumb.
3. put the rubber band around the collar of the capsule. the band should be put over the top of the capsule and pushed down until it stops flush against the flange (rim). if the band is correctly placed, the band will be just 1mm flat inside the rolled bare aluminum edge (rim).
4. insert the capsule in your citiz machine as usual. optional: you can orient one of the puncture holes at 12 o'clock position (top dead center) during the insertion process. this time, it will work. you will find the capsule will eject cleanly with the rubber band intact.
5. save the rubber band.
-which machines does this apply to?-
this is a common problem with nespresso machines introduced after 2010, specifically the citiz. i have not seen this problem on the pixie, yet. i would expect this issue on the lattissima plus.
i am assuming that the machine is otherwise functioning properly: meaning that the machine does not have an issue with the water pump, excessive scaling deposits restricting water flow, or some other major mechanical part.
-why is this happening?-
look at the capsule, the post-2010 machines bite new slightly rectangular indentations on the capsule around the top edge of the wall. this is new. nepresso changed the insertion mechanism in response to competitors bringing non-nespresso branded capsules to market: Douwe Egberts/Sara Lee "L'or expressO", Caffe Vergnana "ESPRESSO", etc.
this new insertion mechanism was supposed to thwart knockoff capsules, instead it is unintentionally thwarting your "real" nespresso capsule. the injector needles are not piercing correctly all the way. the injectors poorly lodge: deep enough to make puncture holes but not deep enough to allow water to flow freely into the espresso grounds compartment.
two things can happen:
1. the pressure release valve, inside the brewing chamber which prevents an explosion occurring if the coffee exhaust path becomes blocked, is activated and hot water overflows into your used capsule basket.
2. the hot water flows outside and around the capsule and into your cup as clear hot water.
-what do i do long term?-
contact nepresso. get your machine repaired or replaced. this is a factory manufacturing defect that has nothing to do with you, wear, use, or hard water. refuse to pay the $125 repair fee. demand that they fix the machine free of charge. they will send you a loaner in a plastic shipping crate to use while your is being fixed. you should not have to suffer without espresso or waste legitimately purchased capsules just because nespresso is in a legal fight capsule copycats. this is not your fault.
Posted on Dec 26, 2011
Coffee pod stuck in machine
These machines are designed to use only Nespresso capsules. The UMilk, particularly, is susceptible to jamming if so-called "compatible" capsules are used, as the capsule is pierced electroncally, not manually as in most of the Nespresso range of machines.
Hope this helps, Rob.
Apr 11, 2015 | Nespresso U D50 Espresso Machine Color:...
My nespresso c190 makes coffee watery
Have you decalcified the machine? They need descaling about once every year - 18 months, and one MUST use the Nespresso Descaling Pack, which is designed for all Nespresso machines. I can't understand why the capsule holder is tight, unless you have used so-called "Nespresso Compatible" capsules, which can cause this. The machines are designed for use only with genuine Nespresso capsules.
Feb 28, 2015 | Nespresso C190 Espresso Machine
Nespresso Essenza 90 leaking at the bottom seam underneath the used capsule holder, HELP
Try gluing the seam with lock tight glue or similar plastic gluing compound. Let it dry overnight and try again.
Oct 16, 2014 | Nespresso Essenza C90 Espresso Machine
Nespresso xn 2003 - water comes through without a capsule but when a capsule is in place the water goes straight into the catch tray?
at the back of the capsule holder there is a metal that correspond
with the sensor sow your problem is the sensor is not finding the capsule holder at the and of the capsule holder do you see the magnit if not replace and try agian
Jul 08, 2014 | Krups Coffee Makers & Espresso Machines
How do I disassemble my magimix m100
You will need a special 0 shaped socket, Nespresso will mend 0800 42442
spare drip trays, ater tanks and Nespresso capsule catchers available from
Magimix Spares Parts from BBS Ltd
May 21, 2014 | Keurig Coffee Makers & Espresso Machines
Magimix M190 CITZ
Are you using genuine nespresso capsules? Are they seating properly. Open the slot where you put the capsule in and check its very clean and nothing is stuck in there.
Have you tried resetting to factory settings?
Apr 03, 2014 | Nespresso D300 Espresso Machine
Nespresso leaks coffee in capsule tray
check the gaskets or orings for cracks and replace if they look bad .perhaps a little lubricant is needed
Mar 19, 2013 | Coffee Makers & Espresso Machines
Capsule area is leaking
Perhaps capsule holder.
Look Inside on top of this capsule holder for a crack in molded plastic where water come in.
(I have replaced big "O" ring for nothing because the capsule holder is cracked on top).
Jul 04, 2012 | Nespresso Citiz C110
My Nespresso Magimix Citiz does not pierce the capsules every time. I use only Nespresso capsules. I have tried to pass them through a second or third time when this happens but I have thrown too many...
Mar 02, 2011 | Nespresso C100/T-US-AERO Espresso Machine
My machine leaks water into the capsul box and doesn't punch holes or not enough in the capsule when pushing it in. Coffee is very weak because not enough coffee is reached in the capsule and water is...
Mar 01, 2011 | Nespresso Citiz D110
Nespresso C100B Essenza Single-Serve Automatic Espresso Machine, Black Logo
114 people viewed this question
Top Nespresso Coffee Makers & Espresso Machines Experts
Joseph Hoffmann
Kolbrun...
Jay Finke
Jay Finke
Are you a Nespresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
