Question about Maytag Refrigerators
Led buttons flash and it beeps til i open the door or even sometimes i have to put off the switch .then compressor stops and starts . it happens once inthe morning or sometimesonce in 2 days usually inthe early morning. shall i go for a new if i have to pay more for the repair .i once paid 7000 to change compressor aftewr 7 years ,just after the guarantee period that is 1 year back.
  • Maytag Master
  • 10,045 Answers
The compressor is not the problem. The defrost timer may be set to the wrong time or the electronic control board may have failed.
Posted on Jul 28, 2017
SOURCE: Samsung side by side fridge/freezer
I bought one of these Samsung fridges a couple of years ago and just as the warranty run out, It started making a noise then the fridge compartment stopped cooling, so I did a web search and found out this is a common fault.I searched the web and found a step by step guide on how to fix on EBAY, under Samsung fridge Fault and it cost me £10.00 Only took me half an hour to fix it and it has worked fine ever since.A1+++ FIX
Posted on Oct 24, 2007
  • 1314 Answers
SOURCE: Periodic tripping of earth leakage switch.
your not supposed to run an appliance on a ground fault circuit because most of the components ground to the body og unit do you have it on a gcfi well here in america anyway
Posted on Jan 01, 2008
SOURCE: Model E372b Fisher & Pykel - Beeps with Fridge Door closed periodically-Higest shelves warm lower down freezes things
First I would like to say thanks for all the information on the Fisher-Paykel active smart fridge freezer problems. This was a lot more useful than their customer support help line… After a week of hanging on for ten minutes without any answer I had a look on the net and found your site with descriptions of similar problems so I decided to investigate further
I have a Fisher Paykel fridge freezer (model 402B in the UK) about three years old. Although it didn’t seem to be as cold as normal, the first sign of a serious problem was when it started making a rattling or knocking noise from the freezer compartment. Looking inside it was obviously iced up solid and the noise was probably the fan catching the ice. So first thing I decided to try was a days de icing after which everything seemed ok except the green indicator light was now flashing about once every second.
Two weeks later it was badly iced up again so the problem was still there. At first I suspected the fans (which I could never see actually working). I disconnected one and tried it with a 6v torch battery and it spun ok. It was then I realised what was happening - the fans cut out whenever the door is opened so they are always stopped if you look inside.
A closer look at the aluminium heat exchanger(behind the plastic panel at the back of the freezer section) showed there was some kind of heater element clipped along the bottom with feed wires at either side. Obviousely part of the automatic de icing systems. It’s a bit tricky but there an electrical connector plug at the top and disconnecting this enables you to unclip the element and remove it (except that in this case one wire had been trapped at the wrong side of the coolant pipes when they had been fitted so it had to be snipped to get it out). Once out a circuit test showed there was no circuit through the element. So cutting into the two shrouded connections at each end of the element revealed some little components inside which I now know are “Thermal fuses”. One of these had “Blown”. There was a number on the side: - DF 72S which Google revealed is a thermal fuse set at 72 degrees. Although these are listed as spares in all sorts of places non was convenient to the UK. So I found a similar component at Maplins Electronics (R14) set at 92 degrees for just 69p! The reasoning being that the other thermal DF 72S fuse was still ok and the slightly higher use temp at the other end would still blow before anything melted!
By the way you cannot solder these things in so its best to use miniature screwed “block” connectors plus a good covering with insulation tape.
After putting it all back together its now been working for a month and no ice build up… The green light did still flash for a while but went out once the temperature dropped too normal freezing level.
Total cost of replacement parts was under £1 but it took a bit of time find the problem.
Posted on May 12, 2008
SOURCE: Door open signal flashing -
First check to see that the door switch is closed fully when the door is closed. Tape it fully shut to make sure
Posted on Jul 17, 2008
wiznet2000
  • 86 Answers
SOURCE: my tv is 7 years old it has just started changing
If you are using the remote controller, try take out the battery, see if it stop changing channel. If so, clean or replace your R/C
Posted on Jun 23, 2009
We have a whirlpool ADG 7800 dishwasher ,getting a beeping sound and start button flashes 12 times? Any help
Hi
Ok try this and see what happens.
Hold the start button again till it beeps
Then select the first cycle on the left which should be the rinse cycle
Then turn the dishwasher off
Then press and hold the start button and with this held in turn the dishwasher on.
Once the start light is flashing let go
Now press the start button once and close the door.
Now it will run a 12 minute test cycle. If it goes wrong it will drain the water out and beep. So open the door and count the number of flashes from the start light inbetween the pause and let me know.
Regards
Oct 11, 2014 | Whirlpool Dishwashers
Why won't my washer start a cycle? Start button LED just flashes. All other lights are steady. Door lock sounds like it engaged, but nothing happens.
There should be a way to enter the washing machine into service mode to view an error code. Check your user manual and then you should have your answer!
Jul 23, 2014 | Washing Machines
Garage Door Remote
Did you happen to put a new light bulb in it? I put an LED bulb in mine and the interference caused the remotes to stop working. I had a bear figuring it out, because it seemed to be totally random. Sometimes they would work and sometimes they wouldn't. Once I switched back to an incandescent, it worked fine.
Jan 17, 2014 | Genie Wayne Dalton 36560U 1/2 Hp Dc Belt...
I have a Bosch dishwasher model # shx4ap05uc/06 and I want to silence the alarm for when it is done. It goes off every 10 minutes until you open the door
Yes, you can switch the cycle completion signal off (or raise/lower the volume)
1. Switch the dishwasher off using the ON/OFF button
2. Open the door
3. Switch the dishwasher on again. (One of the wash cycle LEDs will flash.)
4. Hold the > button in. Continue holding it and press and release the Start/Reset button once, then release the > button.
"Clean" and one other LED should now be flashing. This indicates that the dishwasher is in the options/settings mode. If they are not flashing, start over at step 1.
5. Press > repeatedly, until the LEDs for "Clean", "Sanitized" and "Rinse Agent" are all flashing.
6. Press repeatedly until none of the LEDs are flashing.
The number of flashing LEDs indicate the volume setting . . .
0 = Silent
1 = Volume level 1
2 = Volume level 2
3 = Volume level 3
7. Press the Start/Reset button once to save the setting and exit the options mode
8. Close the door
9. Switch the dishwasher off.
Hope this helps. Please let me know if you need further assistance.
Regards,
BElectric
May 27, 2011 | Bosch Dishwashers
I have a Chamberlain Whisper Drive and it started beeping. Reading the manual, it seemed that I needed to replace the battery. It is about 5 years old. Replaced the battery and the LED is no longer red but...
On the back of the garage door opener there is a red button. Depress this button and sync your keypad to the opener. This will re-establish the code and reset the remote.
May 27, 2011 | Sears Craftsman LiftMaster Chamberlain...
The lights come on, but the machine doesn't start
do you hear a beep when the start button is pushed? if u do hear a beep then it could be your lid switch is faulty, if you dont hear a beep then your keypad is faulty. is the plastic covering the buttons cracked?the keypads fault sometimes because water goes thru the cracks into the electronics causing it to corrode. please reply with answers 4 more help.
May 06, 2010 | Fisher and Paykel GWL11 Top Load Washer
The doors do not open by remote control key(BMW 740il 1996 model)
Programming
When
Key batteries completely discharged. Key batteries not replaced within 60 seconds. Key added or replaced. DO NOT press remote control buttons during battery replacement.
How
Unlock vehicle. Enter vehicle. Close driver's door. Switch ignition ON and OFF. Remove ignition key. Press and hold unlock button Fig. 1 [1]. Press lock button Fig. 1 [2] briefly 3 times within 10 seconds keeping unlock button [1] depressed. Release unlock button Fig. 1 [1]. Some models: LED Fig. 1 [3] flashes slowly for 10 seconds. Some models: Central locking system locks and unlocks rapidly to indicate correct programming. Some models: Repeat above procedure if central locking system does not work and LED does not flash or LED flashes continuously
To change batteries remove panel back of key then screws on plastic bar
Batteries are available from your local motor factor shop
You might not need new batteries try re programing as described above
Apr 24, 2010 | 1998 BMW 7 Series
Resetting the Drum counter on a Brother HL-2040
Hi.
Have you recently replaced the drum?
  • The Drum LED blinks if the drum unit is near the end of its life. Use the drum unit until you have a print quality problem, then replace the drum unit with a new one.
  • The Drum LED continues to blink if the drum counter was not reset when you replaced the drum. To reset the drum follow the instructions below:
  1. Open the front cover of the printer.
  2. Press and hold down Go button for about 4 seconds until al the LEDs light up. Once all 4 LEDs are lit, release the Go button.
  3. Close the front cover.
Reset the drum counter only when you replaced the drum unit with a new one.
Aug 03, 2009 | Brother HL-2040 Laser Printer
Danby microwave m # 1153
danby dmw11536 my microwave oven start beeping all the time. i can start it if ipush the cancel button, ordinarely once but sometimes it won't start unless you unplug it. also disylay shows 1:00 but keep time of cooking anyway. after it returns to beeping all the time, sometime you have to leave it unplugged for a couple of hours. danby dmw11536
Aug 27, 2007 | Microwave Ovens
Refrigerators Logo
27 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
