Montgomery Wards washing maching. about 25 years old
When I start my washing cycle, The water turns turns on but does not fill. I have to manualy change the size of the load or turn the aggitator until it locks... The water would run for hour without filling the machine, what is my problem? And sometimes after a few cycles it gets stuck between cycles. after the first washing cycle it spin dries and then start to fill again. The water just runs without filling.
    Top Expert:
  • Washing Mach... Master
  • 43,927 Answers
"about 25 years old"
Posted on Jul 24, 2017
  • 1294 Answers
SOURCE: Rinse water fills the washing machine when the spin cycle starts
Check your outlet filter, most likely it is blocked, preventing the water from draining out. Chk your pump too. Before this disconnect from the wall socket; and also check the pipe coming from the tub to the filter. Siphon out the excess water from inside the machine before you open the pipes.
Posted on May 18, 2007
  • 351 Answers
SOURCE: hoover 750lb
if its a top loader check for timer/timer module fault.front loader check carbon brushes in motor
Posted on Mar 02, 2008
SOURCE: Whirlpool Model LSV6234AWO
door switch bad?
Posted on Oct 18, 2008
SOURCE: GE WJSR1070A top loader wont aggitate.
You either have a bad timer, transmission, or the agitator is stripped on the splined shaft
Posted on Mar 05, 2009
  • 52 Answers
SOURCE: Washing machine stops on spin cycle
You need a new drain pump.
Posted on May 04, 2009
Do you have a user manual for montgomery ward uht j 1930 sewing machine
no sorry and you will probably never find one since they went out of business over 25 years back.
Jul 25, 2015 | Montgomery Ward Sewing Machines
My F&P washing mach is going thru the cycles fine but it has an annoying squeak when filling up? It's only a few years old, a smart touch. It also squeaks on the wash cycle
very hard to identify without an inspection. Strange to find it squeeking on fill as well as wash maybe something simple . could be a suspension issue due to a weight factor
Feb 11, 2015 | Washing Machines
I have a Sears Kenmoore Series 70 model 100 washing maching. It's 14 years old. The problem is it will not dran water into the machine when I start my laundry. It goes directly into agitation. No water...
The water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
Nov 30, 2010 | Washing Machines
My Montgomery Wards big floor type demumidifier
If your dehumidifier doesn't seem to run often but the humidity in the room is high, try adjusting the humidistat control on the dehumidifier to a dryer setting. If the dehumidifier seems to run constantly, but there's little or no water in the container, there may be a problem in the refrigeration system. Try cleaning the unit. If that doesn't work, you can't repair the refrigeration system yourself, you need a qualified appliance repair technician to do that.
Jan 28, 2010 | Kenmore 54501 Dehumidifier
10 year old model kenmore top load washing maching won't fill.
That means that eithere the membrane water lever switch is faulty (most common) or that the drain pump solenoid is stuck on open.
Dec 21, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machine
the main water valve that the fill hoses connect too in the back of the washer is probably bad.
Jul 25, 2008 | Indesit W 123 Front Load Washer
Simpson esprit washing machine
put a new pressure switch in it
Mar 25, 2008 | Washing Machines
Washing Machines Logo
103 people viewed this question
Top Washing Machines Experts
