Lg inverter air conditioner - WHEN OUTSIDE AIR TEMPERATURE IS 0 DEG C OR A BIT LOWER, THE UNIT DOES NOT HEAT BECAUSE OF ICE BUILD UP INSIDE THE UNIT. PRESUMABLY THIS IS BECAUSE OF THE HEAT TRANSFER AND INSUFFICIENT HEAT IS IN THE OUTSIDE AIR. AFTER SOME TIME EG 1 HOUR, AS THE AMBIENT AIR HEATS UP THE UNIT MANAGES TO DEFROST ITSELF AND START HEATING. IS THERE ANYTHING I CAN DO TO OVERCOME THIS PROBLEM? THE UNIT IS A DUCTED 15KW MODEL B55AWYN7G5.
dgjtex
  • 405 Answers
SOURCE: C4 error code on LG artcool airconditioner
www.yx2.fi/LG/wall_and_art_cool_error_codes_2007.pdf
Please read this article, I think it will help you solve your problem
Posted on Jan 14, 2009
  • 17 Answers
SOURCE: No cold air blowing from vents
faulty indoor fan motor, check for blown fuses first in the indoor fan unit first before replacing motor. i live in s.a to i feel your pain.
Posted on Feb 10, 2009
  • 234 Answers
SOURCE: Problem with Sharp Air conditioner
You proablly have freon leak and the unit cuts off on low psi.
Posted on Mar 19, 2009
  • 38 Answers
SOURCE: RUUD heat pump system does not cool properly.
With a heat pump system there are always going to be a back up heat strip inside the Air Handler.
If you detect a faint humming in the Condenser call your local service company and ask them to come and replace your capacitor in the condenser. The humming is from the contactor engaging but not being able to start the compressor due to not having the required Microfarads to start it.
Let me know if this helps
Posted on May 08, 2009
SOURCE: heating problem
Hi Radan, Did you get this problem solved? We have an Electrolux Kelvinator Split System and ours is doing exactly the same thing. I am struggling to find a solulution. Would be great if you can offer any advice.
Thanks Nicolle
Posted on Sep 25, 2009
Not sure the heat pump is producing enough heat
lower the fan speed to low and if you do not close your turns at 50 degrees Celsius then check the freon
Nov 04, 2011 | Heating & Cooling
It has lots of ice build up around outside unite i would say about 5 inches high around it. Is this normal in winter
Depends on the outside temperature as if the temperature is lower there will not be heat exchange and so frosting can happen.
Feb 08, 2011 | Heating & Cooling
Ice formed on outside of line!
try running the air conditioner in defrost mode. set the temperature to warmest while air conditioner is on, for about two minutes. then slowly move the lever towards cold, all the while having the vent set on outside air. once you move it toward cooler, move the vent switch towards recirculate from outside air.
when you have it on defrost, open the engine hood and push the air conditioner button. watch the lines and see if they begin to build frost. if not, move the slider toward cold a little bit at a time while watching the lines to see if they begin to build frost. if they do start to build frost at any point after running the defroster in A/C mode for a bit, you can always try positioning the temperature control towards the middle or run only the outside instead of recirculating vent.
Jan 18, 2011 | 1998 Ford Escort
Ice is forming on coil fins
Either your coil is dirty or filter is dirty. Worst case your low on freon which would make a coil freeze.But freon doesn't evaporate if your low there must be a slow leak.
May 19, 2010 | LG Heat cool Window Air Conditioner
This unit has a manual thermostat. Is there a way
60 IS A DREAM TEMP MOST UNITS WILL NEVER REACH THESE TEMPS. THERE NOT MADE TO. AT 60 YOU LOWER THE HEAT ABSORPTION INSIDE AND OUTSIDE AND WITHOUT HEAT IT BEGINS TO ICE UP WHEN IT IS 70 INSIDE AND 70 OUT SIDE YOU WILL ICE UP 75 IS GOOD SETTING. IF YOUR TSTAT HAS A HOLD BUTTON SET TEMP AND PRESS HOLD THAT MY HELP
Apr 20, 2010 | LG LXA1030ACL Air Conditioner
Should the LG LS-K-1830CL outdoor unit ice over on the coils when operating in the heat pump mode? Would this cause the unit to not properly heat the room?
Running the heat pump in low outside ambient temps. will definitely cause the coil to ice up. An ouside temperature senor or a wind baffle should be installed in climates that get below freezing. This would definitely cause the heat pump to operate at lowered efficency and maybe not at all. It should go into defrost mode if the sensor is working correctly when the coil ices up.
Dec 20, 2009 | LG LS-K1830CL Cool Mini Split Air...
Ice build up out side hitting fan
pop out drain plug heat up pan with heat gun to melt ice
Nov 24, 2008 | GE Zoneline AZ38H12DAD Split System Air...
Wall ac unit keeps freezing up inside.
No! You will not likely find any service on a product which has very little value. Frosting will sometimes happen if the outside temperature is to low. The outside ambient temperature is directly related to the pressures inside the refrigerating system. The lower the outside temperature is the lower the pressures will be in the cooling end of the air conditioner. In mechanical refrigeration pressures and temperatures are directly related.
Nov 02, 2008 | Goldstar WG5000 Air Conditioner
Phkj048-1
If the outside temp. is lower than 32 deg. F it is normal for the outdoor unit to build up ice but not safe for the motor compressor. Because the safe outdoor temp. in heating is 5 to 64 deg. F but don't worry it has safety device to stop the operation.
Mar 18, 2008 | Goodman PHKJ048-1 Air Conditioner
Heating & Cooling Logo
29 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
