Question about IDV Consulting ResiGo
Problem accessing resigo database - IDV Consulting ResiGo
How do I easily repair corrupt or inaccessible Access database file?
Why to depend on anyone else suggestion. You may download one of the best access recovery tool which will repair your inaccessible access database file. This tool work on windows 10 & below versions also best thing is that free version of this tool will preview all your records after repairing your database. So you may preview your database and can easily review that your data is recovered and to export it you have to use full version. Try this access recovery tool. Access Recovery Tool Repair and Manage MDB or Accdb Database Files
Sep 09, 2015 | Computers & Internet
What should I do to regain access to dbf files?
If you are not able to access database files, its means that your access database file is corrupted or damaged due to this reason your access file is inaccessible. To repair corrupt access database file, you can use compact and repair features. If this method is fail, then try access database recovery software. I have used access database recovery software many times and got 100% recovery back.
Find more information http://www.access.restoretools.com/
Mar 22, 2015 | Microsoft Office Equipment & Supplies
How do I delete databases I don't need anymore from my access files
Access generates individual files which are the complete database, the interface and control program.
Simply deleting this file will destroy the database. the extensions for Microsoft Access Database files are:
*.MDB (Access 2007)
*.ACCDB (Access database 2010 - current)
Mar 10, 2015 | Microsoft Office Access 2007 - Database...
I need to perform access database repair
The repair method attempts to recover only the tables, indexes and queries in the database. Do not attempt to repair damaged forms, reports, macros and modules. Before executing the Compact and Repair tool, please ensure the following condition:
1. Do not Open Access database must closed
2. Sufficient storage space available - minimum double in size of your Access database on that Disk.
3. Close the .mdb file related to .ldb file before you delete the .ldb file.
4. Then Run the Compact and Repair tool
Read more about Access Repair Toolbox
On:- http://www.access.repairtoolbox.com/
I tried lots of the suggestions and eventually found that this page was the most helpful http://www.filerepairforum.com/forum/microsoft/microsoft-aa/access/1385-%E2%80%8Bhardly-corrupted-access-2007-database
Feb 28, 2015 | Microsoft Office Access 2007 for PC
Access database 2003 problem with a copy of database file. How to fix?
You say corrupt, in what way exactly? Do you get any specific error numbers/messages?
Have you tried Access repair program? Compact and Repair. If not, use it. But ensure that you made a backup, it is necessary because all the recovery tips can make the damage even worse.
Also try Jet Compact Utility. This tool created by Microsoft and it is much like Compact and Repair, but more successful in repairing.
If no one of above advice helps, then perhaps you need more powerful solution. In this case try to run a good third-party. I would recommend Recovery Toolbox for Access. It must help you. https://access.recoverytoolbox.com/
Feb 23, 2015 | Microsoft Access 2003 for PC
MS Access database recovery
Have you tried creating a NEW MDB, and then IMPORTING the objects from the Crashed/Corrupted MDB?
This will SOMETIMES serve to rescue most if not all of the corrupted entities .
Or:
You can try:
eRepair Access is a powerful Access database recovery solution for damaged *.mdb and *.accdb files created in Access 2000 and above. Having such a tool at hand immediately after a database file corruption incident may save you a great deal of time, nerve and, of course, an ample amount of money that would otherwise be paid to third-party recovery services. With eRepair Access, you don't need to depend on anyone and entrust your Access data (often quite sensitive) into somebody else's hands. You don't have to wait. You don't have to call it a day knowing that the damaged Access file will not be restored (if at all) until tomorrow. With eRepair Access, you can be back in the game within minutes!
For more information: http://access.erepairtools.com/
If doesn't help, look here: http://www.filerepairforum.com/forum/microsoft/microsoft-aa/access/933-ms-access-database-recovery
Feb 05, 2015 | Microsoft Office Professional 2007 Full...
Access 2007 corrupted database
You may try this third party tool programmed with best technology the tool support all windows and MS office versions. You may try free demo version of this software to preview your recovered access database. SysTools Access Recovery you may check How tool works and its user friendly interface make this easy to handle.
Jan 11, 2015 | Microsoft Office Professional 2007 Full...
How can i repair a damaged access database
There are some reasons which may damage your MS access database such as virus infection, software crash, accidental shutdown of system, unrecognized format of database, corruption of storage media etc. These issues are easy to overcome by using third party software of access database repair.you can try Kernel Access Database Recovery Software one of the best software in Data Recovery
For information you can visit here ...http://www.accessrecoverytool.net
Aug 23, 2010 | Microsoft Computers & Internet
What is the extension file name for a microsoft access file?
According to Wikipedia:-
Access Project .adp
Access Blank Project Template .adn
Access Database (2007) .accdb
Access Database Runtime (2007) .accdr
Access Database Template (2007) .accdt
Access Database (2003 and earlier) .mdb
Access Database, used for addins (2,95,97), previously used for workgroups (2). .mda
Access Database Template (2003 and earlier) .mdt
Access Workgroup, database for user-level security. .mdw
Access (SQL Server) detached database (2000) .mdf
Protected Access Database, with compiled VBA (2003 and earlier) .mde
Protected Access Database, with compiled VBA (2007) .accde
Windows Shortcut: Access Macro .mam
Windows Shortcut: Access Query .maq
Windows Shortcut: Access Report .mar
Windows Shortcut: Access Table .mat
Windows Shortcut: Access Form .maf
Jun 03, 2010 | Microsoft Office Access 2003 (077-02871)...
Computers & Internet Logo
32 people viewed this question
Top IDV Consulting Computers & Internet Experts
David Payne
David Payne
Are you an IDV Consulting Computer and Internet Expert? Answer questions, earn points and help others
