Question about Microwave Ovens
Khind cooker Ic1800
The cooker cannot turn on , no power supply
Indesit cooker clicking
Hello, the clicking sound is as a result of bulged capacitor. One or more capacitors on the power supply board inside the unit is bulged, that's why you are hearing the clicking sound. Have the power supply board check and the cause of the porblem will be revealed. Good luck.
Dec 29, 2011 | KitchenAid Microwave Ovens
My sharp grill2convection made a noise and quite working. is this possibly a fuse?
the problem of this unit is power related.
First, remove the unit's power cord from the wall, wait for about 30mins, then plug it back in. It may cool by then and might power on. If it doesn't power on, plug it into another outlet, to make sure there electricity entering into the unit.
If plugging into another power outlet doesn't power it on then the unit is most likely having a power problem.
When electric current comes from the power outlet into the cooker, it goes straight into the power supply board which then circulates the current into the unit. So if the cooker doesn't power on, the first thing is to make sure there is power entering into the machine.
So check the power cord, if it is a 3-pin plug, it must have a fuse in it. check the fuse if it is not blown. if fuse is intact, then power supply board should be checked.
If any machine or electronics device doesn't power on, it means its having a power problem. it might have worked fine in the past, but that's electronics for you. Power surge, irregular power supply, excess power supply, etc can affect the unit thereby not making it to power on.
This unit must have a power supply board in it where power enters from the mains. A capacitor, fuse, diode, etc may have been defective on the power board and maybe that's why its not making the unit turn on. There might also be some disconnection or something, inside the unit which is not making it to power on.
To actually find out what's wrong, you need to disassemble the unit with a screw driver and check what's wrong. You will be needing a meter and continuity tester in order to read the components on the power board, once you detect any bad component, you can make necessary replacement at any electronics accessories store withing our vicinity. This is the only way by which you can detect the problem.
Of course, testing the power board with a meter will require someone that has the ability. So it you can't, then you might be needing the help of a repairman or you can call a friend that has the ability to help you out.
I wish you the best of luck.
Regards.
Nov 06, 2011 | Sharp R-930AK Convection/Microwave Oven
No power to microwave outlet funtioning properly
Best wishes.
Nov 03, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Ge spacemaker light blew and now wont turn on
Regards.
Ge spacemaker jvm1650sh01 has no power after power outage
Regards.
Nov 02, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Goldstar 2006 doesn't work at all ,no power
Regards.
Walesarumi
Sep 29, 2011 | Microwave Ovens
No power in microwave, replaced fuse and still nothing
Regards.
Walesarumi
Sep 26, 2011 | Microwave Ovens
Regards.
Walesarumi
Sep 26, 2011 | Kenmore Microwave Ovens
My electronic ignition has gone and the cooker clock doesnt light up, also the fan isnt working is there a battery and if so how can I change this. Thanks
I would say that you have a power failure. A battery cannot run all of that. Check the mains supply to the cooker.
Feb 14, 2011 | Microwave Ovens
I have a creda europa solar plus double oven and want to replace it with a BOSCH HBM56B550B will the power supply I have be enough for the Bosch?
What you must do is calculate the total power required by the Bosch cooker. Convert it into Amperes and copper cable is roughly 10 Amperes per 1.50mm cable. What size cable feeds you cooker at present? Or
Is the maximum power calculated for the old cooker the same or more than the new cooker. If it is and the old cooker was installed by a qualified electrician observing local electricity codes, no problem get it fitted, if not consult a qualified electrician.
Jan 01, 2011 | Microwave Ovens
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
