FAN FOR DUCTED HEATER BRAEMAR E22-367 NOT WORKING
GAS HEATER SECTION IS OPERATING BUT FAN NOT. I HAVE CHECKED THE FUSES (OK) AND INSIDE UNIT BUT CANNOT SEEING ANYTHING OBVIOUSLY WRONG
4 Suggested Answers
  • 5 Answers
SOURCE: braemar ducted heating wont switch on
If a used unit check under lid for a pressure hose no thicker than a pen , black or clear, look for splits or if disconnected reconnect
Posted on Apr 28, 2011
wentlanv
  • 710 Answers
SOURCE: just installed a new visionpro
Hi niklok,
You have the thermostat hooked up incorrectly. Honeywell's directions are sometimes confusing. You should have power first to the thermostat and from the thermostat to the heater. You cannot have power running both to the thermostat AND the heater. That effectively assures a continuous ON situation. The black wire from the panel should be connected only to one lead from the thermostat.
If you need further instructions, please reply back with the number and color of wires coming from the panelboard and the number of heaters and the number and color of wires coming from your thermostat.
Thanks,
Handie Andie
Posted on May 27, 2011
SOURCE: Unable to get Braemar Spectrolink thermostate to switch to auto
I have the same problem too. Did anyone get a solution for this?
Posted on Jul 23, 2012
Braemar spectrolink reset error 05
I had the fault code 05 (spectrolink controller) recently on a Braemer TG420 ducted heater. The heater would start and cut out on high temp as the room fan was not starting. I checked under the house and found the cable fitted to the return air thermistor had been chewed. I repaired the section of cabling and restarted the unit and it worked fine. Fault Code 05 is to do with the Thermistor in the return air duct.
Mar 27, 2012 | Heating & Cooling
I have a Vulcan Ultra 21E ceiling ducted unit The LED flashing fault is no 8 which is a gas interruption. The unit fan runs, ignition starts full flame and gas flows for about 2 secs then shuts down The...
Just been thru a similar problem with my Climate Technologies Vulcan High Efficiency Ducted Gas heater which in this case is installed under the house. This heater is about 7 years old and I have previously (2 years back) refurbished the controller by replacing the main power supply electrolytic filter capacitors.
I also had a communication problem with the Touch pad Thermostat which in the end required replacing the entire touch pad as one of it's voltage regulators had gone intermittent (Touch pads are available on E-Bay). To operate the heater while the touch pad was out of commission I installed a manual switch between the heat contacts on the heater controller. Closing the switch causes the heater to permanently run if it has no thermostat. Once communication with the touch panel was restored we were able to try and find the intermittent heater fault.
Again I have been getting Fault Code 08 "Gas Interruption" however the heater was lighting OK and then going out after about a minute or so. In the end I found 2 distinct heater faults.
Fault 1 was the flame sensor where the weld between the wire and flame probe rod had broken but it was still touching. This meant it was sensing Flame OK and then later would go open with expansion as the temperature rose. I fixed this by replacing the Flame Probe with a new one sourced from Reece HVAC.
At this point I celebrated thinking it was fixed!
Fault 2 after the flame sensor issue was cleared the fault still persisted but slightly less often.
The heater was cycling 3 times to get going and then locking out, requiring a reset from the touch thermostat or heater controller board. Sometimes the heater would achieve a onging burn for a long period, and other times just locking out after 3 tries.
Careful observation of the flame, through the observation holes after it lit, showed correct flame sensing but as soon as the nominal 65C duct temperature was reached the combustion fan (modulates) throttles back too far and the flame goes out, the flame sensor switches off and gas valve is then closed. The pressure differential across the burner manafold controls the Gas flow rate so if the combustion fan goes too slow the flame goes out due to lack of gas.
On the control board there is a potentiometer marked "MIN GAS RATE" this needs to be tweaked clockwise until the burner remains lit when the nominal 60-65C duct temperature is reached. Don't turn it up too far or the heater may not throttle back enough and end up going out on overheat.
Once a stable flame is achieved when throttled, try the heater in the economy mode which uses a lower recirculating fan speed and check the flame still remains lit. My problem was most obvious in the Econ mode.
Hope this helps someone else - It took me over a year to solve this one. NeilP
Aug 21, 2011 | Heating & Cooling
Braemar spectrolink comfort controller keeps on asking to be reset works ok for a while then goes to reset
Look for the error code on the right hand side of the display above the zone section and below the actual temp displayed.... refer to:
http://www.braemar.com.au/PDFDocuments/Section8_ServiceTroubleshoot.pdf
Jul 21, 2010 | Honeywell Programmable Thermostat Heater
My heater fan is not working on my jaguar x tyoe fuse ok what could it be
Check the fan motor runs ok if power directly applied to it,
if OK:-
check operation/replace blower motor control relay (if fitted),
check fan speed control resistor pack- usually mounted in heater air ducting.
Nov 11, 2009 | 2002 Jaguar X-Type
I have exactly the same problem, did you ever get an answer to this issue?
Sep 08, 2009 | Honeywell Programmable Thermostat Heater
Ac blower motor
Check fuse supplying fan is not blown,
Check blower control switch is operating OK,
Check relay controlling fan is operating OK,
Check variable speed resistor pack is not faulty (the resistor pack is usually located in the blower ducting, in the blower airflow),
Check blower motor ground connection is not missing.
Aug 12, 2009 | 2000 Mercury Grand Marquis
Braemar ducted heating wont switch on
Jul 12, 2009 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
