Indesit Help to locate brushes
    Problem Solver:
  • 5 Answers
Brushes, 2 of, are located in the back of the motor , , u will have to turn your washing michine on it side to do it.
Posted on Apr 20, 2014
I think the brushes are worn on my Indesit WIB101UK but searching for the correct brushes to replace worn ones is proving difficult!! Please could you advise me of the correct ones I would need. The motor...
Key in your model to epares.co.uk they will show a picture of the carbon brushes and you will see on utbe a video of HOW TO ...I find it easy to leave the motor on the machine and work from under it although I have done this over 25 years so its easy for me .....I wish you well .Cost of parts around £15 depending on model....
Jan 29, 2011 | Indesit WA 115 Front Load Washer
Need to replace carbon brushes on Indesit Omega 1200
The brushes are located inside the motor. Remove rear panel of washer, remove drive belt, from motor and drum, unplug the motor, undo screws that secure motor, and remove motor.
At the opposite end to the motor pulley, you will find the brushes located, undo 2 screws that secure the brushes, remove and replace brushes.
I would also check the pump filter, which should be located behind a removable panel at bottom of washer, unscrew anti-clockwise, remove and clean.
Please rate my fixya solution.
Thanks.
Feb 01, 2009 | Indesit W 123 Front Load Washer
Indesit washing machine wdg1295w blowing fuse
Proberly carbon brushes in motor,Can be supplied if req.grandadfixer
Oct 11, 2008 | Indesit W 123 Front Load Washer
Indesit 2000 (washer/dryer)
hi there first remove the back panel and check belt has not jumped off failing that remove the motor and check that the carbon brushes have atleast 12mm of carbon left on them any less than that and they will most likley need replaced, if you still have no drum action after this you will need to replace the speed control module located next to the motor.
hope this is of some help murdozzz.
Dec 09, 2007 | Indesit WA 115 Front Load Washer
Indesit wg 1285w
Replacing the capacitor might solve your problem. Good luck!
Aug 30, 2007 | Indesit W 123 Front Load Washer
Continually spinning
indesits dont have carbon brushes they have a module which controls everything to your tomer if this is faulty or your timer then its not worth doing too much in money to replace get a hoover or candy same machine just ones the uk model and the other is the us model dont go for hotpoint though because indesit own hotpoint now and there changing the carbon brushes to modules which is a big mistake alot dearer to replace then the carbon brushes but maybe thats why there doing so customers have to buy another washer check the price by going to indesit customer support web site but i always keep customers away from indesit due to that module some hotpoints are still the carbons but some arent cheaper to buy a slight damaged from a washer repay shop they usually have damaged at a fraction of the price save at least £125 per washer or buy a repossed one may off been used at the most 10 times nothing wrong with them and you will save £200 plus m8
Aug 23, 2007 | Indesit WA 115 Front Load Washer
W123 Wont rotate
some indesit washer have a module if you pull your washer out make sure power is off take the back off and you will see it on your left hand side it should be in a plastic cover with about 8 wires going into the cover there should be 2 screws that locate this to the back of your washer if not then it will have carbon brushes if these are lower thanabout 8ml long they need replacing these are locatable in the motor by having 1 small wire going onto them they will be plastic with the carbon inside pf them m8
Aug 12, 2007 | Indesit W 123 Front Load Washer
Washing Machines Logo
15 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
